Will OBX LT's + ROR = deafness?
Old Jun 1, 2011 | 12:36 AM
  #181
Will I can bring some teflon tape we can wrap the 02s threads in and reinstall them.
PM me your addy and ill see if i can come out there on Sunday right?
and Jbrew...... ****
Old Jun 1, 2011 | 05:46 AM
  #182
Jbrew had a few jbrews. The o2's and plugs went in fine, I'm sure teflon tape or the permatex will work on sealing them up.
Yeah this is turning to to be the longest header install of all time. :o
PM sent Patrick.
Old Jun 1, 2011 | 09:34 AM
  #183
jbrew's Avatar
There's really to much heat down there for Teflon. Yellow/or gas tape might last 5 seconds longer tho. I've tried it a few times, - wrapping in 3 complete circles lol. Yea , not sure what the yield is as far as heat, but it's not enough.
The Permetex is the better bet, but I've had them leak using that as well. - Depends on the leak of course. The only way to seal tight and leaving them removable at the same time is to fab up your flat washer. One that the sensors compression washer sits on top of and that washer also needs to be larger than the bung circumference.
Yea, anymore beer last night and I would have been arguing with myself today
Old Jun 1, 2011 | 09:55 AM
  #184
Windsor's Avatar
I was going to say the same thing. Anti-seize is a better bet. Might want to chase those threads too.
Old Jun 1, 2011 | 09:56 AM
  #185
Permarex it is then. I'll try and make a nice bead around the o2 compression washer first. That should seal it up. Notice how I'm being confident.
Old Jun 1, 2011 | 10:09 AM
  #186
Windsor's Avatar
Double post.
Old Jun 1, 2011 | 11:14 AM
  #187
Is anti seize really a sealant though? I know I've used it before to make things easier to remove at a prior job.
Old Jun 1, 2011 | 05:22 PM
  #188
jbrew's Avatar
Yea, I know Huskey caries the good stuff. Usually that 2000 degree crap. You just need to find the correct formulation. It doesn't have to be 2000 degree stuff. It doesn't get that hot @ the collectors or around the sensors. At least 1000 degrees tho.
Not sure if they have a site online, but here's some of what they offer and formulation info -
http://www.allsealsinc.com/antiseize...dsealants.html
Sounds like the 400 line, but that doesn't ring any bells lol. The 400, but high heat 400 maybe. Yea , they have it somewhere, so does other manufacturers.
The answer is Yes.
Old Jun 1, 2011 | 05:59 PM
  #189
So which should I use? An anti seize or permatex sealant? To me they have differing properties.
Old Jun 1, 2011 | 06:28 PM
  #190
Windsor's Avatar
I'd be reluctant to use a sealant on an O2 sensor because it might become welded in place, or rather just damn hard to remove at a future date. While the anti-seize isn't a sealant, it should be thick enough to stop any exhaust leak between the threads. My experience with headers is that a small leak down steam of the collector isn't going to make any audible noise. Realize you are creating a lot more back pressure by blowing air up the tailpipe than that your system will not generate.
I think the source of all your noise is at the head and the flange mating surface. If those OBX headers are not really flat, that thin shim gasket just won't work. That likely the reason they came with a composite gasket. Trust me, I've blown more than my fair share of header gaskets. Too bad Earl's doesn't make a gasket for the mod motors.
Old Jun 1, 2011 | 06:48 PM
  #191
OK jbrew and Windsor, I'm sold. Thanks for the help. I'll be getting anti seize for the o2's and bung plugs. The headers looked very flat so I'm not concerned about the OBX gaskets not sealing. Just want to get this done and no worries.
Old Jun 1, 2011 | 07:25 PM
  #192
Windsor's Avatar
Changing a header gasket is a lot easier than installing headers, but you may have to take the inner wheel wells off to access the clips on those header bolts.
Old Jun 1, 2011 | 07:44 PM
  #193
I'm already prepared to have to take off the inner fender liners again. Hope I don't lose any of the retainer clips for the header bolts, they only send just enough. Patrick has offered to come help so I'm going to have everything ready to go by the time he arrives. Truck in the air, Wheels off, liners out, o2's and plugs done, etc. Well, maybe I'm being too optimistic.
Old Jun 1, 2011 | 09:25 PM
  #194
Ill bring some nickel antiseize as well
  #195
OK since I have none. I may buy some anyhow since I need some anyway.
