Project GO FAST is now in progress!!!
Old Oct 19, 2008 | 07:37 PM
  #1816
boss1984's Avatar
Originally Posted by jbrew
You first start up I think, I don't think it was even fine tuned yet, but she sounded very heathy.
Sooo, That's all your truck we're hearing in BOTH vids ?
yea, i couldn't even here Builts blower over my exhaust...its ridiculous
Old Oct 19, 2008 | 08:38 PM
  #1817
jbrew's Avatar
Well , usually when Joey races someone - it's all his truck. That's purdy much all you hear. In the first vid posted from the inside of Joey's truck, I didn't here the blower ??
Yea, I was curious why that was, -for a minute there..
Old Oct 19, 2008 | 08:42 PM
  #1818
boss1984's Avatar
built, that garden hose cap is it made out of plastic or what???i found some that r plastic but thats it..once i know i'm gonna order the EGR delete plate
Old Oct 19, 2008 | 09:04 PM
  #1819
jbrew's Avatar
Home centers usually carrie them - Sometimes the good aluminum ones are founnd on (Gilbert) sprinklers with two hose connects.. Don't ask me how I know this
Just go to plumbing section and get yourself a good one ? Their 3/4" on the 5four. - or 19mm to be exact.
Old Oct 19, 2008 | 09:07 PM
  #1820
boss1984's Avatar
well i found a plastic one...will that melt??
Old Oct 19, 2008 | 09:09 PM
  #1821
Blown F-150's Avatar
Definitely...
Old Oct 19, 2008 | 09:11 PM
  #1822
boss1984's Avatar
Originally Posted by Blown F-150
Definitely...
so plastic will work then...im confused by the "definitely"
  #1823
jbrew's Avatar
Nope. - Just use the washer inside as well or it will probably fall off
It won't melt, I just don't trust the plastic ones over the Aluminum. The Aluminum ones that I have are deeper caps and aluminum threads of course.
Old Oct 19, 2008 | 09:18 PM
  #1824
jbrew's Avatar
I used that one for awhile - it's plastic -
You can make your own block plate , if you feel like it -
Old Oct 19, 2008 | 09:36 PM
  #1825
jbrew's Avatar
Old Oct 19, 2008 | 09:59 PM
  #1826
ONELOWF's Avatar
Other than cleaning up the engine bay..........
A quote from an SCT tech:
"Most likely it will not pass an IM test. The EGR is there to reduce your Oxides of nitrogen. This is mainly produced during cruising RPM, and light load. The IM240 test is designed to instigate situations such as this. This is also assuming that they do not plug in and check to see if the monitors are passing. If you have shut off that system. the computer will tell them that it has not passed (because it never ran the test). Shutting off the system will keep the system from functioning, and keep it from setting the CEL, but that is why they run the tests.
As a side note, I would recommend leaving the EGR in place. You will not see a noticeable power gain by removing the EGR. The valve is closed at WOT anyway, and the temperature difference is minimal. You will, however notice a reduction in fuel economy with it disabled."
Old Oct 19, 2008 | 10:12 PM
  #1827
built54's Avatar
I bought a brass cap for the header. Its all tuned, no cel, still get 14mpg city and 18mpg highway, go for it.
Old Oct 19, 2008 | 10:35 PM
  #1828
My Bad, I wasn't paying that close of attention, I thought maybe you were doing something crazy like trying to put the plastic on the header.....please don't do that!
Old Oct 20, 2008 | 02:04 AM
  #1829
Faster150's Avatar
dude go to lows.. get a piece of aluminum and drill two holes in it. thats what i did
Old Oct 20, 2008 | 02:05 AM
  #1830
Faster150's Avatar
my gas mileage and performance went up when i got rid of my EGR. less gunk in the intake to robbing air flow and performance!
