backup camera
Old Jan 12, 2009 | 04:48 PM
  #121
Buckeyes903's Avatar
Originally Posted by racinwarrior
go to wal-mart and in the car audio section look for the roll of 25 ft RCA for 10 bucks.
the black/pink wire under the drivers sill plate is the rev trigger(NOT BROWN AND PINK AS I MADE THAT MISTAKE)
Trailer plug is switched 12v (if you have towing package) look on the cover and it will tell you the wire to use
Originally Posted by Low_e_Red
There is a grommet at the rear of the vehicle in the sill plate (both on drvr and pass side.) Put the wires through that.
Awesome, thanks for the info, this will make it a lot easier!
Old Jan 23, 2009 | 05:28 PM
  #122
OK, so I just ran the RCA wire, I was unable to find the switched 12v The only thing I have for towing if the standard 4 prong wire, but I see it goes into a much bigger connector with a few other wires, would the switched be back there? Also the black and pink of course I guess is all the way in the bottom of that wire loom?? haha I found the brown and pink, oh well more digging in there tomorrow.
Old Feb 3, 2009 | 12:37 PM
  #123
JJDH's Avatar
i have a 2007 fx4 with the dimming mirror, is this mirror already equipped with camers ready?
Old Mar 1, 2009 | 01:10 AM
  #124
Kenankeny's Avatar
2008 F150 OEM Backup Camera
I got the backup camera and mirror in and it works great. Thanks to my Ford buddy (and of course to you) who came to my house and helped, we got it installed in about 2-3 hours. The hardest part was getting the front part of the headliner loose and getting the new harness in. Fortunately it was no problem for my Ford Tech friend.
Here’s the entire part list:
8L3Z-19G490-A CAMERA
8L3Z-9943400-CG TAILGATE HANDLE
8L3Z-14A411-A TAILGATE CAMERA WIRE ASSEMBLY
8L3Z-13A409-CA WIRE ASSEMBLY
8L3Z-13A576 WIRE ASSEMBLY
8L3Z-14334JA WIRE ASSEMBLY
8U5Z-17700-L MIRROR
So we put in a new harness basically for the taillights and license plate lights, the trailer light plug harness, installed the camera, the jumper harness from the camera to the new taillight harness. Replaced the one harness from the mirror, lighted visors and satellite radio antenna. The main loom under the truck and behind the glove box had the wires in them all ready for the camera so the new harnesses just plugged in.
The picture and illumination of the camera is so nice, I’m glad I went with the OEM installation.
Old Apr 5, 2009 | 08:40 AM
  #125
alien_sporez's Avatar
I just purchased and installed a camera from 4ucam.com. I'd recommend it. So far I'm happy with it. It's one of the few cams where the monitor turns off when in drive. It's wireless, so it does sometimes pick up interference, but overall I'm very happy with it. For only $100 it's definately a good price. The best part is that it comes with the IR illuminators making seeing in pitch-black night very easy, something other cams in that price range don't have.
Because I insisted on hiding all the wires the install was a bit more complicated because I had to run wires under the dash, but had I just chosen to do a generic "surface" install it probably would have been an easy 1-hour install.
Old Apr 5, 2009 | 09:07 AM
  #126
nu guy's Avatar
Old Apr 11, 2009 | 04:12 AM
  #127
jonathanschiffe's Avatar
Has anyone installed the emblem camera on an older model (06)? The wiring seems straight forward (now that I've read the posts). I thought I could just pull the plate off of the inside of the tailgate and have room to work. No luck... I guess my first step is removing the old emblem. Is it bolted, snapped or glued on? and is there a hole behind it or will I need to cut it out?
Thanks in advance for any help.
Old Apr 11, 2009 | 09:09 AM
  #128
JJDH's Avatar
cam
no. i bought one off ebay before i looked in the tailgate, the new tailgates must be different, it cant be done, unless u go custom and cut up the tailgate. there is a crossmember in the 2004-2008 models. with that crossmember u wont be able to wire it or mount it.
Old Apr 11, 2009 | 01:32 PM
  #129
Thanks for the info.
Dose anyone want to trade a handel version for my emblem version? Also are they the same cameras?
Old Apr 11, 2009 | 01:33 PM
  #130
JJDH's Avatar
cam
cameras are different
Old Apr 12, 2009 | 03:15 AM
  #131
thanks
Old Jun 2, 2009 | 01:09 AM
  #132
golden4x4's Avatar
8U5Z-17700-L MIRROR
Why was the taillight harness (8L3Z-13A409-CA WIRE ASSEMBLY) required?
Old Sep 17, 2009 | 10:37 PM
  #133
Kenankeny's Avatar
Sorry, haven't one hear since I posted. You will need all those looms so everything plugs together for the OEM installation. I still love my backup camera installation. About $1200.00-$1300.00 total cost.
Old Mar 9, 2010 | 08:25 PM
  #134
kwfireman10's Avatar
I have a 2008 white FX2 and I would like to have the handle and backup camera that connects to my Pioneer Avic D3. Can someone Give me the part numbers for both? and also does the camera have rca connectors? what is the Price?
Old Mar 15, 2010 | 06:23 AM
  #135
Kenankeny's Avatar
See above for part numbers and no the factory camera doesn't have RCA plugs, just a four pin plug if I remember correctly.
