Torn between Mag or Borla
I don't notice the raspiness on mine at higher end. I went 2.5" front to rear, high flows, x, and 4x14 magnapacks and I really think mine sounds very similar to captain awesome's, even with the different motors and mufflers...
Well, I guess I'm the odd man out then. No raspiness at all on my setup.
On the other hand, I have heard a couple Borla setups that I'd consider 'raspy'-er than the Magnapacks setup on my truck.
I reckon, 'raspy' is a very subjective term.
not much rasp here, it is in the cab though, i'll put up a new one tomorrow...and this was last oct, shortly after the install, they've broken in...and are meaner!!!
http://www.youtube.com/watch?v=5maACYxPQgg
I only have 2200 miles of Maggie experience under my belt, but I've not heard anything I would consider raspy either. Only once have
I had it anywhere near 4000 rpm and I was driving, so not 100% sure what it would have
sounded like outside. I can't imagine what you fellas are doin if your concern is how the truck sounds at 5000+rpm...these aren't crotch
rockets!!!
rockets!!!
nice vid ryan. I'm gonna start slowing buying some kick *** magnapack set up like that over the coming weeks. BUT here's how jank my set up is now, i've just now finally got under there and really took a closer look at what my exhaust shop did. I've got factory everything from the Y pipe back, a 2.5" midpipe and they welded a 3" pipe about 2 feet from the muffler to fit the muffler's 3" inlet, then it has dual outlet 2.25" (i believe, just took a quick measurement) tailpipes to 3x18" chrome tips out the back. Very differing numbers...but it sounds alright to be honest but I want aggressiveness like 08FX4's vids or yours, Ryan.
This is the setup on my 2010 FX4, same as 08FX4's, only difference being 08Fx4 also had high-flow cats installed.
Not sure why, but it seems like my SI/DO Magnapack setup is louder outside than the Magnapack True Duals I have seen videos of. Maybe it is just the videos. If you want a consistent "Roar/Howl", than check out the Borla XR-1.
Hope this helps.
Factory Y > 3" midpipe > 3"/3" Magnapack (#14419) > 2.5" tails 45'd behind the rear tires > 18" rolled tip Maggie tips.
Hope this helps.
Hope this helps.
The Maggie Y-Pipe I used is 3" in and 2.5" out.
http://www.summitracing.com/parts/MPE-10778/
Yes. You don't need a SI/DO muffler.
Hey,Fellas
I just ordered my Borla 40842-S. Those Magnaflows sound great too by the way. I am going to do a SI/SO delete the resonator. I really liked the way Capt. Awesomes sounds. I will make a vid when I get done. I hope it turns out good, Ive never tried Borla before. My truck is a 2012 FX2 5.0.
I went with a 3" SISO Magnapack with a Y pipe split to my tails. Very satisfied. High flows going on sometime this week. Videos to come! Should be pretty nasty!! Ford power.
Im a for Borla. I had the afe 3" catback for about 6 months before I switched it but that was due to the drone at highway speeds with the AFE. Both sound awesome and I love the sound of my borla. I know if I had a stock exhaust my gas mileage would probably be a lot better but I jump on it all the time just to hear it. I also like to use my tow/haul mode button when going down a slow hill to hear the awesome sound that comes out of that borla is just awesome. My system is just a catback system that I did in my driveway.
Part# 140291
Part# 140291
When I switched out my XR1 for the Magnapack, the guy who installed it made mention of how much deeper the Maggie sounded than the XR1.
I am still torn between what I will try next. This is what I am looking at so far (not to thread hijack!):
1. SI/DO 3"-3" SS Dynomax Bullet.
2. SI/DO 3"-3" Borla 40085 (Round).
3. SI/DO 3"-3" Corsa "modded" system.
This question is for anyone really but I'm asking Arklight cause I know that he has had the XR1 on his truck. Here goes.
Within the next week or two I want to get a borla XR-1 si/so 3" inlet/3" outlet for my truck. I am torn between the round body or the oval body (part numbers 40943 and 40085)
I am concerned with the possibility of drone especially at highway speeds of 60-70mph ( I drive like a gramp and its too expensive to drive fast lol) and I read your reviews on the exhausts you have had on your truck. Which XR-1 were you using and based off of your experiences with that muffler which would you recommend?
And for the record I am planning on mounting this muffler as far back as I can and removing the resonator. The truck is a '12 S'Crew 5.0 if that makes a difference.
