Project GO FAST is now in progress!!!
Old Jan 15, 2008 | 09:16 PM
  #961
jbrew's Avatar
Well, the motors went a few tunning stages to get dialed in , it might be the plugs. I've experience coils getting hit with oil or even gas - dry them off and all seems fine . Two days later , they start that mis firing business.
You said you had trans fluid hit the truck pretty bad right - That could have something to do with it. Some residual fluid might have worked it's way into a connector or a coil may have been exposed to fluid and it may have infected it..
But , yea , they usually last 2 days after exposed for me.
BTW - Your over 4000 posts ( :
Old Jan 15, 2008 | 09:19 PM
  #962
built54's Avatar
Good thought Jbrew... Oil did sling all over the back of the engine, and just maybe the back 2 coil packs got a little oil on them....
Old Jan 15, 2008 | 09:26 PM
  #963
jbrew's Avatar
Last time something happened to me like that was two winters ago . That spring rusted inside the connector @ the fuel rail . It blew off @ about 45mph Pumped gas all over the back of the motor and it soaked down #8 coil pretty good. It was okay for a couple days , before it started acting up. The coil was fairly new as well..
Old Jan 15, 2008 | 09:29 PM
  #964
built54's Avatar
wow lol I had no idea i had that many posts.... Hmm ok ill pull #8 and 4 tomorrow and check them out...
Old Jan 16, 2008 | 02:01 PM
  #965
Faster150's Avatar
coils or the plugs got wet and not getting a good ground because the tranny fluid on the threads. or ur plug gap is to big
Old Jan 16, 2008 | 03:02 PM
  #966
kaptain's Avatar
I had pretty much the same thing happening last week. It would sometimes miss, but other times seemed fine. I started by pulling plugs and found the #3 cylinder was definitely lean. turned out to be a bad 42# injector. I think youre running 60#ers, but you might check.
Old Jan 16, 2008 | 07:14 PM
  #967
built54's Avatar
I have 42's but im going to check them, just not tonight
Old Jan 17, 2008 | 09:31 PM
  #968
built54's Avatar
I pulled all the plugs, they were all fine, still looked new and gapped at .032... still have the wot miss. Today going down he interstate at 80mph, it would cut out for a second, about 5 times within 5 miles... I wish it would just throw a code or something.
Old Jan 17, 2008 | 09:47 PM
  #969
jbrew's Avatar
Well , you can kick start the monitor. I posted a "How to" in the lightnings forum..
I'll find it for yuh .
Here it is -
https://www.f150online.com/forums/sh...d.php?t=264844
But yours cuts out @ WFO (wot) So it's a big ? mark. Well, it's worth a shot . Maybe the monitor can at least isolate the cylinder # if it's indeed just one cylinder. You might be able to get a multiple/random code set anyway.
Old Jan 17, 2008 | 10:10 PM
  #970
built54's Avatar
Hey thanks man, ill give that a try tomorrow
Old Jan 17, 2008 | 10:22 PM
  #971
jbrew's Avatar
Thing is , that procedure has to be done under normal acceleration..
Uhmmm.. - Is there such a thing anymore?
You might want to do more than just two excels and decels to be sure the monitor gets activated - just in case
Old Jan 17, 2008 | 10:33 PM
  #972
built54's Avatar
ya i really dont like the fact of it cutting out like that under wot... while its missing... I think im going to try datalogging everything i can think of first
Old Jan 18, 2008 | 08:37 AM
  #973
JMC's Avatar
JMC
25 Year Member
Check your engine and tranny harness connectors. While you are at it check the PCM connector too. I dielectric grease all of mine to keep water mud out. Do the gauges sweep when the engine cuts out?
JMC
Old Jan 18, 2008 | 06:25 PM
  #974
built54's Avatar
no nothing happens. I reinstalled my tune and it doesnt do it any more...
Old Jan 18, 2008 | 06:44 PM
  #975
Klitch's Avatar
keep it up joey, mines coming up behind yours finally.
personal opinion of computers - theyre retarded sometimes and forget **** lol
