Brypink...Question About Zapco Amp
Old 04-22-2006, 10:13 AM
brypink2's Avatar
Originally Posted by GA FOO 88
Sorry i didnt mean to rule out a sealed box for the RL-ps, its just the concensus on sounds solutions in the SS forum was that they thrive in ported boxes. Anyways check out the DIYMAS for real, www.diymobileaudio.com, and click on the shop tab. (.5 to .75 sealed rec box for a 12 )
So, I looked at this sub...looks nice, I might have to give it a try.
  #122
Old 04-23-2006, 11:40 AM
Bartak1's Avatar
Originally Posted by brypink2
Bart...why the 8053? Nice HU though.
Higher end kick **** SQ HU that I can get CHEAP-couldnt pass it up. I dont need anything with a screen and navigation and all that stuff.
1/2 is like borderline ok/not ok Id say. Im not exactley sure how that would work out. I try to get at least 1" between the sub and the box like you guys too.
I will try to get that measurment for you in awhile. Ill tell you right now though, I have 2 1/4 inches between the bottom of my box and the floor, and I think thats about the minimum you would want to go, just to give you an idea. Once some power gets on it probably more, because this thing isnt moving close to what I know it can.
  #123
Old 04-23-2006, 11:57 AM
brypink2's Avatar
I had an 8051 a while back...loved it. But, you know me...always changing out.
2 1/4" is about all the room I can give the MAGs...if I go that route. Did you check out the diymas that ga foo posted. They look pretty nice...I got the pre order code and might order a couple...only $150 each.
  #124
Old 04-23-2006, 12:31 PM
Bartak1's Avatar
Those DIYMA's do look somewhat impressive. I say you should grab one or two and let us know what they are like.
Should easily fit under the seat.
On a different note, I cant find any darn D5's. I think I need to start looking for something more available. Anyone have any ideas on some nice cheaper (300ish or under) amps that do 150ishx2 and 1000ishx1. A lot of ish's there.
  #125
Old 04-23-2006, 01:01 PM
brypink2's Avatar
Yeah, I'm thinking about it...pretty good deal @ $150 a piece.
Amps...did I mention Zapco make some nice amps? LOL
  #126
Old 04-23-2006, 01:13 PM
Bartak1's Avatar
Also borderline expensive.
If I could find a cheap 750.2 and 350.2 or something along those lines, Id probably go for it.
  #127
Old 04-23-2006, 01:14 PM
Bartak1's Avatar
Oh yeah------Buy the subs
  #128
Old 04-23-2006, 05:39 PM
Bartak1's Avatar
Just got in from measuring that. Its 1 1/8 inches from the box to the tallest part of the surround. So I guess 2 1/4 would work ok, but ideally Id at least try to get 3 inches, if not more, between the box and the floor.
  #129
Old 04-23-2006, 10:44 PM
GA FOO 88's Avatar
Yeah I would love to have 2 DIYMAS, but i might have plans for something else that is mighty tempting.
  #130
Old 04-24-2006, 01:44 PM
dconder's Avatar
Woohoo....LMI seat lift kit arrived today.
Bryan, is it best to take the seat back off to install the kit? Since you have already done it, I just want to make it as umcomplicated as possible.
This is a good looking kit by the way. Nice finish on all the parts.
  #131
Old 04-24-2006, 04:02 PM
brypink2's Avatar
Thanks...I don't think I can get 3" of clearance and still get the MAGs to fit. Might just try those diymas...or the 12W6v2s.
Yeah, take the seat back out too. You will need to get to that seat bracket/bar on the floor. The lift does look nice, but I wish the fit was a little better. It works great though. I'm trying to remember everything I did different so I can help you better. Do you have your PM's enabled? If so, I'll PM you my cell number in case you have a question or something.
Thanks FOO...good find. I lurk on that site a little but didn't pay attention to that sub. It looks pretty nice.
  #132
Old 04-24-2006, 05:18 PM
dconder's Avatar
Thanks for that. I sent you a pm. Nothing looks too scary but, just in case.
  #133
Old 04-24-2006, 06:31 PM
brypink2's Avatar
Responded.
  #134
Old 04-25-2006, 03:22 PM
dconder's Avatar
I just finished up installing the seat lift kit. No big surprises. Just a couple of snags. The passengers side rear bolt, the very long one, was locktited and was a royal pain to get that thing out. I made sure and scrubbed it down good to put it back in. I did not have a 50mm torx bit and used a 1/4 allen wrench. All the bolts came out except the one under the passengers side seat front. I almost ruined it and had to run and get a 50mm at the parts store. I almost thought I had done it all for nothing because that bolt would not move but, finally I got it. As Bryan pointed out, the fit is not perfect. I had to use washers on the rear mounts on both sides but, the directions said I may need to. Also, there were no washers at all in the kit and I added some here and there. A few places would be hard to tighten down good without some large washers. I also used some longer bolts for the pivot arm mounting bracket. The ones they sent were not going to work with mine. Too short. Overall, the kit looks good and was not very difficult to install. Be advised, you loose a lot of headroom. The leg room is still very good but, when I sit in the back seat, I maybe have an inch to the headliner. Be careful over those big bumps with someone tall in the back.
Now, the planning stage starts. I still need to get the Arc 12" sub from the Mustang and start cutting some wood.
  #135
Old 04-25-2006, 05:51 PM
Bartak1's Avatar
So how much mounting depth can you get under there now for that sub? What are you looking to get for airspace too?
Quick Reply: Brypink...Question About Zapco Amp
