- May need new exhaust manifold.. what is a header?!
- ordered my parts 1 hour ago
- 1986 F-150 dies when under load
- swapping out a 302 to a 460
- putting a piston in
- E3 Spark Plugs In 5.4
- throttle body spacer/k and n airfilter
- i need a timing code for a 04 f150
- How to Convert 06 Non-FFV to E85?
- Intake problem, please help
- Water in gas tank
- COP's
- WHich K&N cold air intake?
- intake ?
- Another spark plug question.
- summer gas in NJ?
- Lightning swap
- blue smoke after idling
- F150 5.4 noisy at start/ sounds like diesel
- oil question
- Anybody use the tornado fuel saver?
- Smoke at start up
- SeaFoam
- Idle
- oil in radiator 5.4 97 f150
- stock numbers
- Studders only on first start of the day.
- Anyone running the Volant Powercore CAI yet?
- New Tune...Stalls
- Royal Purple oil change
- Anyone have info about E3 spark plugs?
- Decided to sell my dirtbike
- 1998 F150 False Temperature Reading
- Trouble starting when hot?
- 2002 5.4L rough idle & hesitation
- SeaFoamed.. No Smoke?!
- o2 senor simulater
- O2 Sensor change dissaster, and TB miracle
- Dead Battery?
- 2011 6.7 Liter Ford Scorpion Diesel!
- Help with DPFE SENSOR
- Doin it again... rumble rumble
- Fram Orange Filter
- Bad news from the dealer
- New engine-sgl cyl- 900HP
- Gas Question/Discussion.....
- this noise is killing me
- very rough 4.6l 1999 f150
- 95 owner w/ some questions
- F-150 Hybrid Upgrade
- 2004+ 5.4L 3V triton DPFE location?
- truck over heating?
- 94 lightning motor swap to 4x4 95 f150
- Idle RPM 07 5.4
- Optima battery mount
- How to find a good perfomance tech in GA?
- Is this an easy install?
- 5.4 2WD Average Mpg
- 97 f150
- tranny
- procharged lightning ! ! !
- Lousy Fuel Filter Line Design
- Motor started to knock
- P0304 on 97 Expy 4.6 w/209k miles
- Code PFFFF, Please Help
- 4.9 in-line 6 ??????
- Aftermarket heads for a 5.4 and other upgrades?
- Which Tow Package do I have?
- New guy with a common problem.
- 2001 F150 starting issue need advice
- They Came!
- help please!
- Mechanic in Hayward Ca?
- fuel leak broken fule line were?
- Pats Keys/ Locating A Good Garage
- 4.6 Swap
- Radiator problems
- yay zero oil psi
- I think I own the devil
- What is up with Troyer!?!?
- Oil Cooler Lines
- Help Please - Tension Pulley
- 98 F150 5.4,,,P0174 Code, sorry 4 new thread
- Woo Hoo! 18 mpgs today!
- 5.4 lightning motor
- will this fit a 99 (mass air flow sensor)
- help with 302
- oil pump
- Will plugs that are colder then stock make my truck idle rougher...
- cooling fan size
- rough idle, no power
- Summit Racing Cops 3 valve
- Timing Change Swap on '04 f150
- engine misfire - I think
- oil pump
- Fuel flowing upstream
- New TSB + Dealer Plug Change?
- Is it ok to get rid of IAC plastic thing?
- Changed plugs, did the coolant mod...
- Temp. guage quit working
- Quick PCM connector question ('04+)
- Buzzing sound
- gas in oil
- Prestone coolant/flush?
- Idle adjustment 4.6.V8
- Protecting Radiator?
- Radiator Electrolosys (sp?) God &$%# Electric Fans
- Which plugs for the change today?
- 06 5.4 3v plug change
- hey i have no problems just love my 1997 f150
- Dealer left cap off power steering res!
- IMTV or IMRC actuator 4.6SOHC swap to DOHC
- head swap
- 99 5.4 skipping
- Coolant sending unit location on 2002 5.4?
- Torque specs for head gasket and rocker arms
- Mass air flow sensor check engine light
- p0401 and p0402
- Summer project...460 ranger :)
- Redline
- serpentine belt, better than oem?
- I also fell victim...I spit a plug today
- 100K Plug Change
- 7.3 and 5.8
- need some help guys
- What's a JIC fitting??
- Side exhaust
- 99 f150 super cab 5.4 MPG?
- Head gasket toast??
- Changing Just the Oil Filter
- 5.4 Supercrew vs. 5.4 Expedition
- 04' Ford F150 - High-Pitched Sound
- hesitation
- Bank 1 rich , bank 2 lean show at same time
- this weekend st.louis
- Best Heads To Put On A 5.3?????
- Where to get Timesert?
- Need help diagnosing engine idle/ revving problem
- 5.4 into 4.6 truck swap???
- A LOT of DTC's...
- Need to cut stainless steel bolts - air tool or electric
- IAC question
- 4.9 straight 6
- Ticking Engine Noise
- Hydrigen generator boost kits?
- Misfire?
- P0119 - Intermittent Coolant Sensor
- Replaced DPFE now new Fn CODE!!
- Truck wont crank. Fuel pump?
- Removing mechanical engine fan
- Need a little Help.
- Succesfully put an 02 Police Interceptor engine in 00 F150
- High mileage engine
- HELP! Romeo 4.6 vs. Windsor 4.6
- Software question
- Need help
- oil filter? metric or standard thread?
- engine swap
- Changed pass side exhaust manifold gasket Saturday
- Broken starter positive cable
- nedd some help
- PCV assembly replacement
- Temp gauge/senor issue, need advise please
- Coil and plug change
- Settle an argument: Which can make more HP? 3v 5.4 or the old 2v 5.4
- Brother Messed Up
- Throttle Body Hoses Leaking
- Got Em!
- whistle sound
- Extreme vibration at 75+ mph
- oils
- What else?
- Lost Ignition Key
- truck shakes
- more power for less $$$
- coolant leak
- New F series F-16 I found
- F150 vs Tundra
- Blown Engine
- truck uses oil
- 4.6 rebuild
- Building another 4.6 Windsor or romeo
- Dipstick won't go back in!?
- 2001 F150 Screw coolant flush / thermostat replacement
- price to pull and replace engine
- oil pressure dropped engine stopped
- P0401 and P0402
- Annoying miss at around 1700 rpm
- Annoying knocking
- 97 f150, 4.6 keeps killing in parking lots
- Oil Preasure Problem
- 99 5.4 engine tapping
- ID Crankshaft
- altenator problum
- Rough Idle
- Moron needs step-by-step tune-up guidance ('02 4.2)
- Coil Quad Pack misfires or Transmission shudder?
- Water Pump
- Metal grinding noise when accelerating
- hesitation at at 35 to 50mph
- Changing oil pump
- Underdrive pulleys
- $250 Per Cylinder!!
- 99 f150 NO START & Wont Shift out of 4-lo please help!
- First visit and question
- 5.0 to 5.8 swap
- IAC ? where is it ?
- dtc P0302 engine has a miss
- #8 misfire on my 02 4.6L
- 97 4.6 to 01 5.4
- Oil Filter and rough running engine/sloppy idle
- New cap and rotor sounds like exhaust leak
- 'New' 5.4 3V, should I pull the plugs?
- 98 F150 V-8 5.4 won't start
- Emergency Help Firing Order 4.9 I6
- help with misfire
- Power Steering working or not woorking ?
- engine swap
- full synthetic oil
- Lucas Oil
- changing fuel filter
- Performance Parts
- Air kits which is better?
- E85 Ethanol
- HELP! I'm losing oil and not sure where?
- power steering fluid for 04 lightning
- v8 5.0 improvements
- Plug Spitting Issue
- What is p0074 code
- 460 big block timing cover blew off
- Better Camshaft for a 4.9L?
- Finally fixed
- any one know cel codes
- pulled codes-egr flow insufficient
- 460 into 94 f150?
- do i have the spark plug problem?
- 4.6 engine upgrade advice
- shaking at 1100& 1600 rpms
- 460 big block into 94 f150
- Improve Gas mileage?
- powercharge sc 3900.00 msrp
- battery level fine, engine wont turn, clicks
- 99 f150/250 engine swap
- How many gaskets?
- exhaust leak
- Is your Oil Black after 3000 miles?
- Fl 400s Vs. Fl 820s?
- 2005 cadillac escalade vs. my 02 f150
- throttle body?.......cold air intake?....flowmasters?
- Ok need help, engine chugging/roughness.
