Project GO FAST is now in progress!!!
Old Dec 15, 2008 | 02:10 PM
  #1981
Veteran: Army
Originally Posted by built54
I dunno, hes runnin a faster time than me.... maybe I should try it.
yeah but your truck was heatsoaked and you've got the new mods
Old Dec 15, 2008 | 06:22 PM
  #1982
built54's Avatar
yea thats true^
Old Dec 15, 2008 | 07:09 PM
  #1983
Faster150's Avatar
they launch in 4wd then shift out to 2wd with the push button. its hell on the transfer cases
Old Dec 15, 2008 | 08:28 PM
  #1984
150xlt's Avatar
Their is two guys here that have duramax's and both of them launch in 4spin and shift out just after they launch and neither have had problems. The one has ran a 7.68 and the other an 8.20 in the 1/8. I would think you would be fine, just my 2cents
Old Dec 15, 2008 | 10:21 PM
  #1985
built54's Avatar
Well my 6 year old yellow top optima finally took a ***** today.. luckly my truck was in the garage and I wasnt out in the middle of no where! Just thought id share my anger of spending money on things that dont make me go faster...
Old Dec 16, 2008 | 02:54 AM
  #1986
Neal's Avatar
Cool
HI!... You did pretty good to have a YELLOW TOP last 6 years. Life expectancy for those is about 4 years of continuous use. My 1ST one last 5 years. Then the 2ND one 2 years in my truck and I believe JMC has had it in his truck for 2 as well mabey a bit longer.
Old Dec 16, 2008 | 09:45 PM
  #1987
Chris123NT's Avatar
Wow, spent the last day or two reading through this thread. This truck is absolutely insane, I love it!
Old Dec 16, 2008 | 10:04 PM
  #1988
Jackal's Avatar
IMO, you CAN NOT beat the heavy @ss Motorcraft BTX-850 battery.
Old Dec 16, 2008 | 11:21 PM
  #1989
Neal's Avatar
Cool
HI!... Well I had one of those in my F-150. Killed it in a year. Dealer replaced it. Killed the 2nd one in a year. It's not designed to be drained all the time like I do at the dragstrip with running two 16 inch cooling fans and a 10 inch tranny cooler fan and a electric water pump. The YELLOW top laughs at all 4 things running with the truck off.
Old Dec 16, 2008 | 11:30 PM
  #1990
SKRWZ's Avatar
I had a yellow top although it was pretty good when it went i replaced it with a Odessey battery these are nice http://www.odysseyfactory.com/batterysearch.asp
Old Dec 17, 2008 | 12:22 AM
  #1991
hdmyg8586's Avatar
Now that is a lot of brass air fittings http://www.liangdianup.com/subpages/airfitting_1.htm there is just about every type
of air fitting that you could want. Wholesale prices too. I guess these could be used as small water pipe fitting also. I
used some of the parts to make my babington wvo burner.
Old Dec 17, 2008 | 07:50 AM
  #1992
built54's Avatar
great thanks. ill put a hot water heater in my truck
Old Dec 18, 2008 | 07:56 PM
  #1993
baticus's Avatar
Built, I tried looking for it, but I was wondering what muffler(s) you have on your truck?
Old Dec 19, 2008 | 04:32 PM
  #1994
BlacknGold's Avatar
Registered User
I dont know if it makes a differece or not but I would think the positive displacment blower would be a little harder on drivetrain parts then a turbo. Due to how the blower will deliver power quicker and harder then a turbo. Also he could be running an adjustabe wastegate so he can ease off on the boost on lauch and then as more as he gets faster. Parish was running close to 1000hp and he did 4wd launches but I dont know if still had stock half shafts.
Old Dec 20, 2008 | 11:26 AM
  #1995
built54's Avatar
I am running bassani mufflers dumped
