backup camera
Old Apr 29, 2008 | 02:48 PM
F150PARTSGUY's Avatar
Former Sponsor
Originally Posted by Bugman1400
That is very interesting...I did not know about the color coded lines. The obvious question is where are the color coded lines added....in the camera or in the mirror. My reason for asking is whether or not it is feasible to connect the factory camera to another video display...say to a Kenwood or Pioneer video dash system and have it operate in a similar manner. I've also noticed that the mirror can be bought directly from the mfr for significantly less.
Your thoughts Ed?
I'm no tech, that's for sure. I didn't even know what NTSC was until yesterday.
" Short for National Television System Committee. The NTSC is responsible for setting television and video standards in the United States (in Europe and the rest of the world, the dominant television standards are PAL and SECAM). The NTSC standard for television defines a composite video signal with a refresh rate of 60 half-frames (interlaced) per second. Each frame contains 525 lines and can contain 16 million different colors.
<br>
The NTSC standard is incompatible with most computer video standards, which generally use RGB video signals. However, you can insert special video adapters into your computer that convert NTSC signals into computer video signals and vice versa."
so if this holds true, I would say the camera will work with Kenwood or Pioneer etc. I think the lines are in the mirror to gauge distances to obstacles. I'll see if I can come up with more info.
Anytime Ford gets involved they have a markup that I would die to be able to make. I get to squeeze by with 20% to 40% while they make 400% to 1000%
I received invoices from Ford vendors in the past where there cost was like $0.22 cents and my cost was $18.00. I know they have to box it ship it and pay someone to process it all. But dam share the wealth, but then again there are dealers out there that refuse to make a buck and ***** up the market and give it away so it wouldn't matter what the cost was.
I would buy the mirror direct if you can.
anyway off topic, I hope this info helps you a little. Anything else let me know and I'll see if I can come up with more information.
Ed
Old Apr 29, 2008 | 03:26 PM
Former Sponsor
Normal Operation
With the ignition switch in the RUN position, the video camera receives voltage through circuit 294 (WH/LB). With the gear selector in REVERSE (R) position, a reverse voltage signal is sent to the rear view mirror, enabling the system. The video signal from the video camera displays an image on the left portion of the rear view mirror display.
I couldn't find anything else. yet!
the search continues
Ed
Old Apr 29, 2008 | 11:58 PM
Low_e_Red's Avatar
All I need is a diagram of the wire layout. Whether it be through a BS connector or RCA to make it work...
Old Apr 30, 2008 | 09:54 AM
TascaFordParts's Avatar
Former Sponsor
if anyone needs a picture of the connectors at either the camera or the mirror send me a email and I'll send them out.
Old Apr 30, 2008 | 11:25 AM
Low_e_Red's Avatar
Ive got it. I figured out how to make it work with the help of Tasca Auto Parts.
You will need 3 Things, 12v Switched, Ground and a one RCA cut in half.
12v+/0: needs to be connected to Pin 1 (White/Lt. Blue - 18ga)
Ground: to Pin 6 (White - 18ga)
RCA Center Pin: Pin 4 (Red/Yellow - 18ga)
RCA Outside Pin: Pin 5 (Black/Yellow - 18ga)
Last edited by Low_e_Red; Apr 30, 2008 at 11:33 AM. Reason: OEM BACKUP CAMERA WIRING FOR AFTERMARKET
Old Apr 30, 2008 | 11:50 AM
Low_e_Red's Avatar
Normal Operation
Ed
The Reverse signal is housed in the Mirror. When put in Reverse no signal is sent to the camera. Instead it turns the monitor in the Mirror on. If you were to put a 12v switched to the Reverse signal, the monitor would stay constant. Or if you wanted to make that a screen it is also possible.
Old May 5, 2008 | 03:16 PM
Big-Fokker's Avatar
Originally Posted by TascaFordParts
We carry the parts at www.TascaParts.com there are a couple of options for the handles. The basic textured black one like the stock one is 8L3Z9943400AC and the textured Black handle with the chrome pull (lariat edition) is 8L3Z9943400AD they are also available as the MarkLt handles painted with the chrome pull, the camera is a separate piece.
Pardon the ignorance, but is this just a replacement stcok assembly with the keyhole hogged out so a camera can be mounted?
Old May 6, 2008 | 01:37 PM
Former Sponsor
Its the 2008 Tailgate handle with a separate hole for the camera.
Old May 6, 2008 | 02:07 PM
jrb03's Avatar
That is some very good information there! But Im not 100% sure where these pinouts are from, the mirror or the tailgate.
Reason I ask is I have a few mods in mind for my 08 with the Reverse monitor in the mirror. I am about to install my D3 and was wondering if there was a way to get the video feed from the factory camera into the D3 for reverse. Before I decided to get the D3 i had wanted to find a way to turn the reverse camera on anytime I wanted, like if I was driving down the highway and wanted to take a look at the load in the trailer. From what I read here I should be able to tap into those pins and run an RCA cable to the D3 and view the video. You say the camera is powered reguardless of gear, so I should be able to view the camera output on the D3 going down the highway also? Sounds like exatly what I want if I can figure this all out.
Old May 6, 2008 | 05:33 PM
Low_e_Red's Avatar
Exactly. The pins are at the camera. And that info is so you can use the cam for reverse.
If you want you can also turn your mirror into a screen for the D3...
Old May 6, 2008 | 05:41 PM
jrb03's Avatar
That sounds like something I need as well
Happen to have the pinouts for the mirror?
I am going to do the rca cable for the D3, even if I have to run a 20 footer from the tailgate to the console. Thanks for sharing the info
Old May 6, 2008 | 11:19 PM
Low_e_Red's Avatar
Why would you do that??? Why not trace the wire into the cab and cut it and wire it in from there? Much shorter...
Mirror - Wire RCA on to the other side of the leads. Then feed 12v+ into the reverse wire (Dk. Grn/Yellow - Pin 2 - 18 ga).
That will turn the reverse mirror on for use as a second screen.
Old May 7, 2008 | 12:44 AM
thenewbreed's Avatar
Tasca, you seem to have a decent price on the handle. Do you know the diameter size of camera that will fit?
Old May 7, 2008 | 12:52 AM
jrb03's Avatar
Well I said if i HAVE too....
I didn't have much luck tracing the reverse wire in my 03 when I installed a backup cam, so I got tired of messing with it and ran a long wire to the tail light. I will search out these wires though, thanks for the great info.
Old May 7, 2008 | 08:05 PM
j2h1's Avatar
I just got the handle today and measured it with calipers. The hole size I get is .815" dia. by about 1.725" max depth clearence. In mm is is about 20.70mm X 43.81 mm dp. Looks like you can widen the hole up to .965" or 24.76mm. I am looking for a camera now but am having a fun time finding that hole size without widening the hole. I did see Sharp makes one here http://www.sharpvision.cn/waterproof/cw637.htm that would be a great size.
