View Full Version : Other Powertrain
- Cruise Control
- ratio of standard differential XLT
- WARNING TO 98 AND NEWER F-150 OWNERS
- Can not locate 75w140 axle oil. any help?
- Need serious help with drivetrain prob...
- Moving up to 4.10 gears
- Limited slip?
- Noise in the four wheel drive shift.
- How to install a speedo gear?
- '75-76 F-150 Axle Width?
- 4.10's not an option in Ca. on a Supercrew,5.4,4x4, from the dealer.
- 6500 GVR weight pkg.
- Noise in 4WD
- removal of transfercase
- 99 f-150 4wd hub/bearing service
- Transfer case broke
- clunk feeling on take off
- 97 4x4 CV joint lube
- Weird sounds from rear end!
- Need info on limited slip problems!!!
- 4.10 gears installed!!
- Which gears?
- Auburn Gear now has limited slip diff for 9.75"
- Speedo diff with 33's and 4.10's?
- Speedo Gears........
- Speedo calibration to new gearing
- LS quite working ?
- lowered front alignment question
- Speedo problem with 2000 F-150, PLEASE HELP!
- a dumb 4X4 question
- aftermarket limited slip and what rear end?
- Will friction modifier hurt my regular/open differential
- auto hubs
- 4x4 not engaging
- Still no aftermarket LS diffs for 9.75"?!?
- Wise to order the 7700 GVW to net 3.73 gears?
- Towing Package?
- ARB Lockers
- driving in 4H
- 3.31 gears
- No More Hop
- 2:75 to 3:55
- 2000/2001 Rear Axle Whine
- diff. vent tube
- 3.55 to 4.10 change
- DRIVETRAIN
- Noise in 4WD
- Limited Slip?
- Anyone installed their own gears?
- bad vibration when i reach 100mph
- Speedometer Calibration
- 4.10 Gears
- Gear change and rear end size ??
- Trans/Diff Change over
- 97 F150 Supercab Rear axle noise
- manual hubs/2000
- How do you I.D. your diff gearing?
- Gears vs gas mileage
- gearing change for 5.4L Expi and 35's?
- Transfer case rebuilt!
- Calling StrangeRanger, Trac-lok question...
- 1997 F150 4X4
- Jerking / Kick? at stops
- Ok, it was funny the 1st time...now, its annoying [Loc-tite?]
- Gear Change Report
- 4x4 shift on the fly does not disengage
- 3.55 gear or 3.73 gears? That is the question..
- 4X4 operation
- 3.55 to 4.10
- gear change and/or LS
- SPEEDOMETER GEAR Problem!
- Rear differential leak
- Metal to metal in reverse- breakage?
- 4x4 w/auto trans problem: Help?
- Gear change for a newbie
- gear ratio
- '92 F-150 4WD now not engaging
- Transfer case damaged!
- 4X Low noise
- Differential Identification
- Socket Size?
- Good shop in Dallas/Ft Worth area to install posi?
- Converting to Limited-Slip axle
- tie rod failure
- Gear Help!
- Hey, guys, what's "axle wrap" mean?
- Gear Companies
- Which rear axles swap into '95 F150?
- Question about 4 wheel drive system in 2001.
- Anyone got a locker
- Marbles in transfer case!
- 3.31 vs 3.55 and 4.6 vs 5.4
- All the ring and pinion parts and info you need!
- 4.10 or 4.56?
- 3rd member oil level
- New Gears; What parts do I need?
- Smog laws vs. gear changes???
- Differential friction modifier?
- spec sheet
- 4X4 Problems HELP?????
- No 4x4?
- axle swap???
- 4x4 Low - how many revs do you go?
- which gears are better?
- Gear Pricing
- seal wears grove in frnt axel after 79k miles!
- Body Lift still bad, getting worse
- Oh no! Body Lift gone bad! Please Help!
- If i hear this 'clunk' one more time!!!!!!!!
- Vibration -- Please HELP!!!
- Tow Gearing (Mike or Anyone)
- Power steering fluid level?
- "Clunking" from 4x2 to 4x4?
- locking hubs
- LS Hop?
- Fuel Filter or Tranny?
- Winter driving and LS vs Non-LS
- Pinion seals leaking.........
- Steep gears, STEEP cost...
- Transfer case gremlins
- Can LS 4X2 truck go in the sand?
- squeaky steering
- axle splines
- Locking Hubs
- transfer case and diff fluid.
- Poweraid?
- Change gears?
- Gearing Questions
- Wheel Studs Stretching and Snapping Off
- Where to get TubeSand?
- Cost to change 3.08 to L.S.
- 4 Wheel Drive
- WHICH GEARS...?
- Any new 9.75" Powertrax news?
- Do I need gears...?
- No grease fittings on u-joints?
- Lockers
- Clutch Problem
- clicking driving me crazy!!!
- Identifying rear end / gear ratio
- What causes a Rear end to pump out fluid?
- LS axle-is it dangerous in rain/snow?
- electronic transfer case
- Rearend Gear Oil ?
- 4X4-Shifting to 4L
- Locker Rear-ends, best thing since sliced bread!
- Changing rear gearing / LS?
- 4x4 Dust Boots
- rear gear ratio and limited-slip?
- 1999 F150 ext-cab vibrates
- Bigger tires to change gear ratio
- Electronic Transfer Case operation
- What should I look for in a used STX
- any sugestions on a clutch??
- The need to shorten your drive shaft
- Auto Hubs
- Can I convert to limited slip?
- Vibration on Right turns
- 97 auto trans. mtg brkt cracking, is yours?
- clicking noise
- electric or not?
- 265 to 285, 5.4 L, 5 sp, 4.10's... should I recal speedo?
- Rear End Noise
- Rear End
- Slipping Feeling in driveline
- axle ratio
- National Backlog on ShortBed driveshaft orders?
- Unknown Humming Noise
- I know nothing about gears!
- Rear End
- OEM 4:10 or 3:73???? HELP!
- Gear Change
- E150 driveline noise question
- 5W-30 oil or Synthetic???
- Detroit Gearless Locker
- Wanna change from 3:55 NON LS to 4:10 LS or Posi
- Whining Noise
- 8.8 or 9 axle?
- thump and vibration
- Rear Diff Vent Issue
- good u-joints?????
- 99 gear swap/speedo correction
- Auto 4WD swap into S-Crew
- R&R Electric T/Case Shift Motor
- 4x4 question...hmmmmmm?
- Same 4x4 problem
- Front axle drag????
- 8.8 4.10 gear part number?
- Solution to 4x4 Not Engaging Problem
- clicking noise
- '92 F150 rearend
- Other Drivetrain
- Loc rites and others?
- rear fluid 97 4x2??????????
- 97 F-150 rear axle seals & squeaky front end
- Front Wheels no power problem
- 4.10 Gears and Speed /RPM Readings
- part # for friction modifier
- 4x4 Question
- 3.73 vs 4.10
- will 4.10's hurt mileage on the expy?
- Why do my tires spin
- Gear ratio?
- Expedition rear end swap
- Reprogram Spedometer?? 97 and newer
- Gear Recommendation
- Steering noise on 1998 F-150 4X4
- LD Diff Cover Vs. SD DIff Cover
- SLIP YOKE TSB...WHERE TO FIND???
- Expedition Rear End Fluid Change Questions
- Help buying '99 F150 XLT
- Just got my Mag-Hytec differential cover
- Gear Ratios
- New Gears + Posi.
- "Klunk" in Rear-End
- What gears for 4x4 4.6L 5-spd?
- Is the expedition 2wd have the ford 9.5 inch rearend?
- Has anyone gone from 3.08 to 4.10s?
- 4x2 to 4x4
- Can anyone explain how '97-2000 4x4 works?
- Manual Locking Hubs for a '97 ??????
- Powertrax
- Gear prices
- rear axle swapping
- FWD F150?
- Electronic Shift-on-fly Question
- Slow Throttle Response
- Speedo gear for 97 F150
- Need displays of Drivetrain
- Driveline Vibrations
- Help. Noise coming from front end
- 4.10's are in like a hair in a biscut!
- Front differential fluid leak
- Code for one ton rear-end
- found traclok and lockrite for the 8.8 front end
- ignoramus
- 3.73 and bigger tires
- Truck Options
- How Much Quicker 4.10s than 3.55s
- Severe Vibration @1200 - 1800 RPM
- Ford 9" Rear End
- MPG after changing 3.55's to 4.10
- Aluminum drive shaft?
- SuperCrew 4.10 Gears ???s
- 4.10s, How much difference to expect
- Seedo calibration
- Fluid Leakage
- 1998 GVWR Option
- Option Packages
- Option Packages
