Sponsored by: CARiD
Write-up: Auto Spring 2.5" Leveling Kit Install
Old Nov 8, 2011 | 03:41 PM
  #241
shibby2's Avatar
Might wanna update the tools list and let everyone know that the 30mm socket will need to be deep well also.
Old Nov 8, 2011 | 10:15 PM
  #242
FieldsJ007's Avatar
2" AS Level made my 2010 FX4 Screw sit perfect..deciding between 275/65R20 or 285/65R20..just don't want any rubbing...
Old Nov 8, 2011 | 10:42 PM
  #243
FieldsJ007's Avatar
Old Nov 16, 2011 | 08:42 AM
  #244
TXST8tj's Avatar
30mm sockets are sort of deep by nature. The large size of a 'standard' socket is deep enough for this application.
Old Nov 21, 2011 | 03:27 PM
  #245
Damn Dirty Ape's Avatar
I notice that the rear blocks for the 09-11 4x4 don't have a bump stop on them like some other block brands. Anything to be concerned about?
Old Nov 25, 2011 | 06:15 PM
  #246
otisrm's Avatar
lift kit
thank you, very very helpful! i have 2005 f150 stx that i justed ordered a 3 in. kit for, and being mechanically inclined, was hoping to do it myself! thanks again
Old Dec 1, 2011 | 03:32 PM
  #247
shibby2's Avatar
Not true, I had one that didn't fit at all... not even close. Had to go out and buy a deep-well while doing it.
Old Dec 1, 2011 | 03:52 PM
  #248
dixie_boysles's Avatar
do these affect ride quality at all and do you need an alignment afterwards
Old Dec 17, 2011 | 12:13 AM
  #249
o4eFeX4's Avatar
Great write-up! Thanks for sharing.
Hope I'm not stepping on anyone's toes...a video of this project...hopefully this will help someone out too..
http://www.youtube.com/watch?v=ZmfCDXdWQjI
Old Feb 1, 2012 | 03:58 AM
  #250
bubbajoe28's Avatar
My two most recent...
2006
2011 (2009-2011 are a little different, but still super easy)
TXST8TJ,
Any tips you can provide on how the install is different for a 09?
Thanks,
Bubba
Old Feb 2, 2012 | 06:41 AM
  #251
CAGE RATTLER's Avatar
Just wanted to thank the OP for the great write up. I've done a few leveling kits over the years on other vehicles but nice to see an easy to follow write up.
I do have a question though.
Does anyone know the exact heights of the front spacers for how much lift? And does it vary from year to year of the F150's?
I know they arent a 1 to 1 ratio so knowing for example a 1 3/4" tall spacer will give you 3" of lift, would be nice to know. It would especially be good info to have in case the busy ebay sellers send you the wrong size and without this info, you dont find out till after the install.
Old Feb 21, 2012 | 01:24 PM
  #252
TXST8tj's Avatar
Originally Posted by bubbajoe28
TXST8TJ,
Thanks,
Bubba
Bubba,
With the 09+, you have to remove the forward, lower control arm bolt at the frame. You need that extra flexibility to get the lower strut bolt to line up. It takes an extra couple seconds of work, but it is no issue for the install.
Old Jun 4, 2012 | 03:47 PM
  #253
tallydawg's Avatar
bookmark. I want to try this
Old Oct 8, 2012 | 07:25 PM
  #254
jpm1221's Avatar
Thanks for the Great write up TXST8tj. I just purchased my first real truck two weeks ago and love it. I think I will take on the AS 2" or 2.5" leveling kit job as soon as I have time. I am somewhat reluctant to take apart a new truck but they look so good leveled out. After reading all of the posts, I understand that I should measure the truck on a level surface for the exact lift I need. TXST8tj, am I correct that the only difference from your write up compared to a 2012 screw FX4 is that I will need to disconnect the front UCA to frame bolt? Has anyone installed an AS 2" or 2.5" kit on a 2012 screw FX4? If so, could you post a picture for me to compare?
John
Old Oct 8, 2012 | 07:30 PM
  #255
jpm1221's Avatar
Oops. I mean disconnect the LCA to frame bolt.
