How-To: Push-button Start (2004-2008)
Old May 25, 2009 | 12:02 AM
  #106
FL4X4's Avatar
after you cut the piece off the back where the power plug goes, there is two black tabs that you bend back and the metal peices should slide out. that way you don't have to break off the black tabs to get the black piece out, then you will have to glue that piece back in. all you will have to do, is slide the metal piece back into the black piece. hope this helps.
Any way you or any one else could provide a pic or two on this? I must of been at it for an hour trying to get the socket out with out breaking anything. thanks
Old May 25, 2009 | 02:44 PM
  #107
ride_002000's Avatar
Originally Posted by monoxide
ok i think i got this now. lol. so dont tap the red/blue cut it put one end to one pole of the switch and the other to the other pole with another wire going to the push button.
is that better?
Is this the correct wiring if I want a switch? Just want to make sure before I go ahead with this and start cutting.
Old May 25, 2009 | 06:55 PM
  #108
hydeph's Avatar
worlds most confusing truck to steal
Old May 25, 2009 | 06:57 PM
  #109
gcw's Avatar
gcw
Old Jun 22, 2009 | 12:37 AM
  #110
Shanks12's Avatar
now that this thread has been dead a month or so... and you guys have had time to do this and all.... have any of you ran into any problems?
Old Jun 22, 2009 | 01:26 AM
  #111
MmmBuckles's Avatar
my first set up broke when i was out of town and the button fell behind the dash. of course i didnt have tools with me. ya to stick my are in the tiny slot and grab the switch. fixed it when i got home though. havent had a problem since
Old Jun 22, 2009 | 11:53 AM
  #112
no problems from mine. I put in a "valet" switch so that I can still turn the key to start it it.
Old Jun 22, 2009 | 05:32 PM
  #113
gcw's Avatar
gcw
I ended up losing my keys and had to have two new ones made ($175) the guy said that i had to re-wire it because he couldn't get the pats to program, i think that he was just old and set in his ways so I wired it back up stock and he made my keys then i put it back no problems yet. im thinking about putting the valet switch in some time this week.
Old Jun 23, 2009 | 01:08 PM
  #114
Shanks12's Avatar
how did you fix it so it would stay in place..
Old Jun 23, 2009 | 01:54 PM
  #115
MmmBuckles's Avatar
didnt use hot glue this time. lol. i used to bolts, one behind the dash and another in front, and tightened them down to hold the switch in place. i have a '98 though, so mines probably completely different from most of the other people that tried this
Old Aug 10, 2009 | 03:58 PM
  #116
boomer1's Avatar
would this mod be the same on a manual f-150
Old Aug 10, 2009 | 04:48 PM
  #117
Nettershakes's Avatar
Ive had mine goin since this thread was made and iv had no problems. I will say though if i hold the button down two long the check gauges comes on the odometer readout but other than that, works good.
Old Aug 10, 2009 | 06:14 PM
  #118
gcw's Avatar
gcw
thanks netter glad you like it
yes boomer it will work with a 5speed just push the clutch in lol
Old Aug 11, 2009 | 08:29 AM
  #119
weshova's Avatar
would you mind posting a couple pics of your set-up? is it essentially the same?? same color of wires as well?? i have a 98 as well and would like to do this mod as well...we don't really have a problem with stealing so i might put nascar style switches in mine though
Old Aug 14, 2009 | 09:53 PM
  #120
spdkilz02's Avatar
http://www.summitracing.com/parts/PC...T/?image=large
will that one work for this mod? i see that it is 15A but doesn't say if that is for the 6v or 12v im thinking it is for the 12v
