axle ratio
Old Oct 24, 2000 | 08:51 AM
eagle63's Avatar
Post axle ratio
Is it possible to get the 3.73 limited-slip rear end with a 2001 F150 XLT, off-road package, 5.4 V-8??? I was checking out the vehicle configuration page on Ford's website. -it wouldn't let me choose this combination. the best I could do was a 3.55 LS.
Old Oct 24, 2000 | 11:35 AM
michael_hovis's Avatar
Post
Since the 2000 models, you're required to get the 7700# GVWR package to get the 3.73 LSD axle.
Edit - I moved from Minneapolis last year, went to the U from '93 to '99. How's the weather?
Model: '99 F150 Lariat Supercab 4x4 SS Mechs: 5.4L, 3.73 Diff (9.75" LSD Rear, 8.8" Front)
ORP: Skid Plates, LT265/70R17 GY Wrang. AT/S
Group III towing: HD Electrical/Cooling, GVWR 6500# (Extra leaf spring).
Stuff: Step Bars, 4W Disc ABS, K&N filter, 0W-30 Series 2k Amsoil @ 8200 miles, Herculiner
Stock Items That Differ Across F150s: Steel Driveshaft, Oil filter bolted to engine w/ drip guard, 4R70W transmission.
[This message has been edited by michael_hovis (edited 10-24-2000).]
Old Oct 24, 2000 | 02:54 PM
eagle63's Avatar
Post
what is included in the 7700# package?? I'm sure I don't need anything in that package, but I would really like to have the 3.73 LS.
P.S. weather's been great for an October in MN! 70's and 80's all week.
Old Oct 24, 2000 | 06:51 PM
JDF's Avatar
JDF
Post
O.K. A real rookie question.
What do the different gear ratio's mean/do?
I have the 3.55LS. 3.55 was standard on the sport model. I ordered the LS presumably to make it a better 4x4.
My other question is that I ordered LS and the window sticker says LS, but the owners manual refers to it as Traction-Lok. Have they changed something or is it the same thing?
2001 F150 SC SPORT 4X4 FLARESIDE
* Black
* 4.6
* awesome factory 10 spoke 17" wheels
* "MAN"ual shift 4x4
* 3.55 Limited slip
* Captains chairs W/console
* Factory tube steps
* Slider
Old Oct 24, 2000 | 07:35 PM
Y2K 7700 4x4's Avatar
Post
The 7700 package gets you LT tires, 4-leaf rear springs, a bigger frame, 'approval' to mount a snow plow, a stiffer ride, 4-wheel disk brakes, and a nice 7700 sticker on the tailgate . It only comes in the Auto 5.4 3.73 variety.
JD: Ya done good, lad -- as the 3.55 is the standard for HD towing. When you order the 7700, you up the tire size by about half of what you'd expect to gain with the 3.73. Ford tries to keep the highway cruise in the 2000-2300 RPM range, and your set-up will tow quite a load without any complaints. Limited Slip is standard issue for any off-roading -- with some actually wishing for LS in the front axle (until they actually Drive one and discover that it turns like a boat).
Y2K™ Jim - N8JG@Hotmail.com
Toreador Red, Keyless XLT SC SB 5.4L E4x4 4wDisc/ABS, 3.73LS, Skid, HD 7700# Towing, LT-245's on Chrome, Tube-Steps, Captain's, 6CD, Tonneau, named: "Nick"
Old Oct 25, 2000 | 07:49 PM
max mitchell's Avatar
Cool
Eagle63- 7700 pkg = 7700GVWR/1830 payload, larger brakes/& tires, high capacity 7-lug wheels, HD frame/shocks/springs/electrical/& cooling.
JDF- the Traction-Lok is the LS (limited slip)."What do the ratios mean/do" = it is the ratio of incoming (driveshaft/pinion) compared to outgoing (ring/axle) transferred inside the rear end through gears. Higher #s = lower ratios and visa versa. The different gears are used for different needs. Lower gears (higher #s) are quicker during acceleration, aid in towing, and lower top speed. Gear differences also affect mgg and rpms. Just a brief, non-technical overview.
2000 F-150 XL,RC,LB,5.4,4R70W,3.55LS,
Class III tow/Payload #3/Convenience pkgs.,
4-wheel disc/ABS,Chestnut/Parchment 40/60,
Ford bedliner & gas/wheel/spare locks,
3" cold air box modification, Superchip,
Dynomax ultra-flow welded 3" cat-back,
3" exit Y-pipe, Hellwig rear anti-sway bar,
Rancho RS9000s.
