V10 Swap
Just how long has that question been on your mind buddy ?
I remember when you were looking for that info -- Shoot!!
, uhh, - last year sometime I think ?
Well, maybe you'll get an answer this time.
Good Luck
, uhh, - last year sometime I think ? Well, maybe you'll get an answer this time.
Good Luck
I remember a few pages back, he said it was a secret as someone attempting it needed a "challenge."
But if it was Neal or JMC putting a V10 into an F150, i'm sure they could find a way if it was the only thing holding them back.
well I tore up the syncro's so it had to be almost stopped in order to shift into 2nd (1st after granny gear) If I was doing a V10 swap I'd toss in a 6 speed and a 76mm turbo just for pulling power
. There is no pats issue. S-duty pcm has no pats. I do have the cluster but since it runs and works fine without it. It has fallen very far down my list of things to do. The only thing that does not work is the spedo and odo.Josh
Engine mounts were interesting. I dont say as if someone else gets there they will (assume some slight creativity) roll around in laughter as i did.
Josh
Josh
Well if you actually do the swap you would see what i am talking about. So loose the attitude. Motormounts are usually simple in a swap but this was really simple. Just do it and you will see.
Josh
