Will your V6 Peel/Burn out?!
Old Jul 31, 2008 | 04:04 PM
04heritage's Avatar
Originally Posted by Blue150
Don't tear it up trying to keep up with the sport compact market.
Sure hope your not calling a corsica a sport compact.
Originally Posted by tj03f150
im pretty sure mine can
I bet you have never tried. No... I take that back I know you have never tried you tread that truck better than most treat their kids.
Old Jul 31, 2008 | 04:20 PM
01HondaHauler's Avatar
I have a 4.6L ext cab auto with the stuff in my sig on and it won't pin the rear tires on dry pavement to save its life, brakes or no brakes
used to with old crappy tires tho lol
Old Jul 31, 2008 | 05:07 PM
Blue150's Avatar
Does it really matter? They're both POS's
Old Jul 31, 2008 | 05:54 PM
BlueOvalFitter's Avatar
Unhappy
Mine couldn't fall out of a tree fast!
Old Jul 31, 2008 | 08:15 PM
BTobiczyk's Avatar
If it is the slightest bit damp I can't keep them from spinning. And if it is wet and starting up hill people will honk cause i just wont go anywhere.
Old Jul 31, 2008 | 08:25 PM
600Polaris's Avatar
my standard shift 4.2 did amazing burn outs. i would do a brake stand, power shift(no clutch) into second and hold it to about 50-55. the wheel would be cut to the left and the thing would spin for about 7 revolutions. this was with 170k on the original clutch and tranny. the v6 was a champ. my 4six v8 can spin them, and pretty well for an auto...
Old Aug 2, 2008 | 10:03 PM
ranger81's Avatar
I'm in the same boat.
Old Aug 4, 2008 | 03:04 AM
MXrob26's Avatar
Why do you guys like burning your tread off? Since i got new tires, I havnt even chirpped the tires, let alone full out white smokin them. I like my tires, and at over $600 a set, I want to keep them as long as possible.
The dirtbike is a different story tho..hah
Old Aug 4, 2008 | 08:18 AM
dirtyd88's Avatar
i dont white smoke them ever. just did a small powerbrake, and as soon as they started to wail, i stopped. have chirped them a few times, mainly because i didnt let the rpms go down as far as i shouldve and put it in gear(also bad for the tranny)
Old Aug 4, 2008 | 02:19 PM
hydeph's Avatar
my 06 just hops, no weight. it's a manual
Old Aug 11, 2008 | 06:57 PM
Raptor05121's Avatar
3.55 non-LS M50D can chirp, spin and do all sorts of fun with my tires. My P255/70R16's are down to the wear bars. plan on getting new ones soon and when I do I'm going to spin them until they blow
Old Aug 28, 2008 | 06:53 PM
timmypstyle's Avatar
Originally Posted by billybob22
I have a completely stock(Except K&N air filter) 1999 F150 Sport V6 and was suprised when this truck couldnt even peel out from a dead stop going up a hill! My friends 92 4 banger corsica can! What the... It will only hit 2 thousand RPMS when trying to power break also. anyway around this, can you guys peel out, how?!
i had an 04 heritage with 3.08 gears and it was a 4.2L V6 with a 5spd manual. when stock if i reved it up and dropped it, it would spin for a second or 2 but i put a K&N intake on it and after that i could spin tire for about a quarter second shifting into 2nd at 35-40mph. it would kick the rear end out about a foot too, and thats on dry pavement. wet pavement it would definitely spin both gears but 2nd is the best to fishtail in because 1st will kick it out then catch because your closer to the speed in which it tops out.
my 3.08 gears...
1st-40ish, 2nd-65ish, 3rd-90ish, 4th-110+. speedo only goes to 100 but tach kept going and i fgured out a was going about 108mph in 4th. also with the 3.08 gears if you had the power the truck would top out above 170mph in 5th. that would be sweet!!
Old Sep 11, 2008 | 10:09 AM
sullivan_90's Avatar
When i had roughrider A/T's mine would peel out, break stand ect.... now that i have 265 BF goodrich Rugged trails... wont do much unless i turna corner sharp n punch it...
Old Sep 11, 2008 | 07:41 PM
JayPhoenix's Avatar
My 97 has never had an issue with peelin' rubber :P it's a 5 spd manual and it had a stock 3.08 open rear when i first got it, which meant a mid burnout side to side tire swap on those crazed run's LOL and I put a 3.55 w/Auburn Locker and the only time I haven't been able to spin the rubbers is with my mud tires... 235/85r16's they are studded and grip like crazy... it's for the better tho
Old Sep 28, 2008 | 04:07 PM
Layinbuckfifty's Avatar
i can spin my 20's all day long and i can get out of my truck while the wheels are spinning and nobody be in the driver seat. its called airride take all the weight off the wheels and put all the weight on the frame and there you go once you get the wheels spinning they will spin on my truck
