Project GO FAST is now in progress!!!
Old Oct 27, 2007 | 02:47 PM
  #481
jbrew's Avatar
The lightning 4R100 is stronger - if you could get it to work .. That won't work - it's only 2WD.
Yea , I wonder if you could reprogram those diesel tranny's - they would have more strength stock....
Old Oct 27, 2007 | 02:48 PM
  #482
built54's Avatar
yeah, my local off road/diesel shop could get me one for a good price... I'd like some more info on this.
Old Oct 27, 2007 | 03:33 PM
  #483
SKRWZ's Avatar
Originally Posted by jbrew
Joey , you might need a "Monster In a Box" for that motor .. - But these E4OD's are purdy tough..
It's perfect outside for a second gear holeshot - It just rained
Think I'll take her for a spin..
I'd look into a BTS tranny they are built for 800 HP or so if that wouldnt hold up I dont know what will
Old Oct 27, 2007 | 03:35 PM
  #484
built54's Avatar
yeah thats what I looked at, but the price isnt catching my eye... I want other options
Old Oct 27, 2007 | 03:39 PM
  #485
SKRWZ's Avatar
A buddy of mine put a BTS tranny in his F 250, he let me drive it one time and all I can say is WOW I want one it shifts so smooth you dont even know it shifted, if i lived where you do I wouldnt even go anywhere else, you pay for what you get
Old Oct 27, 2007 | 04:46 PM
  #486
jbrew's Avatar
Well , got my fix for now. Started to go sideways before I let off - Some punks even gave me a thumbs up
Sure does sound good cutting loose in second on wet pavement ..
Glad to see that Amsoil is still doing it's job - checked my fluid when I got back and it was still cool- man was that a good investment..
Old Oct 27, 2007 | 05:30 PM
  #487
PSS-Mag's Avatar
From: Lost some where in the middle of the Ozark Mountains!
No Kidding , I never tried it... Thanks :o
Dont feel bad I didnt know either until about a year after I got my truck and was complaining on here that I missed my manual tanny for trying to take off with a trailer in gravel in the middle of a hill. (I've always had manuals since I was 16) Then someone here told me you could do that, so I tried it and what do you know, it worked! It's a great tool, I use it just like I did on my manuals alllll the time now. I just wish we could do 3rd the same way.
Old Oct 27, 2007 | 06:12 PM
  #488
jbrew's Avatar
Yea , I remember when I was installing the shift kit and reading about all this extra hold power and strength second gear is going to have with the kit. I just thought - Okay, whatever , sounds good to me lol - Not thinking to much about it... But yeah - that was news to me - I think it shoots better out of the hole in second - Like bran-new
Old Oct 27, 2007 | 08:18 PM
  #489
Faster150's Avatar
the thing that causes the clutches and the bands and stuff to burn up is the lack of pump pressure. simply upgrading to a stronger intermediate shaft a stronger front pump get some red eagle clutches and koleen steel plates a good valve body and valves and ur good for about 700-800 hp.
Old Oct 28, 2007 | 04:35 PM
  #490
built54's Avatar
Ok who ever has a lc1 wideband, please help. I Need to know all the settings you guys are using. I got a lean code p0174, and i just uploaded the tune and its only been at idle, and slight rev, and my a/f is showing 8-10.3 at idle, now how can that be if im getting a lean code?? I go into the lm programmer, and what do you guys have for settings in analog 1 and 2?
Old Oct 28, 2007 | 05:42 PM
  #491
JMC's Avatar
JMC
25 Year Member
Look for a vacuum leak. Because it is a new set up you may have missed a fitting somewhere. Something may have slipped off. Start at the air filter and work your way to the engine. PCV etc...
JMC
Old Oct 28, 2007 | 09:00 PM
  #492
jbrew's Avatar
Joey - This site has a ton of info about the diesel tranny's . I'll bet they have some information about diesel tranny's to gas motor conversions.
I know they have a total E4OD rebuild in color . Just something to check out . -
http://www.thedieselgarage.com/
Old Oct 29, 2007 | 01:21 PM
  #493
built54's Avatar
ok my wideband is working perfect now, 14.2-14.8 at idle, 15-16 at part throttle. Now that its working, i can datalog with it and my tuner can fix it right.
Old Oct 29, 2007 | 04:04 PM
  #494
MGDfan's Avatar
Joey;
You did a fresh free-air calibration, etc, right?
I'm looking at my logs right now. The A/F's remain @ stioich from idle through midrange, until I go open loop @ approx 78% Load - then they start to get richer ( 11.9-12.1) all the way to the limiter @ 6,000.
There is no way it should be leaning out first... what's up with that ???
Old Oct 29, 2007 | 06:43 PM
  #495
Faster150's Avatar
Originally Posted by MGDfan
Joey;
when u first push the throttle the air is added quicker than the fuel injector pulse width can increase so it always will lean out when u first hit it. if it dont the motor will bog down from fuel dump. also fuel demand in the tune varies with the RPM and the gear/Load of the engine. the heaver load the engine is put under the more power is demanded and the more it makes. which is why u always dyno in 1:1 ratio.
