Whippled Lightning
Old Jul 10, 2005 | 10:10 PM
  #106
WaveBlaster785's Avatar
Originally Posted by l-menace
Rob,
I'm not going to get into a pissing match with you, but if the MP was putting out over 20# ... aww nevermind.
That puts my conservative street tune 435/522 on my stock block to shame.
you beat me, 15 more hp and 66 more ft/lbs.
Please explain how The pressure in the combustion chamber is going to be different? will it be cooler? will it allow you to run more timing? will the tune be different?
I'm not trying to be a smartass. I'm trying to figure out how the engine will know that it has a $3300 blower and now has to make more power ... at the same pressure that the 1/2 price magnum was making.
Is the Whipple that much more efficient and it doesn't that much parasitic power to spin it? thus freeing up horsepower, instead of actually creating more?
I'm pretty sure he was saying that cylinder pressure rises with boost, and with the Eaton and with the KB, or Whipple he would be able to make more power on LESS boost, and therefore lower cylinder pressures.
Old Jul 11, 2005 | 08:17 AM
  #107
whip's Avatar
Originally Posted by LightningTuner
Yep JJ, pretty good amount too.
Hahahaha!
Thats a good one!
Old Jul 11, 2005 | 11:58 AM
  #108
Tim Skelton's Avatar
. . . I'm trying to figure out how the engine will know that it has a $3300 blower and now has to make more power ... at the same pressure that the 1/2 price magnum was making.
It's not about boost or pressure, it's about density.
The Whipple will supply cooler air with less parasitic drag. On the KB at stock pressures, that amounts to 16 rwHP. The Whipple should be similar.
At 20 PSIG, the gap would be huge.
Old Jul 11, 2005 | 12:48 PM
  #109
31Charlie's Avatar
Originally Posted by Grimace
2 weeks.
Lol, never gets olds.
So let me get this straight. Whipple is saying I can put their blower on my completely stock '00 block and get up to 15psi of boost with out worrying about blowing the engine and gain 175 hp with out a tune. Wow.
31C
Old Jul 11, 2005 | 01:03 PM
  #110
honda hunter's Avatar
31C
September now according to another thread I read
Old Jul 11, 2005 | 02:05 PM
  #111
l-menace's Avatar
isn't pressure directly related to density, or vice versa?
Old Jul 11, 2005 | 02:15 PM
  #112
brain bypass's Avatar
pressure, temperature, and density are all related.
say you have two cannisters of air both at 100 psi. one is 100*F the other is 200*F, the one with a lower temp will have a proportionally higher density.
Old Jul 11, 2005 | 03:25 PM
  #113
Magnum Powers's Avatar
That is correct! And Sal has told me he data logged both the KB's and Mag's air charge temperature running the same boost pressure and the Mag's air charge temperature was lower by quite a bit. In other tests Sal has run a PE aginst the Mag with the Mag making 5 pounds more boost yet the Mag had the same air charge temperature as the PE with the PE running 5 pounds less boost.
Charles
Old Jul 11, 2005 | 03:32 PM
  #114
Master Of Pain's Avatar
Charles
Exactly. The more heat energy matter has, the more the excited and energetic the molecules (or atoms) are, and they will have a larger distance between them, hence lower density per volume. This rate of thermal expansion (or contraction) is fairly linear with most matter, with few exceptions (such as water-ice).
Old Jul 11, 2005 | 03:51 PM
  #115
Master, I sent you an email but I figure your mail server threw it in the trash.
How about give me a call or send me an email, I'd like to discuss something with you.
Cheers,
Charles
Old Jul 11, 2005 | 05:25 PM
  #116
Cheers,
Charles
ojref@yahoo.com is good, or ojref@oplink.net
I'll try to ring you later on today.
Old Jul 12, 2005 | 01:43 PM
  #117
KBELL's Avatar
Originally Posted by Rob_02Lightning
If there is a clear answer to what makes them run trouble free, I surely am interested in knowing it. SO, can Jim Bell "or someone" PLEASE clear this up for me, ("in laymen talk").
Are we saying only a stock air box will retain the wrrnty on a KB ???
or maybe a Airaid System too, (since it seals against the hood when closed)
Response:
Rob,
I think everyone must decide for themselves if they want their engine - supercharged or non, Kenne Bell or other, stock or modified - to suck in “cool” or “hot” air. But who can deny that ANY engine will run better, make more power and be more reliable with cooler air? I think the combination of a SEALED BOX, FENDERWELL FEED AND FRONT AUXILIARY HOSE is the best setup for a Lightning owner looking for both max cool air and air flow. The JLP kit comes closest to meeting these requirements so we recommend it and warranty kits with the JLP or the stock air box. Our customers should be aware that Kenne Bell hasn’t yet declined to warranty anyone’s supercharger because of a “hot air” kit. We have no way of knowing what kind of system our customers run, but the temperature can be determined. We ARE making an honest attempt to convince Lightning owners that COOL AIR is better than HOT AIR for any supercharger including ours. The Airaid System looks good for cool air flow but appears to lack the auxiliary air hose of the JLP kit and therefore could not supply enough air to feed your high HP Lightnings.
Jim Bell
Old Jul 12, 2005 | 01:49 PM
  #118
KBELL's Avatar
Originally Posted by WaveBlaster785
Jim, you stated that you know exactly how many blowers have locked up or failed, I for one would like to know this number. PLEASE POST THIS NUMBER SO WE CAN SEE HOW FEW HAVE FAILED.
1. Of all the Lightning superchargers sold since introduction in 12/’03, our records show 44 failures from rotor to case contact. All were warrantied. The total number sold is confidential. There have been only 4 warranties in the last 6-1/2 months. All were the “old style.” The threads you see about KB’s “locking up” are not the new redesigned case. The good news is no reported failures with the new design, so it appears we’ve solved the problem. So, I think I’ll disagree when you say we STILL have a problem.
So far if I'm on track I have a blower that cannot be spun past X RPM, isn't designed for trucks that use extremely mild cams, and cannot be used with 90% of aftermarket air induction kits. Is this correct so far?
2. Contrary to what you may have heard, we recognized the issues with the case and did, in fact, re-design it - twice. Yes, we should have got it 100% the first time, but we didn’t. For one, we screwed up and didn’t foresee the effect of the “hot air” kits. I agree, Kenne Bell may not make 90% of the inlet “hot air” kit suppliers happy, but making them love us was never one of my priorities. Instead, I must do and recommend - as any manufacturer does - what I believe to be in the best interest of Kenne Bell products and customers. To a few, it may sound like we’re making excuses, but to us, it’s both a recommendation and a warning. And I don’t care what other supercharger manufacturers recommend or don’t recommend for inlet kits. All supercharger companies list a maximum recommended rpm. Kenne Bell is not unique here - or hiding anything. To the best of my knowledge, I don’t recall us ever stating you can’t use a cam with our superchargers. We don’t care what cam - mild or hot - the customer uses. Just don’t over rev the supercharger.
You raise some other good but technically complex issues on Kenne Bell vs. Eaton cases, discharge temp, etc. that are beyond the scope of this text and probably not all that interesting to everyone. However, if you would like to discuss them further, feel free to give me a call.
Jim Bell
Old Jul 12, 2005 | 01:50 PM
  #119
Originally Posted by KBELL
Response:
Rob,
Jim Bell
The PSP kit runs two hoses, one through the fenderwell and one to the bottom of the box.
Just an FYI, I wasn't sure if you had done the research to know that someone other than JLP sells a coldair kit. Seeing as some of us are not willing to pay 185 dollars for a box and filter, 100 for a scoop, and another 20 for a lid.
  #120
Sharpshooter's Avatar
How about the PSP Fast Air kit. When moving my IAT is at ambient temperature. It has 2 "AUXILIARY HOSE's" At idle the temp does climb, but I would imagine JLP's does the same thing.
