BOP reflashed PCM is in
Old Jul 10, 2003 | 10:41 AM
  #136
beefcake's Avatar
the other thing, as i read through the nonesense is some people are actually saying the thing is compensating,
if it was compensating, the a/f would be at a 10.9 with the nitrous too, bottom line,
just like guys can run a 2lb pulley without a chip on most trucks. it's not because of the "compensation ability" it's the simple fact the truck has a relatively safe tune to start with.
SO IN CONCLUSION IT HAS NOW BEEN PROVEN THAT THE "CAL'D" PCM DOES NOT COMPENSATE FOR SQUAT
Old Jul 10, 2003 | 11:51 AM
  #137
jmimac351's Avatar
Originally posted by hslightnin
12 to 1 is messuring percent o2 correct? 12% would also be correct?
and tail pipes being leaner becouse the cats? good point never thought that
1350 is kinda cold isnt it 1450 is gas 1250 on methinol
been a few years but i think that what i ran
this might sound like a "flame" but its not
Put it this way, it is 12 parts air to 1 part fuel.
1350 is what I run but you could run higher. I don't care to tune my carbureted street vehicle to the edge.
Old Jul 10, 2003 | 11:54 AM
  #138
jmimac351's Avatar
Originally posted by Gen2 Lightning
Everyone, do not attempt to tune for maxmimum power safely with an EGT gauge on a FI vehicle. That's NOT safe, or very accurate, by any means.
12.0 to 1 + is about the limit I would have ANY forced induction or any Nitrous equipped vehicle running at, and that's when they are running good octane.
I completely disagree.
Old Jul 10, 2003 | 11:59 AM
  #139
jmimac351's Avatar
Beefcake, you mentioned yourself that you didn't bother reading through the posts. I am sure you missed the post Nate made about the NOS system messing with the fuel regulator on the baseline. It helps to take time to read things you are going to critique.
RIF - READING IS FUNDAMENTAL
Old Jul 10, 2003 | 12:22 PM
  #140
03Lightning's Avatar
Beefcake, every time the truck was run with the NO2 system's fuel pressure regulator vacuum line working as the kit was designed the truck ran rich (10.9:1-11.3:1). Even with diferent sized jests and no NO2 the AFR stayed rich. Then we decided to take the NO2 vacuum line kit off and the truck stayed around 12.2:1-12.5:1. Also, the AFR would progressively get richer as the RPM's went up.
Fact is that you were not there to see it in person. You did not see the AFR change in real time as I did. You did not see the dyno operators change jets and get around the same AFR, I did. For my application, a set in stone chip is not an option. I don't want to send my chip in every season to get a re-tune. And to coment on your suggestion to get a 4 program chip and get a summer tune, winter tune, race tune and a towing tune, I think that is a waste of money, and the type of mentality that the tuners want you to have. If you throw enough money at a problem you will eventually solve it.
Old Jul 10, 2003 | 02:24 PM
  #141
SpeedJunky's Avatar
OWNED!
Old Jul 10, 2003 | 11:43 PM
  #142
beefcake's Avatar
i didn't read all the posts b4 posting my first reply, i had already read the excuses b4 the first post.
Old Jul 10, 2003 | 11:48 PM
  #143
beefcake's Avatar
i'm curious then, why weren't the "matching" a/f dyno sheets posted,
the first dyno sheet is the only n/a one and it shows an a/f of 10.9 the rest are at 12.4, why not post the matching sheet if it's there?
Old Jul 10, 2003 | 11:50 PM
  #144
beefcake's Avatar
Originally posted by SpeedJunky
OWNED!
i own this thread, results were just as predicted, nothing has been said or proven otherwise, see next reply
Old Jul 10, 2003 | 11:55 PM
  #145
beefcake's Avatar
originally posted by me b4 any dyno results were shown in a previous thread
i'm happy for nate, but again, the only difference is he now has a better program for his truck, it's not that because it's done on the PCM makes it any better, and, i guarantee you, off the nitrous, his power will be down compared to people with identical mods for the simple fact that the "reflasher" will have put in plenty of room for safety with the 75 shot,
like i said, i loved my 4 way chip,
run on the street at great power, when i want to be more aggressive at the track and run 98 or higher octane, i had the ability to add 3 more degrees of timing and boom, theres another .10, when i wanted to run nitrous, flip again, less timing, but still maximum power for the shot i was running,
once it got cold, flip to cold weather to still run aggressive, but safely,
YOU WILL NOT GET ALL THAT WITH THIS REFLASH,
the simple fact that you cant get the extra power with the higher octane turns me off,
i guarantee you, if nate runs 100 octane unleaded, he's going to lose power because the fuel will burn too slow for his program,
i'd love to know the timing he's running, ect.., i wonder if he has any idea?
hmmm did i say the n/a program would be pig rich? is it? yes
10.9 vs 12.4, i don't care about the excuses, the charts posted speak for themselves
Old Jul 10, 2003 | 11:59 PM
  #146
beefcake's Avatar
how is it a waste of money to get a chip programmed 1 time for everything that you need, i ran the same program for the entire year until i added nitrous, then i had my mileage program removed and had a nitrous program added, didn't cost any extra,
if the chip isn't right it doesn't cost you anything to get it reburned.
so, your saying if nate decides to get a 200 shot, then he can run it safely without being "recal'd" again. i say PROVE IT, i see a/f's in the 13 to 14 range with a 200 shot,
Old Jul 11, 2003 | 03:56 AM
  #147
cyntaxx's Avatar
Beefcake, weren't you the one that swore by a stock PCM adding 3 degrees of timing with colder temperatures?
Old Jul 11, 2003 | 10:56 AM
  #148
beefcake's Avatar
yeah, so what's your point, i still do!
WHERE ARE THE "fixed" DYNO GRAPHS
if the problem was fixed and corrected the predicted fat a/f ratio, where are the dyno's, why were the "unfixed" dyno's even posted?
Old Jul 11, 2003 | 03:29 PM
  #149
cyntaxx's Avatar
Then this discussion has ended.
Old Jul 11, 2003 | 07:03 PM
  #150
beefcake's Avatar
hey brilliant one, i just talked to sal, he checked the stock pcm programming and the computer does indeed ADD 4 degrees of timing from 100 degrees.
OWNED
