DIY Intake Modification for 1997-2003 F-150
Old Jul 9, 2011 | 10:46 AM
  #181
Fordfan4life199's Avatar
After reading all of this i def want to do this mod soon. My only worry is that my MPG already kinda sucks so will this mod affect it any? Well it go down or maybe even up? Thanks!
Old Jul 9, 2011 | 02:14 PM
  #182
Veteran: Army
since you've faiiled to re-gear it's amazing your transmission has survived this long
Old Jul 9, 2011 | 03:17 PM
  #183
What you mean?
Old Jul 11, 2011 | 08:08 PM
  #184
Mondorah's Avatar
Great thread! Did this to my 4.2 this morning. Can tell a definite difference in the performance. It's no 'power house' but it sure is running better.
Thank you for the great write up.
Mondo
Old Jul 18, 2011 | 04:29 AM
  #185
ExTex's Avatar
What you mean?
I think he means that, since you've put the large tires on, it's putting a lot of stress on your tranny that it wasn't designed to deal with. You should change out the rear end ration to a higher numeric one to take some of the stress off your trans.
Old Jul 30, 2011 | 11:12 AM
  #186
I personally dont think that i have "fail" to regear. I havent had bigger tires for long and also my past truck (same style 99) had 35s and from 90K miles to 330K miles and did not have any problems. stock tranny to. Now if i had 37s or bigger, yea i would be re gearing.
Old Sep 2, 2011 | 07:20 PM
  #187
Ironhide_F150's Avatar
I just did it on my 2000 4.6 and gotta say, it was the easiest mod I've ever done on a vehicle since I used the flexible sewer pipe instead of regular PVC. it does feel like it has a little more pull when im passing other cars, but it only really kicks in at higher RPM's, but I guess thats what its supposed to do.
Old Oct 27, 2011 | 09:06 AM
  #188
gofordguy's Avatar
soo i was reading up at the begining of the fourum again.. you should only do this if u have a tuner/programmer? and how do i know if ive got a 2 or 3 valve? does that matter?
i have a 97 5.4?
Old Oct 27, 2011 | 11:08 AM
  #189
Alex_4.2L's Avatar
Ive done this mod but I have a question. Is it possible this mod could hurt your gas mileage. Your engine is taking in more air so the PCM would compensate by using more gas wouldn't it?
Old Nov 11, 2011 | 06:09 PM
  #190
Mad Texan's Avatar
Done with Bling Bling clamp...
Old Nov 13, 2011 | 02:52 PM
  #191
Veteran: Army
i have a 97 5.4?
you have a 2 valve 5.4, no tune required
Old Nov 14, 2011 | 01:33 PM
  #192
ExTex's Avatar
I would think that, for "normal" driving, there would be no real adverse effect on gas mileage. The only time the extra power would be used would be for high-speed passing, or maybe hard acceleration (stoplight drags?) when the throttle is fully or nearly wide open. The rest of the time, the throttle plate position would be the determining factor in air/fuel flow.
Old Feb 13, 2012 | 02:34 AM
  #193
AndersonS's Avatar
I just did this mod to my 03 5.4L, and I used sewer pipe. The write-up says "at least 2 inches" into the fender, which is fine, but does the new pipe have to rest inside both the cutouts in the fender, or just go through the first hole? Should it rest flush with the second hole in the inner fender, or is a little gap okay? Should any attempt be made to seal the gaps between the fender and pipe with weatherstripping or something?
Sorry for all the questions... It's sad, but I still want a K&N 77 Series.
Old Feb 16, 2012 | 03:54 PM
  #194
1997 lariat 4.6's Avatar
add your names ot list if you have not done so already
1. Gotts2BMe
2. tarajerame
3. jlr128
4. Patman03SprCrw
5. 2002 Wonderboy
6. dleebold
7. jughed
8. jbrew
9. cookdawg06
10. Bushie
11. NYFordguy
12. successtrainer
13. BroncoWrench
14. JMoreland
15. sharpshooter109
16. ridethlightning
17. JNC995
18. grizzstang
19. hockeyfanjeff
20. BANDAFX4
21. m1e9r5c6
22. Rusty-Ford
23. phatbak
24. JackandJanet
25. 31 YNOT
26. Polevaulter95
27. mccrick
28. FordBasser
29. CrackerJackk
30. 4.6 Punisher
31. A_White
32. my64falcon
33. hillbilly4u
34. Jump n
35. 97fordnut
36. Dankh02'F150
37. Apex Rex
38. venn189
39. Modea2006
40. CRIMSON-06SCREW
41. 05crewzer
42. ALVA
43. Aaron.b
44. R****tenden
45. 97_MarkIII
46. Ford7700
47. RebelOne
48. 1clean42
49. Kqresq
50. ccmac
51. Charles&Hudson
52. ElPaso
53. Lacho713
54. Muddauber
55. SkyBound85
56. tbraquet
57. RALgolf1953
58. sledman62
59. Thejake1989
60. RJP
61. kozzney
62. B&WScrew
63. linusb212
64. Ch1ro420
65. buxton91
66. DMD09
67. willys5555
68. 428GT
69. Dinggus
70. kieth 2000 xlt
71. Alexcngford
72. XtremeBawls
73. AZ98F150
74. sean46
75. russ10screw
76. 2Low2Go
77. BigTruckGuy
78. Red02FX4
79. nhford
80. FX41
81. Dukes218
82. Poolboy1191
83.KingranchCoy
84.enriched
85. BOMO
86. Wildcatt
87. Borrego97
88. OptimusPrimeFX4
89. Chexfam
90.Mikesea
91. FoMoCo905
92. Fordordie1
93. 1997 lariat 4.6
i love this mod! so easy and it actually helped my truck! i passed someone today and it had helped with takeoff, and didn't fall on its face like it did before this mod!
Old Feb 16, 2012 | 08:43 PM
  #195
1. Gotts2BMe
2. tarajerame
3. jlr128
4. Patman03SprCrw
5. 2002 Wonderboy
6. dleebold
7. jughed
8. jbrew
9. cookdawg06
10. Bushie
11. NYFordguy
12. successtrainer
13. BroncoWrench
14. JMoreland
15. sharpshooter109
16. ridethlightning
17. JNC995
18. grizzstang
19. hockeyfanjeff
20. BANDAFX4
21. m1e9r5c6
22. Rusty-Ford
23. phatbak
24. JackandJanet
25. 31 YNOT
26. Polevaulter95
27. mccrick
28. FordBasser
29. CrackerJackk
30. 4.6 Punisher
31. A_White
32. my64falcon
33. hillbilly4u
34. Jump n
35. 97fordnut
36. Dankh02'F150
37. Apex Rex
38. venn189
39. Modea2006
40. CRIMSON-06SCREW
41. 05crewzer
42. ALVA
43. Aaron.b
44. R****tenden
45. 97_MarkIII
46. Ford7700
47. RebelOne
48. 1clean42
49. Kqresq
50. ccmac
51. Charles&Hudson
52. ElPaso
53. Lacho713
54. Muddauber
55. SkyBound85
56. tbraquet
57. RALgolf1953
58. sledman62
59. Thejake1989
60. RJP
61. kozzney
62. B&WScrew
63. linusb212
64. Ch1ro420
65. buxton91
66. DMD09
67. willys5555
68. 428GT
69. Dinggus
70. kieth 2000 xlt
71. Alexcngford
72. XtremeBawls
73. AZ98F150
74. sean46
75. russ10screw
76. 2Low2Go
77. BigTruckGuy
78. Red02FX4
79. nhford
80. FX41
81. Dukes218
82. Poolboy1191
83.KingranchCoy
84.enriched
85. BOMO
86. Wildcatt
87. Borrego97
88. OptimusPrimeFX4
89. Chexfam
90.Mikesea
91. FoMoCo905
92. Fordordie1
93. 1997 lariat 4.6
94. Fordfan4life199
Gotta add me to that list. I did it several months ago and dont regret it. At high RPMs it accelerates so well to get around the people "driving Ms. Daisy"
