Slow Throttle Response
My Brother and I Have the "identicle" trucks.
Both trucks are 2000 4X4 ORP supercabs with 4.6 L.
When I drive his truck I notice the throttle responce is great!! The gas pedal is very touchie.
My truck is the complete oppesite!!
The gas pedal is very mushy! I have to push it 1/3 of the way down for the truck to move. Very annoying!!!!
Performance wise they are the same. A few drags of the lights prooved that!
Any Suggestions.
Any suggestion???
Snowman: Black 2000
F-150 4X4 Off Road, King Cab
Any Suggestions.
Any suggestion???
Snowman: Black 2000
May not help but I used my hand to push my gas pedal and found about an inch of slack on the pedal before it moved the cable. I placed a nut and bolt just behind the gas pedal to take up the slack. Now you touch the pedal you get rpm change.
97 F-150, 2WD, Reg Cab,Flareside,Dk Toreador Red, Windsor 4.6, Magnecor 8.5mm wires, Bosch Plat +4s, 3.55 LS, EGR Bug Deflector, ******* Bed Cover, Bed Liner, XL Full Length Running Boards, Air Aid Kit, Gibson Single Out Cat Back, Superchips, TransGo Shift Kit, Hellwig Rear Sway Bar, Hellwig 2500# Overload Springs,Energy Suspension Polyurethane Front Sway Bar Bushings, 265 70 16 tires, Rancho RS9000 shocks
