box design help needed
Old Jan 7, 2008 | 11:55 PM
king ranch's Avatar
i kno you guys are tired of me starting new threads
anyway i would appreciate if someone would design a box for me and tell me all the specs on it so i can try to build my own box unless i can get someone on here to build me a box for a reasonable price
i dont have room for a slot port so i was told by a guy a caraudio to go aeroports
i plan on having 2 12's l7's and my max dimensions are 26 long 17.5wide and 35deep
if possible i would like each sub to have 3cuft or more
also is a aeroport box just a sealed box with aeroports put in them
could someone help me out
thanks
Old Jan 8, 2008 | 12:00 AM
what year truck and what size cab?
under the seat? whats your plan?
Old Jan 8, 2008 | 12:24 AM
king ranch's Avatar
2001 supercrew king ranch with bucket seats plan on taking out the rear console and placing a box in that area made for 2 12's ported
wanted to do 2 15's ported just dont think its possible even aeroports
so i figured 2 12's aeroported at 33hz should be loud enough anway
Old Jan 8, 2008 | 01:04 AM
GJ Screw's Avatar
Alright, first off Yessss. We are gettin tired of the same posts asking the same questions.. check these threads out might answer the questions you have, and possibly find a box builder..
4 12"s
First box build
Box design questions
The best 12" Sub
Is this possible
need a box builder
800 dollar system
Need info will this sound good
2 12"s
where
hey 1bad86vmaz
would this be a descent set up
what would sound better
does this setup sound good
how to bridge and amp
new hu and subs
amp and subs what do i do
what should i do
is there room
need help
tweeters
how can i put subs in my truck
mixing sub sizes
amps
shallow mount
sub for king ranch
Edited to add 3+pages of same stuff at caraudio.com. http://www.caraudio.com/forum/search...archid=2805727
wow
There is pleanty of info in these threads you have started, i am not trying to be a PIA but please, read what others have posted several times in all of the threads you have started, all of your questions have been answered..
Jon
Old Jan 8, 2008 | 04:09 PM
king ranch's Avatar
ok sorry for posting so much
but can i get one more answer from a box builder
i want to try nd build my own box aeroport box for 2 12's l7
i would like them to have anywhere from 3-3.25cuft per sub after displacement for everything and the tune to be 33hz
and this is the aeroports i guess would work best for my box it said on psp-inc.com
i figured to go with 2 6" flared ports that are 18.14 or straight port at 17.14 which ever is best i heard flared was best
and my biggest box i can go with is 26long 17.5 wide and 35deep so what should the box dimensions be to give each sub 3-3.25cuft after displacement of everything
and also would the 2 6" flared ports that are 18.14inches long come out to being tuned at 33hz
Old Jan 8, 2008 | 04:48 PM
styxnpicks's Avatar
areo ports only come in 17 inch lengths
Old Jan 8, 2008 | 05:24 PM
king ranch's Avatar
aww geez so how would i make a 18inch port
and also what would a 17inch port be on the tune
Old Jan 8, 2008 | 05:29 PM
you can also check out my box build up in my signature if you are looking for the between the seats option.
Its not ported, but the idea can be modified. If you need my box deminsions let me know.
Old Jan 9, 2008 | 05:21 PM
king ranch's Avatar
ok this si what i have come up with and i tihnk its right and i need someone to build this box and i want it carpted and whats the price for a box like this
internal measurements 15.5 x 23.5 x 27.5=5.8
also why do u subtract 1.5 from external i though the wood is only 3/4inch thick not 1.5 inches or am i wrong
the aeroports it said on the weibsite for voulme of box at 5.2 was 4 inch diameter and 3 of those at 16.02
so the port displacement would be .35 correct and the sub displacement would be around .20
so .55 for everything
so 5.8-.55 equals 5.2-5.3 anywhere in there so each sub would basically have 2.6 net
check and make sure all thats right
thanks
Old Jan 9, 2008 | 06:34 PM
bangingd's Avatar
.75 X 2 sides = 1.5
Everything else in your thread is for the port masters.
Old Jan 9, 2008 | 10:05 PM
gixxerjasen's Avatar
Yup, if your measuring total external length or width or height, there'll be two pieces of wood in that dimension, one on each end. Gotta account for both.
Old Jan 9, 2008 | 11:47 PM
Low_e_Red's Avatar
thanks
Wont work. Not enough port area. you need between 1/4 to 1/3 of the cone area on your ports.
Old Jan 10, 2008 | 01:33 AM
Jwool15's Avatar
if you want to do it right and quit cutting corners you're going to have to lose the back seat man. I'm not trying to be an add just BWI g straight up honest. My cousin just put two L5s in his extended cab chevy and had to lose his back seat. In order to get the tu ing frequency you want and anywhere close to the recomended air space for the subs that's what you're going to have to do. If you're not prepared to do that then you're going to have to pick some different subs.
Old Jan 10, 2008 | 11:37 AM
king ranch's Avatar
ok so how many aeroports do i need at what length to have enough.
on psp-inc it said that would work thats what it suggested
Old Jan 10, 2008 | 01:26 PM
Low_e_Red's Avatar
quit cutting corners. Aeroports arent the way to go. and too many of them. DO THE MATH ON AREA THEN FIGURE IT OUT.
area of a circle = pie x (radius squared)
area of a square = l x w
