Moved to Texas, Had to Buy a 2013 F150 King Ranch
Old Apr 1, 2014 | 09:40 AM
  #136
il_duce's Avatar
Originally Posted by UCF150
Is this what you got for a level
http://autospringcorp.com/index.php?...91a424c9657073
Also, is the x4 a major upgrade over the 3 thats worth the big price jump from used?
No, that is the complete level/lift kit. That would keep your factory rake, but raise everything 2 1/2". I went with just the 2" front spacer here: http://autospringcorp.com/index.php?...products_id=20
From what I understand, the X4 is a MAJOR upgrade over the X3. The X4 has an LED screen and other reviews I've read note that they boot and upload tunes about 3x faster. And I can definitely say it is fast at booting and loading.
Old Apr 1, 2014 | 10:18 AM
  #137
UCF150's Avatar
Wow, that is so much cheaper than I thought and yours looks great. Did you happen to get a pic w the level but your first set of wheels? Wondering if I did the level now and waited on the wheels how it would look, I have brand new tires on that came with the truck
Old Apr 1, 2014 | 10:21 AM
  #138
il_duce's Avatar
I still have the same wheels (stock). If you mean tires, then no. I put the level on 12 hours before having the new tires installed, so no pics of the level with the stock tires. You'll look fine driving around for a while without new tires. I wouldn't worry about that.
Old Apr 1, 2014 | 10:45 AM
  #139
UCF150's Avatar
Meant tires, yea...Brand new set of Dynapro Hankook on, which I like fine. As long as they look ok for the time being ill just need to find someone to install the level.
Did your brother in law do it alone or did you give him a hand? What was the install time?
Old Apr 1, 2014 | 10:51 AM
  #140
il_duce's Avatar
My brother-in-law works at an auto mechanic shop. They don't do level or lift installs or anything of that nature. He did it as a hook-up in the shop. I wasn't allowed to help him because it was during business hours on the shop floor. I watched most of the install though. He did 90% of it himself and had another guy give him a hand when needed. It took him about 1 1/2 hours. He was taking his time too.
I was prepared to do everything myself to save on install cost. But when I talked to my brother-in-law, he said he could do it for $43. It was worth that $43 to have someone else do it. I also had to get an alignment done at another shop for $59. If I was doing it, it would have been in my garage with bottle jacks and limited working space. For what it is worth, I called local places to have them quote installs. Most places wanted between $150-$300. Some places would only install the levels that they sold.
Old Apr 1, 2014 | 11:36 AM
  #141
UCF150's Avatar
Thats a great deal, I guess ill have to do some work on the phone. I knew I should of married someone who's siblings brought something to the table
Old Apr 1, 2014 | 11:58 AM
  #142
Originally Posted by 2007 Loaded FX4
Does the X4 have the ability to disable the daytime running lights?
You can just pull the fuse for those. I did on my 06
Old Apr 1, 2014 | 01:09 PM
  #143
2007 Loaded FX4's Avatar
Doesn't work on my 11', you can pull fuses for the low beam lights, which then in turn disables the DRL's , but thats kind of annoying...
Old Apr 1, 2014 | 02:06 PM
  #144
Huh, that's weird. Certainly couldn't run around with only high beams. I would think there's a sequence you can do to turn them off, but maybe not. You can turn the entry headlights, seat belt warning, etc. off on mine. And the new ones have a ton of options.
Old Apr 1, 2014 | 07:37 PM
  #145
il_duce's Avatar
Look what I found
Got them installed and working right after work today. Unfortunately, I'll have to wait until it is dark to get to see just how good they are. Until then, here is a teaser:
Old Apr 1, 2014 | 07:42 PM
  #146
F150redFx4's Avatar
Very nice
Old Apr 1, 2014 | 07:45 PM
  #147
Looking forward to seeing them!
Old Apr 1, 2014 | 09:37 PM
  #148
UCF150's Avatar
More (most likely) dumb questions incoming, I checked out the sct and it said gains were around 50HP, 100 torque. Question 1 is that noticeable and question 2 I know at one time you seemed a bit worried about warranty issues, what made you change your mind
Old Apr 1, 2014 | 09:45 PM
  #149
il_duce's Avatar
The gains are going to be based on who is writing the tunes. But I would say 50HP and 100TQ is pushing it. That would be an absolute ideal situation and definitely running 93 octane.
I was initially worried about warranty just because it was a brand new truck. I put the tires on and hoped the dealership could recalibrate the speedo (like they swore up and down they could). After they couldn't I knew I couldn't deal with the speedo and shift points being that far off. My latest switch from Diablo to custom tunes was solely based no the reviews I was reading about custom tunes and their distinct advantage over canned tunes. So I decided to make the leap. I just had this conversation on another forum and here are a few of the points that I made:
1.) Think of the amount of F150's on the road and how many have actually had powertrain warranty issues. I'd venture to guess it would be less than 5% of owners.
2.) The tune itself is HIGHLY unlikely to cause the problem by itself. The only problem would be an actual issue with the powertrain itself which could have the warranty denied just because you happen to have a tuned PCM.
3.) This is my 4th F150. I've had an '86, '05, '10, and now '13. NONE of them have had powertrain problems. My '86 is the only one I had to do maintenance on because, well I owned it from 2003-2005 and it was old.
Old Apr 1, 2014 | 09:51 PM
  #150
F150redFx4's Avatar
50 HP 100 torque sounds more like diesel engine tunes / tuners maybe ecoboost tunes would get close to that but that defiantly sounds like numbers for turbo charged or super charged motors
