Ford Tough????
So jbrew let me get this straight. We the consumers must use what the manufactur calls for on our vehicles? We have no say so on what parts can be used on our vehicles and if we use these parts our trucks are going to crap out. That is pretty much what you are saying. Please correct me if I am wrong.
If your not sure of what you're doing, don't you think that would be the best choice ? It can be even cheaper doing so. In your case presently, much cheaper. Yea don't say we, for it is "you" that made the mistake.
Your corrected.
At least you learned something, sucks what happened and learning the way you have.
There is other after market parts that work well in our trucks, but you have to know which ones. The tolerances are much tighter today than they use to be. That's why grade/viscosity with engine oil is so crucial for any kind of longevity. Using a oil filter with such a high rate of DBV failure isn't any good either.
If you don't know, safest bet is letting the dealership service. Sometimes they can service cheaper than you can. Depends on the deals they have at the present time.
I can't believe your not understanding correctly.
Yeah I unfortantely heard about the anti drain back valve after the damage was done
I guess the situation could be worse I could not have purchased an extended warranty and be paying for this all out of my pocket. I'm just going to start changing the oil on my truck myself and only use Motorcraft oil filters. I trust myself as opposed to taking it to Walmart or a Jiffy Lube and nothing against the dealer I just cant leave my truck there all day just to get an oil change that would only take me maybe 30 minutes to do.
I guess you didn't read the post from before where I said I wasn't trying to argue with anyone on here. I definitely am not the first person to have this problem and I will not be the last. However, I do see your point on just how sensitive these engines can be and will be more careful in the future as to what parts I purchase.
First, Ford doesn't say that you have to use Motorcraft, they say you have to use a product that meets the specs they specify. The Fram does not.
Secondly, my dealer does my oil change in 30 minutes and charges me $25 plus the disposal fee. I can't do it myself for much less than that and will take longer.
Fram needs to take these filters off the shelf. That will probably never happen though, so I will do my part in steering people with newer F150's away from those death cans.
The death cans do have a DBV, it's just that they are made from cardboard and don't work too well. Fram also makes a premium filter with a silicone DBV that works fine, I think those filters are white instead of orange.
I've seen one before. I was light blue with no writing what so ever . Yea, who knows ?
Yep, that is what I suspect. The ones I have seen were white with no label.
Well still no word from the dealership. Last time I heard from them was this past Thursday when they replaced the phasers and lifters and said it didn't fix the problem. I am curious as to what they will come up with now.
