Fiddy + Coyote = Patman
Old Aug 25, 2018 | 03:18 PM
  #31
ran into an issue early in the week. Put the harness on the truck just to discover i had a no start condition. traced it back to the PCM, found out I had removed a wire from the BJB to BCM that sends power to wake up the PCM. set me back about 2 hours to diagnose it and repair it. But luckily i didnt just hack up the wiring, and I've be actually depinning connectors, so the repair was super quick
got all the wiring sorted out. still may end up thinning the frame rail harness out, but for now its onto other parts of the project....
here's a few pics of the beginning stages of replacing the core support and correctly repairing the damages from the front end wreck from 2009
Ive got the engine all covered up, and started by removing the LH core support area. I've got a junkyard donor core support, RH apron and inner fender structure (upper rail) that will be installed. We will be repairing the cowl area where the hood hinge got pushed back and down into the cowling of the firewall. Stay tuned for more updates
Old Aug 26, 2018 | 01:45 PM
  #32
Veteran: Army
huge fan here
Old Aug 26, 2018 | 06:03 PM
  #33
huge fan here
thanks! that means a lot to me coming from you
Old Sep 1, 2018 | 08:39 PM
  #34
El_De_La_Lobos's Avatar
Finally letting the cat out of the bag. I've had a busy few weeks, and no where near done
Earlier this year I purchased a 2015 Gen2 Coyote and 6R80E from an F150 with 8400 miles. Took a little bit of time to get the electrics figured out, and I have a ton of time thinning out the wiring harness, but still not done
Don't you hate it when your truck is too low to get the drain pan under it....
Continuing the tear down for ease of removal
And the 4.6 is out!
Obligatory engine bay picture
By any chance still got the 4.6? Is it a Windsor or a Romeo block? If its a Windsor what year is the truck is it an 02 if it is how much for the timing cover?
Old Sep 2, 2018 | 01:21 AM
  #35
2003, I believe the engine is spoken for, not looking to part out the engine......
Old Sep 2, 2018 | 02:59 AM
  #36
I got the LH core support removed
Followed by the RH core support, inner fender, and apron
here's the cowl area that needs to be repaired
test fitting. Took us a while to get everything sitting squared up and happy
Cowl repair, and start welding RH inner fender structure to the firewall
tacking in the LH core support
I plan on doing a test fitment of fenders and hood before we finish welding everything completely, then grind welds, and paint over the welded areas
Old Sep 3, 2018 | 02:53 PM
  #37
FordGuy24's Avatar
This is crazy. Really impressive Pat.
Old Sep 4, 2018 | 11:51 PM
  #38
over the 3 day weekend I did a rough fitment of the hood and fenders to see how squared up the new core support really is....
I also started to fabricate a bracket for the transmission thermal unit. Attempting to get it to sit about the same location/angle as the factory trucks use
Old Sep 7, 2018 | 10:09 PM
  #39
ordered a bunch of parts in the last few days
6R80 shift cable and brackets
QuickCar battery relocation cables, remote cut off switch, etc etc
still have more to order, but this will get me going for now.
Next I'm planning to finalize the transmission thermal unit bracket and then I will be able to finish both sets of trans cooler hoses as well
Old Sep 8, 2018 | 11:15 PM
  #40
decided to try out a time lapse video, this represents about 45 minutes of work
pics to follow.....
Old Sep 8, 2018 | 11:41 PM
  #41
after fabrication, welded it to the truck
lots of racecar goodies
Built the cooler lines from the transmission to the thermal unit
Underside of the new lines. Used factory connections on the thermal unit, and went from 1/2" Hardline to 8AN to 3/8" braided flex hose
These are the brand new donor lines going from the thermal unit to the external cooler
Going to have to order two more fittings to get the donor lines to play nice with my external cooler
Old Sep 9, 2018 | 08:42 AM
  #42
Very nice!
Old Sep 16, 2018 | 02:31 AM
  #43
Overdue on updating. Here's the steering shaft modification process
Ground down the black 2003 shaft so it would slide inside the 2015 shaft
Really tight fitment around the exhaust manifold. Gonna have to grind the shaft to feel more comfortable with this
notching the outer layer of the heat shield
Fully welded and painted. Ready to be permanently installed
Old Sep 16, 2018 | 02:43 AM
  #44
Ran down to Summit to grab the last 8AN fittings i needed to finish the trans cooler lines up
My old cooling fans on my factory 2003 radiator
set the 2015 electric fans on top of the 2003 radiator, gonna have to cut the corners to fit and play nice. Gonna have to come up with my own mounting brackets to make it mount securely on the 2003 radiator
made some clearance modifications to the fan shroud, fit. I'll also need to modify the 2015 intake tube to get down between the engine and the fan shroud
I think the 2015 intake tube should line up with the 2003 air box...... More to come as I get to that step later on
test fitment of the upper radiator hose. I believe im gonna have to modify this to get it to fit in the same space as the fan shroud.
Really exciting to see it with the radiator, and fans. Its almost starting to look like a real engine bay again
until next time
Old Sep 24, 2018 | 10:48 PM
  #45
Got the transmission cooler mounted and lines all wrapped up
Started mounting the PCM bracket. Purchased the factory 2015 PCM firewall bracket/holder
made a template of how much I need to cut out to get the PCM to fit inside the cowl
Traced out the template
Im really starting to see my vision coming together. Engine bay is getting crowded, but its getting exciting to see it at this stage of the project
