E3 Spark Plugs
Old Oct 7, 2010 | 05:46 PM
  #61
sam1947's Avatar
Originally Posted by harrisdel
sold!!!
i'm gonna follow sam's lead and swap these out now.... i only have 23k on my 2008. thanks for putting in the effort and expense sam. much appreciated.
MGD, i live in MA and get to maine occasionally. can i have sam's beer?!
Originally Posted by jetech00001
ask sam its his beers
Like I have stated, the jury is still out on the longevity of these plugs, but again, as I stated if I can get a reasonable life out of these and have no worries about getting them out, their worth the experiment. As far as the beers are concerned, I gave up drinking many years ago, so, to MGDfan..go ahead and give them to jetech !
Old Oct 8, 2010 | 07:14 AM
  #62
MGDfan's Avatar
Originally Posted by sam1947
.. As far as the beers are concerned, I gave up drinking many years ago, so, to MGDfan..go ahead and give them to jetech !
Okay!
But - won't Mr. Harrisdel be pissed that I gave Mr. Jetech his beers instead?
MGD
Old Oct 8, 2010 | 05:17 PM
  #63
sam1947's Avatar
Originally Posted by MGDfan
Okay!
MGD
OOPS !!! :o:o
Old Oct 8, 2010 | 07:58 PM
  #64
harrisdel's Avatar
OOPS !!! :o:o
Old Oct 12, 2010 | 07:06 PM
  #65
menziesfx4's Avatar
Is their any noticeable difference with a plug change at 85k miles. With the motorcraft double plat?????
Old Oct 12, 2010 | 08:36 PM
  #66
88rxn/a's Avatar
nice find!
Old Oct 18, 2010 | 06:29 PM
  #67
sold!!!
Hate to burst your bubble......
But
If you have a 2008 5.4 3v its more than likely that you have the redesigned heads that don't take the plugs that have the heat shield.
Just sayin ya know..........
Edit
If you have the brown cop boots then you can't use the e3.70
Old Oct 19, 2010 | 03:42 PM
  #68
harrisdel's Avatar
But
Edit
already checked the boots... not brown. wish they were!
Old Nov 2, 2010 | 01:42 PM
  #69
Fifty150's Avatar
So I guess people can run an aftermarket spark plug without problems. There are people who think that you have to only use Motorcraft, and that nothing else will work.
Old Nov 2, 2010 | 02:54 PM
  #70
jbrew's Avatar
If you want to take a chance, - it's still early for a complete analysis. The only plug other than Motorcraft for the 3v, that I haven't seen problems with, is the Autolite's.
Champions- There's been to many bad happenings amongst boards. Some have reported -"No Problems" (so far).
From Mustang Racing (4.6L 3V list) (5.4L P#'s are dif) - NA/High boost/Nitro at the bottom. The plugs -
HOT PLUGS HT1
Autolite HT HT1 Gap .045" $10.86
Champion 7989 Gap .045" $16.23
Denso PT16EPR-L13 Gap .035" $6.82
Brisk Silver Racing Spark Plug (One Piece) 3VR17YS Gap .035" - stock and light modified $16.82
Brisk Silver Racing Spark Plug (One Piece) 3VR14S Gap .035" - light modified and modified
Motorcraft SP462 Gap .054" $21.92
___________________________________________
Cooler Plugs HT0
Ford Racing FMS-M12405-3V0 $17.30
Autolite Cool Plugs HT0
Brisk Silver Racing Spark Plug (One Piece) 3VR12S Gap .035" - high boost and/or heavy nitrous
Brisk Silver Racing Spark Plug (One Piece) 3VR10S Gap .035" - extreme power applications - JPC performance 8sec. Mustang 1000+RWHP (high boost and nitrous)
Good/bad reports, - out there, but vary. To be completely fair about the E3 - it has yet to be determined (it's a newer part).
The info above will help in your search. For your particular engine, use plug name and you can further your search, for your own determinations.
Take Care.
Old Nov 2, 2010 | 03:10 PM
  #71
jbrew's Avatar
BTW -
Since the Lisle 65600- Broken Spark Plug Remover for Ford Triton 3-Valve Engines has been getting more affordable (I've seen them between $50 -$60) and the latest design makes removing the separated plugs a piece of cake (fast). I wouldn't fear running a two piece myself.
Old Nov 2, 2010 | 05:28 PM
  #72
onefast96svt's Avatar
GEEEEZ, I really wish this find came sooner. I changed mine a few monthes ago and paid dearly for a set of MC. I still may change to these. The ford guys said this was pretty much the same plug as stock. Why would I want a new peice of crap in place of the old peice od crap?
Old Nov 3, 2010 | 02:02 PM
  #73
Fifty150's Avatar
Motorcraft plugs are not that expensive. They can't be more than $5.
Old Nov 16, 2010 | 09:46 AM
  #74
krebs640's Avatar
Most places have Motorcrafts' OEM replacement | SP-515 | for around $12.99 (MSRP, aka cost at most dealerships, is $25.89). I've seen them range from $10-$20. A set of plugs alone at $104 is expensive to me if you consider the cost of "normal" spark plugs! That being said, SP-515 are double platinum (I've generally seen considered the "direct" OEM replacement), but you can get SP-507 (regular platinum) for less.
Something to remember is the 5.4L 3V is very "special" and takes a unique plug that not many companies want to spend development resources on for only 1 engine. That's why they cost more than a typical "off-the-shelf" plug that can be used on a range of engines.
For reference, here's a JEGS pricing comparison:
- E3.70 : $5.99 ea
- Motorcraft SP-515 : $16.99 ea
- Motorcraft SP-507 : $7.99 ea
I'm preparing to do my change at 78k in my 05 5.4 since I have a nasty misfire under "hard" acceleration (on-ramps, etc.). I'm waiting for my tank with seafoam to run out, then I'll start the long process of PB Blasting, waiting 2 hours, PB Blasting, waiting 2 hours, repeat. Now I'm just trying to decide whether to get the E3.70 or SP-515.
Old Nov 17, 2010 | 02:31 PM
  #75
sam1947's Avatar
- E3.70 : $5.99 ea
I'm still 'young' with these plugs, but 2000 mi +/- with the E3 with no problems at all !!
