Engine Codes
Old Jul 30, 2014 | 03:01 AM
Ford4Life91's Avatar
Engine Codes
My 2000 F150 XLT is throwing codes P0443(Evaporative Emmission System Purge Control Valve Circuit) P1747(Engine Speed Desired signal out of range 2. Pressure Control Solenoid a Short Circuit. P0755 Shift Solenoid B. P0743( Torque Converter Clutch Solenoid Circuit Electrical. P1451 (Evaporative Emmission System Vent Control Circuit. P0135( O2 Heater Circuit Bank 1, Sensor 1. P0155( O2 Heater Circuit Bank 2, Sensor 1. P1409 EGR Vacuum Regulator Solenoid Circuit. P0141( O2 Heater Circuit Bank 1, Sensor 2. P0161( O2 Heater Circuit Bank 2, Sensor 2. I have replaced the EGR valve and this has still not helped. The engine is not running smoothly. You can push the fuel petal down and it will choke the engine down and almost die. My O/D light is also flashing. Any help will be greatly appreciated!!
Old Jul 30, 2014 | 06:47 AM
With that many codes, start checking fuses.
Old Jul 30, 2014 | 08:43 AM
projectSHO89's Avatar
Fuse F23 under the hood.
