first box build
Old Jan 4, 2008 | 01:48 PM
king ranch's Avatar
first box build
i plan on building a box for a friend for a sub i am giving him actually 2 subs and my question is what should i do one sub is a jl 12" 125rms single 8ohm and the other is a mtx 10" 200rms single 4ohm
should i run both in a big box or put the 12 in a big box by itself its rated for 1.25 sealed whats the most air i can give it
also going to build a box for 2 12's l7's recommend for 2.0airmax whats the most i can give each sub
thanks
Old Jan 4, 2008 | 02:07 PM
styxnpicks's Avatar
didnt we go over this already?
Old Jan 4, 2008 | 02:11 PM
azmidget91's Avatar
dont you hate it when that happens
but deffinatly spearate the subs
Old Jan 4, 2008 | 02:17 PM
styxnpicks's Avatar
this is about the 8th thread on the same thing
Old Jan 4, 2008 | 02:38 PM
azmidget91's Avatar
if its rated for 1.25 then "give it" 1.25
thanks
again if the manufaturer recommends 2.0 airspace max then dont go over 2.0 each, they tell you this info for a reason, if you "give it" more air then it needs it will blow, because it will be too easy for the sub to bottom out which will decrease your volume and could blow your sub....
Old Jan 4, 2008 | 05:25 PM
GJ Screw's Avatar
X2 X2
Old Jan 4, 2008 | 07:41 PM
Devildog101's Avatar
thanks
Dont mix subs... Just use one or the other...
Old Jan 4, 2008 | 08:01 PM
Bartak1's Avatar
x a million.
Build a box for the JL, throw a two channel amp that does about 300wrms at 4 ohm on it, and call it a day.
Use the MTX as a paper weight or something.
