Project GO FAST is now in progress!!!
Old Jan 13, 2008 | 01:08 AM
  #916
built54's Avatar
Originally Posted by JMC
I am sure that the built engine can withstand the revs, but is the converter able to handle it?
JMC
Its a tripple disk stall, its built to handle the rpm. Though, the plug was not obviously!
Old Jan 13, 2008 | 10:08 AM
  #917
JMC's Avatar
JMC
25 Year Member
Any sort of warranty on the converter? If you start loosing shìt like that you will need some sort of a scatter shield to keep your toes attached to your feet.
JMC
Old Jan 13, 2008 | 01:42 PM
  #918
built54's Avatar
no warranty, but I'm sure it was from the cheap copper plug...
All is good now, i did the first WOT run last night since that incident... I had to smoke a cummins that thought he would "smoke" me.... wasn't even close.
Old Jan 13, 2008 | 03:17 PM
  #919
built54's Avatar
What do you guys think of this... Remove the add a leaf from the rear so it sits a little lower, slightly uphill, maybe lower the front a little more if its too much uphill? Or should I Leave it alone
Old Jan 13, 2008 | 03:49 PM
  #920
jbrew's Avatar
Have you ever played with the torsion bars. I know there adjustable as well. Brings the front end up and down. I 'm not sure how far you can go with it before it throws the front end out. I know you can tweak it either way a little for height.
The trucks stance looks good in the picture IMO -
Check out your hole shots - how much does the back end sink out of the hole ? If it does at all. I guess that's what I might look @ first.
Old Jan 13, 2008 | 03:57 PM
  #921
built54's Avatar
Yea I Had them turned all the way up a while back. Now its about an inch lower than stock. I took the block out of the back and just have the add a leaf in there.
Here is a launch, as you can see, the front end is way up there
Old Jan 13, 2008 | 04:06 PM
  #922
Blown F-150's Avatar
I just noticed, I have the exact same rims, only mine are just 17's If you drop the front you might loose some weight transfer and it might hurt the holeshot, even more so when you don't have the slicks on. Have you done the gears in the front yet? you wouldn't have to worry about swapping tires all the time just for on the street. not sure how much loss there would be though, couldn't notice any on mine, but I never timed it or anything.
Old Jan 13, 2008 | 04:07 PM
  #923
jbrew's Avatar
Damn , that comes up a couple inchers!! I would leave it where it's at then myself. If your as low as you can go in the front. You have room in the back, I don't think it would look right going lower IMO.
Old Jan 13, 2008 | 04:11 PM
  #924
NYfordguy's Avatar
Wow that torsion crank looked good built!
Hey I know this is sorta off topic but what kind of fog and headlights do you have and where did u get em? I want to upgrade my truck to the clear lenses, the old diffuser style are just blech!
Thanks!
Old Jan 13, 2008 | 04:18 PM
  #925
built54's Avatar
Depo head/fog lights.
Old Jan 13, 2008 | 04:27 PM
  #926
NYfordguy's Avatar
Thank you sir
Old Jan 13, 2008 | 04:38 PM
  #927
Zaairman's Avatar
Leave it the way it is
Old Jan 13, 2008 | 04:39 PM
  #928
built54's Avatar
yeah im kinda thinking that too...
Old Jan 13, 2008 | 05:44 PM
  #929
torkum's Avatar
Looks great built. Can you tell any difference in cornering?
Old Jan 13, 2008 | 05:56 PM
  #930
built54's Avatar
yeah it handles much better being lower. It also rides a lot smoother.
