Change gears?
I have a 2001 Screw 4x4, 4.6, 3.55 LS. It came stock w/ 16" rimes and I changed them to 17". Since I bought the ride a purchased a #6000lb. boat/trailer. I had a tough time towing so I got a K&N, cat-back and chip. It helped ALOT but I know i'm right at my towing capacity and am wondering if I should do more to the truck. ie. new gear ( front and rear? any idea on cost? ) headers, go back to 16" rimes ( looks silly on a 4x4 ). Any ideas?
Thanks, Greg
2001 SuperCrew, 4.6, 3.55LS leer shell w/ rack, complete tow and off road pkg. K&N, catback,
Thanks, Greg
Just mentioning the change in rims is not enough information from which anyone can help -- because you didn't mention the net change in tire diameter. Working with gear ratios is simple -- since it's just a matter of working with, er, RATIOs.
If you changed from a high aspect ratio 16 inch tire to a low aspect ratio 17 inch tire -- and the overall tire diameter stayed the same -- you changed nothing.
Note that if you were to have changed from an LT265/75R16 Goodyear Wrangler AT/S to a LT265/70R17 you would have gained/lost NOTHING, as they both measure 31.7" in diameter (ref: http://www.goodyear.com/us/tires/tir...LAT_SSize.html ).
So...
...you can have those nice wheels and not harm your effective gear ratio by smartly-sizing tires.
Was this helpful?
Y2K™ 7700 4x4
Jim - N8JG@Hotmail.com
Toreador Red, Keyless XLT SC SB 5.4L E4x4 4wDisc/ABS, 3.73LS, Skid, HD 7700# Towing, LT-245's on Chrome, Tube-Steps, Captain's, 6CD, Tonneau, named: "Nick"
So...
Was this helpful?
Y2K™ 7700 4x4
jgorka,
It came stock with Ford's 16" polished aluminum rims with General tires 255/70/16 and I put Ford's 17" aluminum rimes with 265/70/17 tires. I have found out that it will cost around $1,100.00 to change the gears to 4:10's, so I probably will not re-gear. I just am curious about how much it changed my ratio. Any other power enhancing ideas?
Thanks, Greg
Thanks, Greg
If you're really worried about pushing the limit, it's time to upgrade to a Super Duty. I pull a 5600 lb boat in the summertime with no prob. When I had my 97 with a 4.6, it always felt like it needed more oomph, but I shouldn't have that problem with the 5.4. :-) If I want to go fast, I'll take the car. :-)
-Joe-
98 Explorer (Lemon Law Case in Progress)
'00 F-150, X-cab, 4x4, Lariat, Off-road, Trailer Tow, Holandia Sunroof, built 11/99 picked up 10/00!
List of planned mods: Clear corners and tails, CB wiring, Stainless brush guard, at least 1 set of KCs (probably more!), custom radar detector mount, color matched trailer hitch with stainless steel ball, torsion bar tweak, bug deflector, spray in liner, and a tonneau of some sort...
93 Probe GT teal, OE rims painted to match, bone stock drivetrain.
-Joe-
Joe,
Its not that i'm in a great need of more power, even though its always nice, I just want to make sure the drive train can handle it. The 17" tires stand around 1 1/3" taller than the stock rimes and tires that came with the truck. Any other 'bang for your buck' power ideas? I have - chip, catback & K&N.
Greg
Greg
