THE H.P FREAK'S "SUPER FREAK" 5.4 BUILD UP!! (pics)
Originally Posted by Neal
AFTER SANDBLASTING :
I spent 6 hours today with a die grinder removing all the casting flash, unused brackets and casting seams. Going to get CERAMIC COATED inside and out this week.
did u do any modifications to the lower intake chamber? plastic part....
HI!... FASTER150 : Yes the lower ABS plenum was also gasket matched and the center post was tapered to not upstruct airflow.
HI!... Here ya go :
BEFORE :
AFTER :
I'm still playing with the idea of removing the center wall totally to make the lower plenum more like a SINGLE PLANE intake. I'll lose a bit of low end (I've got WAY too much right now) but I should gain some mid and top end power. The cams I'm running make power to 6500RPM+ so all the help I can get is a good thing.
BEFORE :
AFTER :
Now I really wanted to get the belt tensioner Ceramic Coating to go along with my timing chain cover but HTC (High Tech Coatings) said it could not be done due to there is a plastic bushing and spring inside. The heat from the procedure would destroy the bushing and the spring might get jammed up do to the polishing procedure. So I decided to paint it black.
AFTER PAINTING :
lookin nice yeh i was wondering probably would help ya to remove it.. our ford engines have gobs of low end... but having the upper end power should help fuel economony some and also help our top end performance which is what we need if were racing enthusiats.... cuase most of our F150's kinda stop pullin around 90mph
HI!... Well I have a P.I 3000 stall converter and 4.10 gears so I can afford too lose a bit of low end. It's the top end I'm concerned about. That's the main reason I decided to go with a turbo set-up over a SC'er next spring.
