5.4 3v fix
Old Feb 28, 2014 | 11:50 PM
jamesrgr's Avatar
5.4 3v fix
In the market for another F150 screw since totaled my 04 lariat in wreck. ? in what year did they resolve issues with 5.4 3v (cam phasers) etc. What other things do I need to look at. Had replaced my engine and rebuilt trans. had 244000 on it. Will be buying used so what year would be best. Thanks for help.
Old Feb 28, 2014 | 11:57 PM
MGDfan's Avatar
Hi.
^^^ In 2011, when they ditched it for the 5.0, 3.5 TT, 3.7 and 6.2
Cam phaser noise - here's what it sounds like when it's bad:
http://www.livernoismotorsports.com/...epair-Kit.html
Maint list & additional info you may find helpful:
https://www.f150online.com/forums/20...e-up-time.html
https://www.f150online.com/forums/20...ht=maintenance
https://www.f150online.com/forums/20...ht=2005+issues
https://www.f150online.com/forums/ar...placement.html
https://www.f150online.com/forums/ar...ml#post4213274
The infamous 5.4 3V Plug change sample info:
http://www.fourwheeler.com/techartic...rk_plug_blues/
https://www.f150online.com/forums/ar...y-writeup.html
Lisle tool #65600 broken plug extractor should be purchased beforehand. Carquest, Napa, online stores, etc sell it.
New plug boots (e.g Belden from Napa - $4/each), silicon dielectric grease, hi-temp nickel anti-sieze, MC carb cleaner also needed.
IMPORTANT NOTE: IF a 2005 5.4 3V - you NEED to read this and be aware that this can occur at any time - with potentially catastrophic consequences.
==> http://ww2.justanswer.com/uploads/sd...229_r07m08.pdf
BTW - if you have a Traction-Lok ( LS) rear diff, you need to change the fluid if it's not been done for over 30K or 3 years. The friction modifier used ( MC XL-3) is hydrophyllic - absorbs water. Left unattended for longer periods and you risk corrosion in the pumpkin.
Good luck
MGD
Old Mar 1, 2014 | 02:46 AM
They never really "fixed it" because even the new ones have some issues. If you were fine with your last one, just get another 04-10 depending on your budget. Later 08s and up solved the spark plug issues
Old Mar 1, 2014 | 07:34 PM
05FordGuyFX4's Avatar
Just wondering at what mileage did you replace the motor and rebuild the trans? If you can afford a newer truck like mentioned above 08 or newer. Even the new motors have had some failures and issues (around 750,000 f150 sold last year alone). Any motor can have issues and as many 5.4 motors out there (came in multiple vehicles) you are going to hear of problems.
Old Mar 1, 2014 | 08:20 PM
Ross-FX4's Avatar
May 08 I think they replaced the plugs / Cops.
These motors have the 3rd revision phasers.
170k of blown, trouble free motoring.
3v bad motor? Or just bad owners?
