Project BULLETPROOF...dream or reality?
Old Apr 3, 2008 | 11:37 AM
  #241
Jackal's Avatar
http://forums.modulardepot.com/showthread.php?t=96044
Looks like the swirl dams are a good thing in NA 4.6's. Guess I need to cancel the removal if it's not too late.
Just called Patriot and they said they always remove them, NA or boosted. Hmmmmm...
Old Apr 3, 2008 | 11:41 AM
  #242
Jackal's Avatar
Originally Posted by jbrew
Doesn't say a damn thing on the DVD's - just gives you an illustration -
Damn! Are those even the Head bolts? Doesn't look like it. Iduno; like I said before - Never had the heads off her.
BTW - That was a b^tch stealing this diagram off the DVD - The things I had to do to get her here
Those are the ladder cam girdles in the Romeo heads.
Old Apr 3, 2008 | 11:45 AM
  #243
jbrew's Avatar
They have the exact same illustration under the Windsor 5.4L - Identical. Well that sucks - I have one more I can try..
Old Apr 3, 2008 | 11:53 AM
  #244
jbrew's Avatar
This DVD has it right - is this what you have on yours. I have the pics that shows the different sequences at each stage. I'll upload them if you need them.
NOTE: Make sure to tighten the bolts in sequence in three stages.
Tighten the LH bolts in the sequence shown.
Stage 1: Tighten to 40 Nm (30 lb-ft).
Stage 2: Tighten an additional 90 degrees.
Stage 3: Tighten an additional 90 degrees.
RH cylinder head
NOTE: Make sure to tighten the bolts in the following three stages.
Tighten the RH bolts in the sequence shown.
All cylinder heads
Old Apr 3, 2008 | 12:16 PM
  #245
Jackal's Avatar
Yup, same thing. I don't need them, but appreciate your help as always.
Got the swirl damn removal cancelled. If anything, I can knock the top edge down by hand if I decide it's worth the risk of gashing a freshly surfaced head.
Old Apr 3, 2008 | 01:40 PM
  #246
JMC's Avatar
JMC
25 Year Member
Read what Cobra Killer has to say on page 2.
Regards
Jean Marc Chartier
Old Apr 3, 2008 | 02:06 PM
  #247
Jackal's Avatar
Since I don't have ported heads, cams, or a power adder...I feel more comfortable leaving the swirl dams alone.
Old Apr 3, 2008 | 02:12 PM
  #248
jbrew's Avatar
90 degrees = 1/4 turn .. I would just judge that myself. You could just mark Deep well if you wanted or even mark the bolts themselves to tweak them .25 x 2.
Old Apr 3, 2008 | 04:01 PM
  #249
Jackal's Avatar
More info on the swirl dams:
http://www.modularrevolution.com/for...ead.php?t=1272
Old Apr 3, 2008 | 04:12 PM
  #250
joshmac4.6's Avatar
Very interesting, great find
Old Apr 3, 2008 | 05:27 PM
  #251
JMC's Avatar
JMC
25 Year Member
I wonder if Fox lake and Patriot will modify their design?
Regards
Jean Marc Chartier
Old Apr 3, 2008 | 06:15 PM
  #252
JMC's Avatar
JMC
25 Year Member
I just did some checking. nickmckinney's Numbers are;
0.1 51.7/41
0.2 94.7/80.2
0.3 136.3/115.7
0.4 168/145.9
0.5 188.4/160.7
0.55 197.5/164.3
0.6 204.7/165.3
FOX LAKE claims 200/182 @0.55 for Stage 1 and 223/195 @0.55 for their stage 2. So I think Fox Lake has better flow. Now I can no longer be sure if Fox Lake takes off the Swirl Dam.
Regards
Jean Marc Chartier
Old Apr 3, 2008 | 06:24 PM
  #253
JMC's Avatar
JMC
25 Year Member
Now I just checked Patriot and they Flow 217/189 @0.55 with their Stage II and
227/196 @0.55 for their Stage III. BTW their Combustion Chamber is 46cc.
Regards
Jean Marc Chartier
Old Apr 3, 2008 | 07:24 PM
  #254
Jackal's Avatar
Good info JMC. I don't know much...obviously learning, but from what I gather, high cfm's don't always equal more low - mid range torque...??? Isn't it more about velocity and atomization? Do the swirl dams have that much of an effect on cfm's?
Got a header update and pics coming up in my OBX exhaust thread.
Old Apr 3, 2008 | 07:58 PM
  #255
JMC's Avatar
JMC
25 Year Member
From what I can gather in the 3 pages of info nickmckinney claims to have gained more flow than two well known head porters. He also stated that the flow numbers that the others have used were obtained without using the intake manifold. He also stated that he was unable to use the intake manifold when he tested because of a fitting problem. So from that I deduce that he used the same method as Fox Lake and Patriot.
You have nothing to loose by leaving the Swirl Dam in place. It is much easier/cheaper to remove it later than replace the entire head.
You also have to realize that these guys are discussing the 4.6. The extra stroke of the 5.4 dramatically changes the flow requirements of the heads. Try this. Get two syringes of different lengths. Pull the short one so it sucks up some water out of a cup. Then take the longer one and do the same. You will notice that the longer one is harder to pull and you pull it slower even though you are pulling with the same force. Now realize this. At 5500 rpm the longer syringe is pulling at a faster speed because it has a longer distance to travel. Can you imagine how much faster the water has to flow? Or in the case of an engine the air flow?
Regards
Jean Marc Chartier
