Rafa26, Project Becoming A Reality .
Old Jan 25, 2007 | 09:55 PM
  #136
bamorris2's Avatar
Originally Posted by rafa26
Factory Tech 4R75W MonsterBox Transmission and Total Domination Torque Converter.
Hey man, sorry to hear about your frustration.
On a side note, I've seen alot about the MonsterBox tranny, but I've never seen/heard exactly what makes it different/better. Does it handle more HP, or is it just more durable for the same HP? Reason I ask is because I tow a large travel trailer pretty frequently. I fully expect that my tranny will take a crap 1 mile after my warranty is up. So I'm trying to plan well in advance what tranny I'd replace it with.
Old Jan 25, 2007 | 10:11 PM
  #137
khendrix2374's Avatar
Rated to possibly handle 1200 or 1500 HP.. it's not making that much.
I'm sticking with 12.00...
Old Jan 26, 2007 | 10:24 AM
  #138
MartyG525's Avatar
Talking
I just spent the last 15 minutes digesting everything Rafa has done to this truck & I've got to say ... whoa... I can't wait to see what happens the first time you breathe on the good pedal!!! Sorry to hear about the delay issues w/JDM, hope you can get at least a decent justification for that...
So any bets on how long it'll take someone to mount a Pratt & Whitney Jet to the back of a FX2 just to top this monster???
Rafa, please - For the sake of everyone who has read your ongoing project with anticipation, PUH-LEEEZE mount a video camera pointed at your FACE the first time you stomp on it!!! -
Old Jan 26, 2007 | 01:18 PM
  #139
a n t h o n y's Avatar
Banned
Have troyer put all your shift firmness to stock and use the Factory Tech C-plate. It is cheap and a great mod. But so far i have been the only person i have found that has done it on a 04+ F150 (so far). I have a plate right now that is customized for what i want.
Old Jan 26, 2007 | 02:37 PM
  #140
bamorris2's Avatar
Could you elaborate a little more? What exactly does a c-plate do? And how would it help my tranny to last longer?
Old Jan 26, 2007 | 02:49 PM
  #141
Banned
In between the main transmission case and valve body is a separator plate. This plate is what mainly controls your shifts and shift speeds. You open the "orifices" you fill the valve body quicker and leads to a "better shift" (what i think of it) without sacrificing on any aspect. You can also change the springs in the accumulators or even run NO SPRINGS for a tire chirping shift w/o raising your shift pressures via PCM.
Old Jan 26, 2007 | 06:37 PM
  #142
mlawdawg's Avatar
Originally Posted by patshea098
thats what i was thinking
the engine is rated at 1200HP come on!
I don't follow. Rated at mean it can withstand that w/o blowing apart. I think Raf said they were going to keep it at 700rwhpish. So maybe mid to high 10s if he can hook up with some stret slicks
Old Jan 26, 2007 | 10:47 PM
  #143
mcdover's Avatar
Hard to get sarcasm to come across on a message forum.
Old Jan 27, 2007 | 06:50 AM
  #144
mlawdawg's Avatar
True. True.
Old Jan 27, 2007 | 07:26 AM
  #145
assasinator's Avatar
rafa can have more power than this if the power train is up to it. this is a 2v 5.4 BB truck.
STRIP SPECS
Owner: Johnny Wiker, a.k.a. Johnny Lightning
Hometown: New Providence, Pennsylvania
Driver: Johnny Lightning
Year/Model: '01 Lightning
Weight w/driver: 4,300 pounds
Engine: 355ci Johnny Lightning Performance
Built by: Johnny Lightning Performance
Power adder: Kenne Bell twin-screw
Intercooler: Stock with Johnny Lightning
Performance Super Cooler and heat exchanger
Maximum boost: 22 pounds
Intake manifold: SLP
Cylinder heads: Johnny Lightning Performance Stage 5
Compression ratio: 8.9:1
Camshafts: Johnny Lightning Performance Stage 5 cams
Ignition: Stock with Kenne Bell Boost-A-Spark
Exhaust: Johnny Lightning Performance headers,
Bassani X-pipe and mufflers
Transmission: Level 10 Torque Master
Converter/clutch: Precision Industries
Rear type: Stock with 3.55:1 gears
Wheels (F/R): Bogart 15x4 1/2, 15x10
Tires F/R: Hoosier 30x10 slicks
Suspension front: Anthony Jones Engineering frontend with coilover springs, Aerospace brakes
Suspension rear: Johnny Lightning Performance lift bars, QA1 shocks, fiberglass leaf springs
Best e.t./mph: 10.683/127.75
Old Jan 27, 2007 | 08:37 AM
  #146
mcdover's Avatar
STRIP SPECS
How much hp and tq is he putting down with this truck? I'm sure Rafa is going to have some huge hp and tq numbers, but there is a huge difference between a 2-door, smaller frame, single cab truck and a 4-door, huge frame, 4wd Mark LT. With driver, this truck will weigh in excess of 6000 lbs. That's a huge difference and it will take a lot more power to equal the times that Johnny Lightning is reaching. At one time, my truck and car had the same crank hp, but by no means would my truck even touch the quickness of my car.
Old Jan 27, 2007 | 09:49 AM
  #147
ONE04FX4's Avatar
Talking
i say somewhere near the mid 12's.
Old Jan 27, 2007 | 12:09 PM
  #148
JLP fastest Harley truck ran a what? 10.90... fully built race truck with nitrous... weighs less than a fully loaded 06' Crew cab..
Old Jan 27, 2007 | 01:15 PM
  #149
05RedFX4's Avatar
Exactly, it was also the 97-03 body in a scab, so it weighed significantly less. It was also 2wd so it doesn't have the driveline loss of a 4x4 to deal with.
Old Jan 27, 2007 | 01:50 PM
  #150
Black3v's Avatar
so the 26th has come and passed which is what Jim Sr promised isnt it? Any updates or should we not go there.
