engine rattle at shutoff
Old Aug 16, 2009 | 11:48 PM
blueoval5.4's Avatar
i have a 97f150 4.2 with 93,000 miles and when i shut off the truck the engine has a little rattle noise? Is this normal? other than this truck runs pretty good and the engine sounds smooth yet.
Old Aug 22, 2009 | 11:59 AM
nobody notices any type of strange noise are ticking at shutoff?
Old Aug 23, 2009 | 11:27 AM
bugser's Avatar
Ticking would be cooling down of heat shield or something. A rattle would be something loose.
Lots of fun to track down.
Old Aug 23, 2009 | 09:14 PM
CRDick's Avatar
Engine rattles
on an older engine it used to mean you had a problem with carbon and the engine was "dieseling". dont know if thats true on our modular engines since i have not had my 01 do it since i bought it.
Old Aug 28, 2009 | 12:04 PM
The V-6 is not a modular engine.
Old Aug 31, 2009 | 12:04 AM
I had some one listen to it and they said it almost sound like its from the back side of engine. Since my truck is a manual trans could it be the gears kind of slowing down at shutoff? Since the noise is at the back of my engine my second thought is that it could be the cats rattling?
Old Aug 31, 2009 | 09:29 AM
bugser's Avatar
If the truck isn't moving the gears aren't either...at least, you hope not.
Could be something loose back there. Another thread around here mentioned an engine bracket? I don't remember where I saw that.
Old Aug 31, 2009 | 11:22 AM
Are you shutting it off in neutral with the clutch engaged, or with the clutch disengaged? Any difference doing it either way?
Old Aug 31, 2009 | 12:39 PM
PhqChevys's Avatar
It could be that you throw-out bearing is going bad. I had a similar sound before on a '82 CJ-7 Jeep, it ended up being the throw-out bearing.
Old Sep 1, 2009 | 01:10 AM
If i shut the truck off with the clutch pedal pressed in my truck doesn't make the rattle noise... could this be bad input shaft bearings are a bad throwout bearing?
Old Sep 1, 2009 | 11:37 AM
PhqChevys's Avatar
It wont make the noise because you are putting pressure on the throwout bearing. That's how it acts when it's just starting to go out on you. When it's condition worsens, it will start to squeal or rattle when you put pressure on it. It's just at the beginning of it's death....IMO. That's what my experience with throwout bearings have been...
Old Sep 1, 2009 | 12:05 PM
Considering your other thread where you are asking about play in the input shaft, this may be what's doing it.
Old Sep 1, 2009 | 12:11 PM
Thanks for the guys. I guess the culprit is bad input shaft bearings.
