P0172 and P0175
Old Feb 8, 2009 | 08:46 PM
Bad4.2Truck's Avatar
Question P0172 and P0175
those are the codes my truck has been throwin. it started off just thrown P0172 but now its thrown both of em. accordin the the other thread its the fuel trim system rich. i dont know what i should do about this? what exactly is it and how can i get it to stop?
Old Feb 8, 2009 | 09:02 PM
Paralyzer's Avatar
if it is both banks i would check the fuel pressure regultor, make sure the maf is clean and the air filter isnt restricted.
Old Feb 8, 2009 | 09:21 PM
i got a airaid air intake but it runs of the stock mass air sensor and a throttle body spacer... whats the MAF?(mass air filter?) and where can i check the fuel pressure regultor? thanks
Old Feb 8, 2009 | 10:46 PM
Paralyzer's Avatar
MAF=mass air flow sensor
do u have access to a fuel pressure gauge?
Old Feb 8, 2009 | 10:50 PM
the gauge thats on the dash reads that its fine
Old Feb 8, 2009 | 10:57 PM
Paralyzer's Avatar
what gauge?
Old Feb 8, 2009 | 11:10 PM
idk wat the fuel pressure gauge is
Old Feb 8, 2009 | 11:17 PM
Paralyzer's Avatar
it is not a factory gause on the dash, you hook it up to the fitting on the fuel rail to check fuel pressure. if your not to mechanically inclined i suggest you bring it in to a qualified person.
Old Feb 9, 2009 | 10:09 AM
thanks man. ill go get it checkd out
Old Feb 13, 2009 | 11:44 AM
Black $ Chrome's Avatar
its showing your rich your o2 sensors are doing there job check you throttle body and make sure its clean of carbon make sure your air intake isnt pluged up even inside the fender and your mass air flow sensor is in the bottom of the airfilter jug get some eletrical cleaner and spary it down dont use brake clean hope this helps
Old Feb 13, 2009 | 01:32 PM
i fixd it my air filter was leakin
