Alpine W205
Old Jun 20, 2007 | 01:23 AM
  #106
RollingRock's Avatar
Originally Posted by rodl1
I just received my w205 and installed it. It is a nice addition to my truck, but i have one problem. My airbag light keeps coming on. does any one know what the problem is?
does it stay on or come on and off?
could be the harness that you used or you could have possibly grounded it to an airbag ground. Can you tell us what else you are using? Amps? Cap? Bypass?
Just guessing here....
I am about to leave the country with no access to email...hopefully someone can jump in here. I am not expert on the wiring...
Old Jun 20, 2007 | 06:33 PM
  #107
CobyMedic's Avatar
Hey guys, I got the Pac TR-7 for my W205, just wondering what wire the switch has to be put on? I am assuming it would be the red power wire from the PAC unit but just want to be sure. The switch came lose from the unit with 2 wires on it
Old Jun 20, 2007 | 09:28 PM
  #108
rodl1's Avatar
i just have the iiva-w205 and that is it.
Old Jun 21, 2007 | 10:14 AM
  #109
njtek's Avatar
The instructions I got with mine said to put the toggle switch between the white wire on the TR-7 and the yellow with blue stripe wire on the alpine. I have had no problem with mine.
njtek
Old Jun 21, 2007 | 11:20 AM
  #110
dconder's Avatar
Which airbag light? The one by the speedometer or the passenger airbag light on the dash?
Old Jun 24, 2007 | 01:49 AM
  #111
rodl1's Avatar
it is the light on the speedometer.
Old Jun 26, 2007 | 10:20 AM
  #112
njtek's Avatar
Any update on the Blackbird B200 release date?
njtek
Old Jun 26, 2007 | 12:44 PM
  #113
Alpine is pushing to end of July now. Just talked with them.
They are not even accepting orders for them yet.
Told them they had MANY people waiting on them.
Old Jun 27, 2007 | 10:34 AM
  #114
CobyMedic's Avatar
I post this question a couple weeks ago put none of the answers worked out for me, so I will clarify my question and try again.
I have a sirius plug and play radio i believe its a Starmate 4, I have it plugged into the head unit via the Ai-net port, but I am unable to get any sound from it. I had a similiar set up in my gf jeep liberty, just hooked up to a cda-9856 adn it worked perfectly. Wondering if anyone has a setup like this for the 2005 or 200 and can help me out?
Old Jun 27, 2007 | 12:00 PM
  #115
I responded to this already...but will again. I think you have to tell the HU that its there via the SET UP menu...
If that doesn't work call tech support..they picked up for me the other day in 2 min.
Old Jun 27, 2007 | 12:27 PM
  #116
dconder's Avatar
How do you have it hooked up? Are you using the ai-net to rca adapter cable? The reason I ask is I have the Starmate and there is a new adapter coming out that allows control of it from the Alpine head unit. But, it takes an Alpine adapter and a yet to be released Sirius adapter. But, it allows you to use all the features of the Starmate, replay, game alert and such, straight from the head unit.
If you are using the ai-net to rca adapter, you may have to turn the aux. input on. This is in the setup menu. If you are going straight from the Starmate to the ai-net cable, I would be interested in knowing how. Thanks.
Old Jun 27, 2007 | 03:07 PM
  #117
CobyMedic's Avatar
I am going from the ai-net to rca cables, i have the aux in the setting turned on. Maybe I just have a faulty cable or something, I'll have to try the cable off my girl friends head unit to see if that makes a difference.
I have seen ai-net cables on ebay that have the 3.5mm jack on the end of the cable instead of the RCAs, but I am not sure of the quality or if they would work. I would be interested in an adaptor tho if it would allow you to control the sat radio thru the head unit. Any information on it, such a release date or anything?
Old Jun 27, 2007 | 03:21 PM
  #118
dconder's Avatar
I assume you are running the 3.5mm jack from your Starmate to rca's on the other end? I would try running these straight in to the aux. input of your head unit. Is it the W200? If you have the aux. turned on this should work. That is how I have mine hooked up for now.
The Alpine adapter is out. It runs about $70. The Sirius adapter was promoted and shown at the CES show. I have called Sirius and Directed and no one seems to know when it will be released.
Here is the Alpine adapter and you can read about the SCVDOC1:
http://www.alpine-usa.com/US-en/prod...odel=KCA-SC100
Old Jun 27, 2007 | 04:12 PM
  #119
njtek's Avatar
Thanks for the update.
Old Jun 27, 2007 | 09:44 PM
  #120
dave123's Avatar
I have a 2007 F150 ...How much did that radio cost ya/?
