Starting the V10 swap in 99 F-150
Old Feb 29, 2012 | 06:25 PM
  #91
illness95's Avatar
now this is a pretty neat swap, but alll this/that trouble for 50 more hp and 125lbft of torque??? you could have done a bolt on lightning swap to the 5.4 and gained over 100hp..
Old Feb 29, 2012 | 06:29 PM
  #92
ishootstuff's Avatar
My 5.4 was trashed and the V10's are easier to find and the same cost, that's why I did it.
Old Feb 29, 2012 | 06:32 PM
  #93
illness95's Avatar
ahhhh ok ..
Old Feb 29, 2012 | 06:34 PM
  #94
Toyz's Avatar
125ft/lbs of tq is a huge improvement. Lightning swap would cost twice as much and if you have high miles is not worth it imo. But.. money aside would seem to be easier than swapping a v10
Old Mar 1, 2012 | 10:46 AM
  #95
fairlaner's Avatar
In my mind, you can't beat this mod for braggin' rights and sheer uniqueness ... A V-10 F-150, how cool is that!
Old Mar 1, 2012 | 10:48 AM
  #96
1997 lariat 4.6's Avatar
i got a one up on this... 7.3 powerstroke.... but i doubt our trucks could handle it!!! this still is a bada$$ swap!
Old Mar 1, 2012 | 11:08 AM
  #97
Raptor05121's Avatar
I'm still rooting for you buddy. Keep up the hard work. This certainly has quite the unique bragging rights!
Old Mar 1, 2012 | 11:10 AM
  #98
OK, I admit it, that was definitely a factor in the V10 decision!
That would be cool, but I have no need (or budget) for a diesel!
Old Mar 1, 2012 | 11:28 AM
  #99
Thanks, I appreciate that! I can't tell you how many times I have considered selling the V10 and getting a V8 back in it.
I'm now toying with the idea of running the 5.4 PCM in "parallel" with the 6.8 PCM. I have no idea if I can do it, but I want the 5.4 PCM to do the PATS authentication then do a hot swap of sorts with an array of SSR's (Solid State Relays) to actually run the truck.
The other idea I had - again just brainstorming here - is to figure out if I can set up a waste spark type system to fire the extra cylinders. It would be inneficient because I'd be doing a waste injector spray too, but it would get me through emissions and then I could put the V10 PCM back.
I don't know... Just babbling. Thanks for reading
Old Mar 2, 2012 | 03:02 PM
  #100
Burns331's Avatar
Id suggest taking it to a custom tune shop and seeing what they can do. I bet they can alleivate some of you Pats issues, and find some more ponys in that motor.
I want to see some hard accerlation vids from a stop. Id also like to see a 30 mph roll.
Also is the truck a f250ld? I didnt think you could get the 4r100 in a standard f150. It had to be a lighting, harley, or a f250LD.
Old Mar 2, 2012 | 04:36 PM
  #101
I have already contacted two local tuning shops. Still waiting to hear back from the second one, and the first said they THINK they can do it if I buy a new (not used) PCM. Sorry, that's too expensive for maybe.
As far as videos - first of all, its slower than the V8, second, I don't have a speedometer to film!
No, it's not a 7700 or LD. From what I have read and heard, the "E" code for 1999 is the 4R100.
Old Mar 2, 2012 | 09:25 PM
  #102
formuladriver01's Avatar
I still have not had time to talk to my ford tech. I am in the middle of getting ready to move to Guam under military orders. I should be stopping by there sometime this week. I will let you know what I find out. Sorry for the delay.
Old Mar 2, 2012 | 10:48 PM
  #103
You have one of the rare F-150's with a 4R100. You also have 3.73 limited slip.
Old Mar 2, 2012 | 11:36 PM
  #104
Thanks!
Old Mar 2, 2012 | 11:39 PM
  #105
I didn't realize that was rare. Cool.
