Will a V 10 fit my F150?
Old Apr 10, 2006 | 09:34 PM
s1037s's Avatar
Does any body know absolutely yes or no if my 97 f150 4wd will swallow a v10 in the engine bay without firewall mods? My 4.6 windsor is on its last legs and i may have found a v10 with computer and trans to drop in. I know the weight of the v10 is more than the front can handle stock but i can solve that problem when i get to it. I need to know if the motor mounts are in the correct location for a drop in replacement or if i will have to fab some up. thanks for any and all help. Yes i tried searching and came up with nada.
Old Apr 10, 2006 | 09:40 PM
ian51279's Avatar
Doubt it. At the very least you'll need new motor mounts, front crossmember, trans. mount and crossmember, fan $ radiator mounts. It may even be too wide to go between to shock mounts.
Old Apr 10, 2006 | 09:52 PM
tiny1's Avatar
s1037s,
I am not sure what exactly what would need to be changed. I'm sure the motor mounts for one would need to, but Neal "The HP Freak" has a very well viewed thread here in the Engine forum and he mentioned the possiblilty of dropping a V10 in his truck. I am not sure what year his is but I think that it is a '99. You might want to touch base with him or maybe JMC would know.
Good luck.
Old Apr 10, 2006 | 10:06 PM
s1037s's Avatar
i'll try to get hold of them thanks
anyone else?
Old Apr 10, 2006 | 10:12 PM
ws6_guyscrew's Avatar
damn that sounds like a sweet project. I'm not sure either honestly whats the cubic inch size on the V10?
Old Apr 10, 2006 | 10:23 PM
s1037s's Avatar
415 whoppin cubic inches! then add a kenne bell!
Old Apr 10, 2006 | 10:25 PM
Neal's Avatar
HI!... Not sure about a 4x4 due to oil pan restrictions but it will fit in a 4x2. You HAVE to run electric fans and move the rad forward a bit. A 6.8L is the same as a 5.4 but with two added cylinders. Overall dimensions are the same except for the length.
Old Apr 10, 2006 | 10:28 PM
s1037s's Avatar
neal i was just about to pm you. thanks for the info. i have no problem fabbing a new front kmember as i am going to sfa in the very near future. my donor comes with the rad and i have a pair of taurus fans available to me.
by the way is your truck n/a or blown?
Old Apr 10, 2006 | 10:31 PM
s1037s's Avatar
forgot to ask...will it bolt to my trans(auto) 1997. yeah i know it will soon destroy it. the donor comes with a 4r100 but i think id have to put in a 3 inch body lift to clear it.
Old Apr 10, 2006 | 10:39 PM
stock the 5.4L block is 330ci so 415 damn haha. its most likely posible to do though. I would probably upgrade the transmission. I dont know what transmission is behind the V10 though but usually its a tougher heavy duty one.
Old Apr 10, 2006 | 10:57 PM
Neal's Avatar
HI!... The 4R-100 is used in the LIGHTNING, so it will fit under your truck and in the trans tunnel. The 4.6/5.4 and 6.8 have the same trans/block bolt pattern.
s1037s's Avatar
the v10 i have my finger on comes with the trans, a 4r100 and the tcase, but i think i woill have to b/l it to clear. i know my trans wont hold up long
oops, neal posted just as i did. thanks for the info neal, i had forgotten about the lightning using that trans
Old Apr 11, 2006 | 12:22 PM
Zaairman's Avatar
V-10 Swap I think the hardest part of this swap would be the wiring...but it would be sweeeeeeet to have a F-150 with a V-10 emblem on the fender
Old Apr 11, 2006 | 01:32 PM
JMC's Avatar
JMC
25 Year Member
I came soooooooo close to swapping a V10 for the 4.6. The engine I had ligned up was only $1200.00 CDN. But it had sat outside for 2 years without a cover. No telling what might have crawled up into the intake. I am now officially kicking myself in the **** for passing on this option. I ended up setteling for a 5.4 instead. If you stick the 7700 t-bars on the a-arms it should support the extra weight of the V10. That is untill you get the SFA swap done. Rancho 9000s set on stiff should keep it headed where you point it.
JMC
Old Apr 11, 2006 | 01:35 PM
adrianspeeder's Avatar
I'm assuming you have the 4R70w, which I wouldn't waste time with on a 6.8L. The 4R100 will go b/c these trucks did come with them.
Adrianspeeder
