backup camera
Old May 20, 2008 | 01:16 AM
  #61
Low_e_Red's Avatar
No you dont.
Old May 20, 2008 | 01:52 PM
  #62
jstachowiak's Avatar
Lincoln Factory Nav and Backup camera hook up?
You guys seem like you are dialed in to Ford. I've got a Lincoln Navigator 2006with factory navigation, DVD is on passenger side of console for nav system.
Questions:
1. Can I wire a backup camera to the Lincoln nav system display AND,
2. can I wire it to come on when I put the gear selector in reverse?
Any help is appreciated, thanks.
Jeff
Old May 20, 2008 | 02:37 PM
  #63
bubbajoe28's Avatar
Does the Navigator's Head unit have a Backup Cam feature that you can select? If not, you can hook the cam up to a AV input.
You can get 12V power from the taillights(which will activate the cam), then feed 2 video wires from the cam up to the headunit. I would go with a aftermarket cam as it will be much cheaper than the F-150 camera that is specific for a tailgate application.
Old May 20, 2008 | 04:14 PM
  #64
Thanks, I'll have to look at the head unit. A local audio installer is looking into it for me too. The Ford navigation systems are Denso units and there seems to be a little discussion on the GM boards that the rear view cam does not work with this unit. At least on GM units.
I'll start looking.
Jeff
Old May 20, 2008 | 10:54 PM
  #65
zagnum0357's Avatar
Back up camera?
I have a 2008 limited f150 # 4334. Is there a way to install a bypass on the rear camera so I can turn on or of at will? Has anyone tyied this and some pics if you did it. Thanks, Ken.
Old May 20, 2008 | 11:50 PM
  #66
jrb03's Avatar
Here is a link to my thread, I discuss my 08 cam mod. It has the information you need to do the mod you want. Basically, there is a reverse signal wire in the mirror harness. When the vehicle is in reverse 12v is sent through this wire to power on the monitor. You could tap into that reverse wire with 12v switched to power it on whenever you want.
https://www.f150online.com/forums/sh...d.php?t=332905
Old May 21, 2008 | 08:58 AM
  #67
Apparently there are no inputs on the Lincoln nav system. I found these links that may help someone on this board. I have not tried these products. Note: scroll down to see all vehicle makes for the Interfaces. they have cameras too.
http://www.sonicelectronix.com/cat_i...eo-system.html
Old May 26, 2008 | 11:37 AM
  #68
I just purchased a Pioneer ND-BC2 backup camera off E-Bay and the NavTool NavTool off E-Bay. I've got a local installer who said he would install for me. So I will report when I get it in and installed. Probably second week in June by the time I get everything.
I have the Lincoln factory nav system.
Jeff
Old May 26, 2008 | 11:44 AM
  #69
One good reason for backup cameras on SUV's: http://www.allheadlinenews.com/articles/7011065858
Jeff
Old May 31, 2008 | 05:09 PM
  #70
Bugman1400's Avatar
Does Tasca have any more connections diagrams for the ends of the different wiring looms?
Old May 31, 2008 | 07:58 PM
  #71
OK, the Navtool http://cgi.ebay.com/Lincoln-Navigato...QQcmdZViewItem came in but the Pioneer camera is still enroute.
I went ahead and installed the Navtool and it is plug and play (with original equipment Lincoln nav system), had to wire one blue wire to reverse wire Black with Pink stripe on back of original harness that comes out of the back of the Nav DVD player. Everything works and when I put the vehicle in reverse the screen goes blank for the camera input. If you want to wire another video source into the Navtool and Nav screen there are two more wires you have to splice in.
I'll report on the rest of install when I get camera next week. Total cost $220 plus $180 for the Pioneer camera with shipping. You can get cheaper cameras but I did not want to chance it.
Jeff
Old Jun 2, 2008 | 10:08 AM
  #72
TascaFordParts's Avatar
Former Sponsor
I'll check on the connectors and see what I can find.
Old Jun 5, 2008 | 08:56 AM
  #73
NavTool and Pioneer camera are installed and work, just have to install camera on back of vehicle and run wires, the hard part.
Pictures at bottom of my website: http://www.ourlifeanew.com/Home%20Pa...navigator.html
Jeff
Old Jun 5, 2008 | 10:00 AM
  #74
05supercrew's Avatar
Jeff
This is one reason I have the sensers and the camera. Any time Im backing up in my driveway or pulling out I make sure both my kids get put into the house or come in the truck.
Old Jun 5, 2008 | 01:27 PM
  #75
Done. See install pictures on my website bottom of page: http://www.ourlifeanew.com/Home%20Pa...navigator.html
Jeff
