Ecoboost F-150 Confirmed !
Old Apr 15, 2010 | 12:03 PM
  #61
mete's Avatar
The Flex EB manual says designed for 87 octane but for max performance [towing , high altitude] use 91 or higher octane.
Old Apr 15, 2010 | 12:06 PM
  #62
Turbo or not, the knock sensor will keep the timing under control to prevent detonation. Premium may be recommended, and it will run better and get better mileage on it, but using regular won't damage it.
Old Apr 15, 2010 | 12:59 PM
  #63
Burncycle's Avatar
Also, if it ends up recommending 91+ then you are just asking for carbon buildup by running 87.
Old Apr 15, 2010 | 02:44 PM
  #64
fordmantpw's Avatar
Originally Posted by SoonerTruck
Pig9r, I will disagree on both points. First, I will bet that premium fuel is required, not requiring it on a turbo'd engine is just a hole in a piston waiting to happen. So you buy 30 gallons of premium which is normally about $0.20 more expensive than regular unleaded, you just spend 6 bucks more. (basically 2 gallons of gas). If the regular engine gets 20mpg hwy and the EB v6 gets even 22mpg you have more than broken even on the 2 gallons of gas you bought.
Second, the compression ratio has little to do with how long the engine lasts since it's usually not much more than a 1-point difference. Say an NA engine is at 9.5:1, the Turbo isn't likely to be below 8.5:1, not a real difference maker. The thing that KILLS engines is heat, and turbos produce A LOT of it. That combined with much higher compression ratios while under boost, will definitely wear faster on the rotating assemblies than the NA engine will.
The EB engines DO NOT require premium fuel in the Taurus/Flex/MKT/MKS and will NOT require premium in the trucks. It's just not Ford's way of doing things. They use direct injection to avoid the need for premium.
The engines do produce more power on premium, but it is not required.
Old Apr 15, 2010 | 03:56 PM
  #65
Raptor05121's Avatar
When I get out of college, the EB F-150 will be the first thing I buy
Old Apr 15, 2010 | 04:01 PM
  #66
Power Kid's Avatar
Originally Posted by Dunesgirl
As rumors have it now, the 5.0L will be the standard engine with the EB being a "premium" offering as well as the 6.2L in some models.
The added price of the EB over the 5.0L was rumored to be about $700 or the about the same price as opting for the 5.4L over the 4.6L.
You are quite correct.
But I think the $700 was Fords "cost", not retail.
With the 6.2L being @ $3,000 premium over 5.4L. I'd expect it to go like this:
Base: 3.5 or 3.7L V6
Upgade/Base in some: 5.0L 365/375
Upgrade: 3.5L EB + $1,500 400/410
Upgrade in some: 6.2L $3,000 400/+400
The rwd EB at SEMA has 400/400. I recently quoted Ford rep sying EB in F150 could have more than 400 ft/lbs tq. Hard to believe they'd achieve that AND get best in class MPG. But the fine print... best n class mpg vs Gm 5.3L or the GM 6.2l or "unstopable" Turd 5.7? (for example)
(re 6.2L #: Will F150 6.2L have Raptor or SD Cam? It will have efan of Raptor and 150s rated diff than SD so hard to say what exact #s will be)
Old Apr 15, 2010 | 04:09 PM
  #67
boomer08's Avatar
Originally Posted by RayD
The current versions of the 3.5 EB are making peak torque by about 1500 rpm. Not sure where you got the idea that it has to be revved to make power. And the turbos aren't an "addition" to this engine. It was built for boost from the ground up.
Only time will tell but it's a safe bet that Ford did their homework.
I hope they did there homework better on this EB engine than they did with the plugs on the 5.4.
Old Apr 15, 2010 | 04:19 PM
  #68
SoonerTruck's Avatar
Not Ford's way of doing things? My '91 Taurus SHO required premium fuel. I had not seen any specs on the fuel req'd for the EB so I was speculating based on the other turbod/sc'd vehicles I've owned. I'm still not sure I'd want to run 87 with the EB. Knock sensors are great at low rpm's, but on many vehicles I know of, the knock sensor is ignored once you get to around 2500-3000 rpm because it can't discern between engine noise and engine knock. I wouldn't want to rely on it when the engine is at it's most likely area to detonate. (High load, high boost, mid+ rpms)
Who knows though, maybe the direct injection allows the use of lower octane fuel even with the turbos. Edit: I just saw where you mentioned this, FordMan.
Second thought though: If/When people start modding/upping the boost on these engines, I gaurantee you'll want to move up to premium.
Old Apr 15, 2010 | 04:30 PM
  #69
Power Kid's Avatar
What the heck does your '91 Taurus have to do with the EB? Its 2010!!!!!!!!!! My 82 turbo Stang didn't have EFI either but that doesn't mean the EB is carbed too.
Things change. The EB #s are based on reg fuel.
Old Apr 15, 2010 | 04:49 PM
  #70
That's only partially correct. Most high octane fuels have more additives than low octane fuels but just the octane has nothing to do with carbon buildup. I also disagree with all the people around here that say that running high octane in an engine designed and tuned for low octane will have problems. That just isn't so either. The knock sensor will actually allow more timing advance, and it will run better and get better gas mileage. Will you actually notice the difference? Maybe, maybe not. I certainly can tell the difference when I put 93 in my truck, but I can't justify the extra expense to do it very often.
Old Apr 15, 2010 | 04:57 PM
  #71
Power Kid's Avatar
What we NEED is for Ford to line up three identical '11 F150 SCrews. One with EB, one with 5.0L, one with 6.2L. Line em up and go: - empty, - with a loaded trailer, - and one empty 500 mile interstate run for MPG. After we see that, we can pick which we prefer, and none of this other stuff would matter... AMEN.
(oh and include a 2010 with a 5.4L so we know how relative the #s are.)
Old Apr 15, 2010 | 04:58 PM
  #72
Burncycle's Avatar
I have never had a problem running high in a low spec vehicle, but have been give quite a few problems running low in a high spec with some of my 90s and early 2000 vehicles. Carbon buildup, pre detonation, decreased power etc... How about everyone just do what the manual says to do when it comes out
Old Apr 15, 2010 | 07:19 PM
  #73
desratt's Avatar
I don't think the hp will be higher in the truck then the taurus.. I am actually thinking the 5.0 will be higher in hp then the eb...
Old Apr 15, 2010 | 07:46 PM
  #74
Power Kid's Avatar
Nope. Ford has said many times, the EB will be premium offering OVER the 5.0L.
Old Apr 15, 2010 | 09:39 PM
  #75
fordmantpw's Avatar
Maybe we can get pickuptrucks.com to do that for us!
Mike Levine, are you listening???
