View Full Version : Engine
  1. 4.6l Stroker Kit
  2. Best way to change fuel pump on 98?
  3. Help: Started Motor,At least 2 qts of Oil poured out from the Motor
  4. very high idle!!
  5. 4.6 Misfire
  6. Want Better Fuel Mileage??
  7. p 0125 & p 0300???????
  8. Tell me if this is BS
  9. synthetic oil question
  10. 1998 F150 5.4 head issues?
  11. help please
  12. How do you clean the engine?
  13. I NEED HELP making my truck loud
  14. Changing the oil
  15. Cold Air Kit Choice?
  16. NewTSB on spark plug removal
  17. Problems with an overcharging alternator
  18. 99 f250 5.4 question
  19. quick question
  20. 99 F150 Cylinder heads
  21. help on buddies 95
  22. How much hp did the pre 04 5.4 engines have?
  23. Who runs MotorCraft Syn-Blend Oil Exclusively?
  24. HELP Loud resonating noise!!!!!
  25. broken sparkplug
  26. 19000 miles and my motor is toast
  27. Quick Help: PCV one-way???
  28. wonder if i did'it right ??? timing chain
  29. Super40 Killing My Gas Mileage
  30. fox lake heads
  31. BARO sensor and MPG
  32. P0175 System Too Rich (Bank 2) ???
  33. Dtc Help!!!!!
  34. Gears... Stock to a 4.88 i think its called
  35. Intake mod for 3V 5.4?
  36. poor gas mileage
  37. Newbie welcome .....general info
  38. Is this normal
  39. need to replace egr
  40. mustang 96 cam VS. 98 f150 4.6 cam ?
  41. No.1 Cylinder?
  42. Throttle Body Spacer
  43. Lighting Motor in Ext. Cab
  44. Changing Engines In Ranger
  45. Gears question?
  46. Slow to warm up, fast to suck fuel
  47. best performance chip?
  48. Anyone used the Hypertech Max Energy E-Con?
  49. How many guys running the Brisk plug????
  50. need help installing mark vii electric fan
  51. Straight 6 to V8 Swap
  52. Possible new owner
  53. Engine vs tranny????
  54. 4.9 300 I6
  55. Bad Day, Help?!?! Fuel filters suck
  56. Belt Noise and increased Drag!! Help
  57. O2-H20-EGRsys-Evapsys-Catalyst nr ready
  58. Intermitten spark, then no spark
  59. 5.4 3V spark plug options
  60. Gears?
  61. Spinning noise?
  62. Intake Manifold
  63. trying to get my oil sending unit out
  64. Engine lossing power
  65. F150 2004 5.4 3V. 100K miles maintenance. Seafoam, MAF and Trotle body.
  66. head gasket oil leak on 97 4.6 F150
  67. oil change
  68. Help
  69. Non emissions legal motor ?
  70. #4 Cylinder Misfire
  71. SeaFoam
  72. Is this a Good Deal?
  73. Aeromotive 13102 Photo?
  74. Your Trucks MSRP?
  75. Pinging with A/C on and running Edge lvl 2
  76. 91 f 150 wnt run all the time
  77. Running Lean or Rich?!
  78. 2001 4.6l Ticking...Should I worry?
  79. i never change tranny fluid...
  80. Part Number Question
  81. Dash / Engine Tray Rattle at Higher Speeds
  82. PCV Valve
  83. truck nearly died.
  84. K&N Intakes and Filters
  85. help i - 6 300 wireing
  86. Removing intake manifold
  87. 92/302-coolant system is building pressure
  88. Gas Saving tips
  89. P0405
  90. P 0308 and P 2198 Codes after Seafoam, TB and MAF Cleaning
  91. Getting A P1405 Code
  92. 1993 F-150 302 oil pan
  93. Cost of Leaking Head Gasket
  94. 3.8L Supercharger on a 4.6L???
  95. Dyno #'s
  96. Loud Humming Sound
  97. Do I have the PI heads.
  98. No cats, P0420 & P0136
  99. looose distributor cap??
  100. Question for lenore
  101. help with lost oil
  102. Oil Filters There is a Difference
  103. roller rocker stud size
  104. Engine Swap - 4.6L to 351ci (5.7L)
  105. 98 F150 5.4 Tune-Up - 110,000 miles
  106. Intermittent Start Problem - W/C start
  107. First Ford truck!!! Advice?
  108. Coolant leak, HELP............
  109. Ford Premium Injector Cleaner (FPN#: PM6)
  110. 5.4liter 3valve oil requirements
  111. roller rockers
  112. air bag light after amp install
  113. System to Lean??? Help!!!
  114. porn ads on left side of forum, also sound
  115. spark plugs?
  116. Wont start HELP!
  117. 5.4 engine rebuild help!
  118. sound like a tractor trailer
  119. She had the nicest set of........
  120. Engine restore
  121. Sick of engine studder!!!
  122. What else to do to get more RWTQ?
  123. HELP!! 4.9L to a v8 swap!!!
  124. Strange Overheating!
  125. Truck Bucks On Acceleration
  126. Gruling... 04 5.4 sparkplug question
  127. another P1131 help needed bad
  128. Chipping a High Milage Truck
  129. oil sending unit
  130. car wont run
  131. Is this true?
  132. Ughh.. another problem.
  133. Erratic idle followed by shut down
  134. Tps
  135. 04 3V 5.4 plug change
  136. Oil Leak, Fix it or Skip it
  137. Help with high idle. 01 5.4 supercrew
  138. Spark Plug Torque
  139. Cleaning to correct egr problem, need advise..
  140. 5.4L differance between years
  141. 2k 150 4.6 very laggy throtle responce
  142. Changed Plugs, now misfire on cyl 3+4
  143. VIN question
  144. eating oil
  145. Spark plugs stuck
  146. Fuel addatives
  147. whistlen a tune
  148. Will opening up Intake on PI heads lose TQ?
  149. Pressure coming out around gas cap
  150. Obdii Scanner's
  151. Grinding noise
  152. Transmission won't seperate from engine
  153. Recommended Oil type for 2007 F150
  154. Annoying, but not life-threatening (hopefully). Help?
  155. wet msd coil
  156. Number 4 coil keeps going out...
  157. Engine squeal
  158. lightning tuner needed
  159. Cleaning MAF
  160. Lack of power! NHSTA Recall #15932
  161. Spark Plug part nums '99 4.6 w/plug wires
  162. low vacuum, rich condition 5.8 efi
  163. This is becoming annoying
  164. gasket kit for my build
  165. *Poll* What octane GAS 87/89/91/93
  166. Need Help! Cylinder 6 misfire! 5.4L
  167. Noise after truck turns off
  168. compression ?
  169. P0141 heater circuit malfunction
  170. stripped spark plug hole
  171. ford engine guys>help??
  172. 04 F150 FIPK just installed CHECK ENG HELP
  173. Iac?
  174. Timing pointer
  175. high rpm sound
  176. manifold
  177. manifold
  178. HELLPPP!!!!!! F150 5.4L Cyclinder 4 Misfire
  179. Changing oil pressure sensor
  180. Water in COL for Cylinder 4
  181. Plz Help
  182. 04 up plug porcelin removal?
  183. accel coil packs?
  184. '02 4.2L hesitation
  185. Nowhere else to put this???
  186. Antifreeze..
  187. Just replaced Injectors
  188. I finally cleaned my TB!!!
  189. Need Help Please 1998 F150 4.2 engine
  190. sputtering
  191. throttle body spacer?
  192. Throwing code P0232.
  193. Location of fuel pressure regulator ?????
  194. 1000 rpm idle, and it jumps up and down???
  195. Need Help Code 171- 174
  196. I found a turbo diesel in an F-150
  197. Burping Sound in intake tube?
  198. troyer ignition upgrade vs.motorcraft
  199. PCV Removal
  200. 1997 4.2L Misfire
  201. 1990 F150 6in lift 35 ground hawg, 302V8
  202. Help!!! Spark Plug Stuck Or Cross-threaded!!!
  203. Locking gas caps for a 2000
  204. Buy 5w-20 in bulk?
  205. 4.6L Ignition
  206. PI Heads Swap
  207. 4.6 L upgrades
  208. Engine Skipping
  209. 2v to 3v 4.6 head swap
  210. Bigger fuel injectors w/ 4.9L?
  211. Oil Has Changed
  212. know of any injection compatible fuel cells
  213. Synthetic fact or fiction
  214. why change the coils?
  215. Successful 5.4L Plug Change - 1999 90K miles
  216. engine codes bad gas miliage
  217. Romeo or Windsor
  218. 4.6 2600rpm change
  219. Mobil clean 5000
  220. Intake coolant leak
  221. ticking sound
  222. oil....
  223. Does a K&N series 77 intake make my 5.4 run lean?
  224. Spark Plugs and wires
  225. 1991 f-150 runs fine then sometimes won't run at all
  226. 98 f150 help!!!!
  227. 90 deg oil filter adapter
  228. Wtf??
  229. plug change now missssssssssssssss????
  230. Harder to start in the morning.
  231. Gas Mileage
  232. Diagnosis/Remedy from Ford dealer sound right?
  233. remove check engne light
  234. aluminum shreddings in the engine
  235. Dual Oil Filters??
  236. Truck shuttering
  237. fuel sending unit Please Help new one reads E
  238. 4.2 v6 engine swap
  239. major hesitation
  240. how many 05 5.4L have had injector problems??
  241. 2000 F150 4.6
  242. 60,000 mile tune-up
  243. 5.4L supercrew kingranch gas mileage?
  244. Throttle Body Spacer
  245. What's up w/ the Powerstroke
  246. high mileage oil
  247. New to F150
  248. What's the best tuner or chip for 2006 5.4....
  249. Hard to start and P0301 and P0316
  250. spark plug change 2002 4.2 v6
