Project GO FAST is now in progress!!!
Old Oct 29, 2007 | 07:09 PM
  #496
MGDfan's Avatar
Originally Posted by Faster150
when u first push the throttle the air is added quicker than the fuel injector pulse width can increase so it always will lean out when u first hit it. if it dont the motor will bog down from fuel dump. also fuel demand in the tune varies with the RPM and the gear/Load of the engine. the heaver load the engine is put under the more power is demanded and the more it makes. which is why u always dyno in 1:1 ratio.
But Paul.... I don't see any of that in my logs. Stioich, then richer as the load increases. No spikes. And every one of my runs - all of them, are the same. Remember, this isn't a carb.
Looking at the many dyno plots on here - I don't see any evidence of that occuring either on a properly running truck.
I don't think what he's seeing is normal or accurate. The PCM is calling the shots here... and it's supremely fast.
Old Oct 29, 2007 | 07:32 PM
  #497
built54's Avatar
well thats just not even half, and not nailing it, it could be completely different if I were to instantly go WOT. I havent had a chance to data log yet
Old Oct 29, 2007 | 10:36 PM
  #498
Faster150's Avatar
old dyno graph of mine. little over a year ago
this was with no tune stock fuel pump and injectors.. yeah i was lean . 2nd gear pull. damn spiked lean!
heres another i found just using google
Old Oct 29, 2007 | 10:46 PM
  #499
built54's Avatar
Yeah here is one of mine from my old engine, it doesnt spike lean for a second
Old Oct 31, 2007 | 01:35 AM
  #500
mazdaparts's Avatar
If you are looking for a tranny, the 4R100 was used behind the 7.3L PSD from 02-??. From what I have read the E40D was weaker than the 4R100. And it is available in 4x4.
Old Oct 31, 2007 | 08:23 AM
  #501
built54's Avatar
ok well the question is, will it bolt up, and can it be programmed?
Old Oct 31, 2007 | 05:36 PM
  #502
phil6608's Avatar
It will bolt up to the 5.4 I just put a BTS in my truck. But it was no esey task!!!!
I had to get 4R100 flex plate/dip stick, tube and bracket/ cross member/ Lightning tranny wire-harness/L computer/change the exhaust to fit around it/ shorten the driveshaft + you need the 4r100 and a torque converter to fit it! Then I added a LFP pan to hold more fluid and a V10 tranny cooler.
You don't even want to know what the total bill was,,,lol.
Phil
Old Oct 31, 2007 | 06:19 PM
  #503
built54's Avatar
thats what I figured. Id rather just put some good stuff in mine when the time comes.
Old Oct 31, 2007 | 08:09 PM
  #504
Faster150's Avatar
damn that torque curve looks like converter shutter. that or out of balance tires? did you use beads or wheel weights to balance those tires your using? and its not that it goes lean particularly its just that the air hits before the fuel does. so the a/f goes high then levels off.
Old Oct 31, 2007 | 09:16 PM
  #505
flareside4life's Avatar
Actually, that's a specific phenomena that's caused by the film of fuel evaporating faster than it is replenished when there is a surge of air through the intake. You compensate for this through an acceleration compensation setting on the ECU. If you have an electric fuel pump and properly matched injectors, your engine should never go lean. I just watched a 500 hp Mitso Evo get tuned last week with an AEM ECU, its A/F ratio never went below stoich, at the instant from idle to 100% tps the accel compensation made the A/F ratio right at 12.
Your using a stock ECU right? I can't believe that it would be set-up to lean out like that. What kind of control do you have over the fuel map on that beast with the tuner that you are using?
Old Oct 31, 2007 | 10:55 PM
  #506
built54's Avatar
Yeah I dont know why it did that, it was the only run that did it.
Old Oct 31, 2007 | 11:46 PM
  #507
That's really wierd, only one run huh? All the rest were good? Maybe there was some F'up in the ECU and the fuel trims didn't respond fast enough.
Tuning is the pits when you don't have access to a dyno all day long, and you can't tune it the way you want with the tools that you've got. You really need when dealing with that crap.
Well good luck figuring out your fuel/electrical gremlins. Let us know when your running 100%.
Old Nov 1, 2007 | 08:27 AM
  #508
built54's Avatar
Oh I will lol, with some videos!
Old Nov 1, 2007 | 07:40 PM
  #509
Faster150's Avatar
haha niiiiice!
Old Nov 1, 2007 | 11:30 PM
  #510
Careful, it's against the law to kill too many unsuspecting people
