Project BULLETPROOF...dream or reality?
Old Mar 29, 2008 | 07:31 PM
  #181
joshmac4.6's Avatar
I've got a ? for ya neal, since you eliminated the dual plane setup of the factory manifold, did you leave the IMTV in or remove it?
Old Mar 29, 2008 | 08:25 PM
  #182
JMC's Avatar
JMC
25 Year Member
The 99 5.4 doesn't have one.
Regards
Jean Marc Chartier
Old Mar 29, 2008 | 09:15 PM
  #183
Neal's Avatar
Cool
HI!... My 5.4 didn't have one.
Old Mar 29, 2008 | 11:45 PM
  #184
Jackal's Avatar
I think the IMTV is a 4.6 thing.
Neal, do you thread chase with an old head bolt or each of the new ones?
Old Mar 29, 2008 | 11:48 PM
  #185
Veteran: Army
Originally Posted by Neal
HI!... This is the restriction I removed :
would that be a possible modification on a composite intake????
Old Mar 30, 2008 | 12:29 AM
  #186
jbrew's Avatar
WHAT!?!?
Well, not sure what Neal uses - Here's what I use,
A "dead end"(no taper) tap/small port cleaning wire/or course bristle brush/compressed air.
BTW - It's a good idea to run the new bolts (headers only/not head bolts) about 3 or 4 threads in and then remove by hand. That way when you install the part; the bolts will start in correctly. This will decrease the chances of cross threading which is easy to do in these aluminum heads.
About removing the divider in the intake manifold. I've read that doing this decreases torque and hurts the low end. When I polished mine, I was going to do the same thing but I value torque over high end HP, so I opted out.
Good Luck
Old Mar 30, 2008 | 12:38 AM
  #187
Jackal's Avatar
Neal, I actually considered the shop vac, and decided I didn't want to nasty it up. Guess that would work best though.
I wanted to remove the dual plane section on the top side there, but it's so deep can't get it with my Dremel, even with flex attachment. I need some real tools.
Don't mind the red tint...it's from the the blanket underneath.
Driver side:
Pass. side:
Old Mar 30, 2008 | 12:45 AM
  #188
Jackal's Avatar
What's with all the carbon? It's worse than it looks. I haven't used Seafoam in 20k miles...maybe that would help.
Old Mar 30, 2008 | 01:06 AM
  #189
Jackal's Avatar
A shot of the old plugs:
Old Mar 30, 2008 | 01:10 AM
  #190
Jackal's Avatar
jbrew, I'm doing ALL of this by hand.
Old Mar 30, 2008 | 02:16 AM
  #191
jbrew's Avatar
Well, I didn't think you were using you feet
I did mine by hand + necessary tools needed. Are you referring to machining maybe?
Is it just me or do those plugs have some serious gappage.
OH!! Nevermind - You made a funny(ie-"by hand" comment) ; I just caught that
Old Mar 30, 2008 | 03:07 AM
  #192
Neal's Avatar
Cool
HI!... There are thread chasing taps out there. Some local machine shops will lend them (rent) to you.
No offence but you seem to have the engine stripped down quite a bit. Why not just go all the way and pull the engine and build it up on a engine stand. It would be so much faster and easier. The way it sits now I could have that out of your truck in like 20 minutes.
Old Mar 30, 2008 | 12:14 PM
  #193
Jackal's Avatar
No stand, etc.
The plugs were gapped at .054 and still read that within .001. Think it just looks that way because of the super tiny electrode...??? Out of the box they run about .038 - .040
Old Mar 30, 2008 | 12:30 PM
  #194
ONELOWF's Avatar
Good one brew.
I agree with Neal. I did the top end of my engine in the truck, and my ribs still hurt after nearly a year.
Old Mar 30, 2008 | 07:41 PM
  #195
Jackal's Avatar
Yea, my ribs are bruised all to hell. Noticed the pass. side head was beat all to shat from the stealership's attempt to remedy this years ago. Hopefully they can still be used.
Headers don't fit on the pass. side, but I see no reason why I can't go ahead and bolt the driver's side to the head before dropping it back in. I'm taking the exhaust parts to the welder tomorrow to see what he can do to move some tubes.
