Ecoboost F-150 Confirmed !
Only time will tell but it's a safe bet that Ford did their homework.
The added price of the EB over the 5.0L was rumored to be about $700 or the about the same price as opting for the 5.4L over the 4.6L.
yup, ONLY reason i got a 6, just HAD to have a stick. getting a V6 was the price i had to pay, but i would not want a 2v 4.6 anyways. if they had a manual on either 3V, then id go for it but it would still have to be 2wd for me.
The current versions of the 3.5 EB are making peak torque by about 1500 rpm. Not sure where you got the idea that it has to be revved to make power. And the turbos aren't an "addition" to this engine. It was built for boost from the ground up.
Anyone know if the EB in the F150 is going to require premium fuel? If so then any fuel $avings will likely be a wash.
As far as reliablity, turbo charged gas engines are just as (or more) durable than N/A gas engines because they are lower compression. My cousin has a twin turbo Audi with over 250K on the engine and turbos.
It's not fun for me to have to shift from the dash to the back seat when the shifter throw is so long. I also just don't enjoy shifting for the purpose of shifting. I like to have control over the gear choice when I'm ging through corners or trying to eek out every rpm in a certain gear, I really don't care to shift in any vehicle that I'm just casually driving in. If they want to put in a paddle-shift or similar mechanism I'm fine with it, but I just don't see the advantage over having the 6-spd auto.
If the F-150 required premium I don't think they would sell very many.
There's no reason that a turbo has to have premium .I have seen listings of turbos taking regular but I can't remember which ones.
Second, the compression ratio has little to do with how long the engine lasts since it's usually not much more than a 1-point difference. Say an NA engine is at 9.5:1, the Turbo isn't likely to be below 8.5:1, not a real difference maker. The thing that KILLS engines is heat, and turbos produce A LOT of it. That combined with much higher compression ratios while under boost, will definitely wear faster on the rotating assemblies than the NA engine will.
