engine stall at the stop corner
Hi,i have a f-150 1997 motor 4.2 4X4.I had no time to change my (wires,plug,and coil pack)so I went to the garage .before the truck was running well except I had a code of misfiring on cylinder #4 but I was travelling with my truck on on the road without problem.they change my coil
pack and I told them to change my wires and plug.
they gave me my truck back today and after 30 minutes the truck start to run like hell.When I stop at the corner (every stop corner the truck stall)
if I put it on the neutral before the stop and keep my foot on the gaz pedal
and put it on drive I have a little less problem to restart.
on the neutral the idle is ok but as soon I put it on reverse or drive it stall,
need help please,
need my truck for my work,(should have done the tune up myself like I always do
Thanks for your help
need help please,
I did went back to the garage and you should have seen me there,they try lost a thing but after 2 hours,I told them don't touch my truck anymore I was mad like hell and before I do something bad my wife said lets go.I told them they are good only to change tires and something else I won't say on this forum,
