- engine swap info Please
- check engine light
- Problems Cranking
- dead at gas station, yikes !
- IAC cleaning for rough idle problem
- southern ford v6 race
- 265rwhp 280rwtq ALL MOTOR
- throttle body spacer
- How to...
- Flywheel?
- tranny and eng probs
- 4.2 Mac Intake
- rebuilt 4.2 shows no oil
- custom exhaust
- Overdrive
- pics for let me know what you think of my truck
- rough idle and rattle
- v6 verses v8
- EMERGENCY !! 3.0 Not Starting
- let me know what you think of my truck
- 4.2 cam specs
- 4.2/4.9 L Turbochargers!
- Intake gasket help...
- Overheating Issues
- Turbocharging a 2003 4.2 V-6
- v6 or v8?
- Where should I buy Electric Fans?
- Goodbye to My Old V6 Friend!
- raced a cpl ppl today...
- EVAP Code P0455 Gross Leak
- Battery light / EGR
- Cold air intake trick
- Dissapointment
- muffler removal?
- 98 4.2 Shakes
- oil pressure fluctation, how much time left?
- Driveshaft
- Pulleys
- Help finding Catalytic Converters PLEASE?
- IMRC stuck open Code!!! help
- 4.2 Engine oil
- Leaky head gaskets - failure imminent?
- speed recalibration
- front (V6) suspension question
- 1997 4.2 Lugging
- Dip stick won't go in.
- Engine Mods
- Great gas mileage anyone?
- What is overdrive?
- Heater Inlet Hose
- Sound of a 4.9 300 6
- 1997 4.2 lugging and multiple missfires
- #2 Cylinder Misfire
- underdrive pulley causing overheat when towing?
- P1537 Code
- Is our truck capable of pulling a trailer
- Intake Install Help
- High Idle
- Cold Air Intake for a v6 f150
- How to change oil in my 1999 V-6 F-150
- the year 1997
- P 1152
- intake manifold air leak
- i dont understand this gas ****
- Gears
- throttlebody
- Rebuild or Used? Help needed
- another 4.2 bites the dust
- Help adding Horsepower to my truck
- high volumn oil pumps?
- Plugs of choice
- 1995 V6 ????
- 4.2 has served me well
- Best chip for a 4.2 or 5.0
- MAF Location
- 4.2L kind of jumping???
- 97-f150 too slow!!
- quick question
- anyone want to burn that stupid 4.2L
- magnaflow and flowmaster exhaust??
- Need some help 2002 F-150 4.2 no power
- thinking about a 1999 f150 4.2
- 4.9 300 Inline 6
- Check out my truck
- Speed
- rough ride (occasionally)
- straight pipes, i need help??
- V6 knock
- dodge boy
- exhaust suggestions?
- Anyone use a BBK 3.8l throttlebody
- !!best Performance Mods V6!!!
- My truck has 53000 miles now-Advice?
- Superchip and the PCM
- 3.9l dakota vs f-150
- 96 Ford F-150, 300 inline 6
- 'Factory' Idle
- exhaust help!
- Gas Guzzler??
- 4.2L GEAR GRINDING INTO 3rd
- a 305 in an f150???
- 4.2l exhaust?
- V6 Stumbles on Acceleration
- Looking for a clutch kit
- 250 rwhp from a NA 4.2, beat that v8 boys
- Need Help 4.2 Belt Routing Please Help Me
- looking for best mods for low end torque
- My new baby!
- Towing
- Any problems putting a 2002 engine in a 1997
- Is my basic warranty still valid?
- Water Leak?
- 4.2 exhaust
- micotuned V6?
- Water leak, FLoor of Truck Soaked!
- 4.9 L oil leak, surge, PCV
- f150 vs. tundra
- Oil Pressure Gauge Fluctuation
- 4.2 troubles must be folklore!!!!!
- Recall question and other info...what does all this mean?
- Oil pressure
- Ignition switch
- 5.0 Missing Out When Hot
- What's ticking
- 4.2 leak and I'm getting hosed
- Where is the radiator drain valve?
- Question ??
- Keyless questions...
- I just got a 2002 f150 !!!!!!!
- Cool Sites for us 4.2L V6 guys... and maybe gals
- Any Ideas?
- available cam grinds for truck V6's!
- Redline Shiftpoint When Racing?
- the little security thingy...
- flowmasters on a 96
- Wich belt for underdrive pulleys?
- Code # 0401
- Flowmaster 40 on V6
- oil level after changing oil
- 4.2 Liter
- 98- 99 4.2l upper and lower intakes?
- I give up!!!!!!!!!
- engine life
- Knock sensor question.
- mac header
- Exhaust question
- More power for my V6
- Slight Pinging
- RGR in the house
- Anyone running 285/75R16's with 4.2L
- Premium gasoline?
- dyno #'s 4.2 v6
- Intake Gasket - Cost
- How Much Oil ??
- few ?'s bout nos system
- dipstick
- superchip/jetchip
- Oil Pump Replacement
- Graduated from F150's
- ringing sound
- who has the most miles?
- V-6 long blocks
- Check Engine Light on at 18k miles....
- 30 gallon fuel tank capacity
- 4.2l V6 3V
- any tips for a dual exhaust?
- Scamer on classified section
- Anyone put one of those V8 intakes off ebay on their V6?
- v8 killer
- super charger
- 2002 F 150 models?
- knock sensor?
- Ohh Crap Help!
- need more power HP
- throttle cable
- Idler Arm on V6
- Finally made my gallery
- Doing the Lower Intake Gasket replacment... just a few questions
- Getting Rid of a HyperTech Power Module
- How bad did i get burned?
- Engine Knock!!!
- Gonna race a HEMI
- Carpeting
- engine swap
- Fuel injector/regulator knock?
- new k/n intake
- dipstick -- metal chips?
- Low Temp Thermostat gains
- K&N and now i'm lean?
- Know of any High Output Ignition Coils???
- Throttle Body Upgrade for V6
- Power Steering flush increasing MPG?
- 4.2l v-6 service endine soon light need help
- 2001 4.2L Swaped for 1997 4.2L Problems
- new tach installation help please
- Idler Pulley
- Hesitation [without Check Engine light]
- Service Engine Soon light back on
- slight ticking noise AFTER startup?
- Air Induction System????
- my micro tuner is finally here
- Engine Management System
- Loud ticking/ clunking at start up
- 4.2 97 Help!
- 4.2 L Vortech Supercharger
- Ringing Sound
- V6 Ford Challenge WEBSITE UP!!!
- Senors gone bad?
- What did you pay for your v6 f150??
- AjRango,you the man!
- After gasket problems we'll be talking fuel injection
- 4.2L engine in 1997 F150 bombed at 80k miles
- SUPERCHIP installed this morning
- Towing Capacity Question
- Problem trends with 2002 F150 6 cyl?
- Whats real problem??
- Dynomax Exhaust..
- Who has a SuperCharged V6?
- Slow warm-up ?
- gas mileage dropped
- quickest v-6 f150
- trade in
- rpm gauge
- What type of coolant is in your 4.2
- Fuel Mileage for V6...
- What Gaskets:
- Oil for High Mileage
- 2002 engine into a 1997?whats the difference
- Adding Stop leak :
- micro tuner
- micro tuner for v6
- v6 to v10 conversion
- Service Manual - 2002 vs 2003
- Where do I buy parts???????
- LOooong cranking time to start
- RUFF idle
- oem airintake
- Hiiisssssssssssss!!!!
- A/C Clutch
- engine diagnosis
- Coolant question
- Near St Louis? Want a Procharger? Look inside...
- lifted v6
- 5600# Gvwr
- eratic studering????
- help on some customizing issues for 97 4.2L
- hesitation and slow start
- gibson exaust?
- air intake heatsheild
- Flowmaster Part #?
