DIY Intake Modification for 1997-2003 F-150
Old May 10, 2013 | 05:58 PM
  #241
Veteran: Army
it'll work, without hindering anything
you can also remove the MAF "lid" and use your stock air box over the K&N open filter for a lil' more sealing
Old Jun 10, 2013 | 12:26 AM
  #242
rust1d's Avatar
84.) rust1d
Old Sep 7, 2013 | 11:17 AM
  #243
Galaxy's Avatar
So I'm still searching but can't find it…is there a how to or something for the mod where you attach the stock air box to the MAF but leave the CAI tube up to the TB? Have one pic, but can't tell from that how the stock air box section attaches to the MAF modified by the prior CAI.
Old Sep 7, 2013 | 10:40 PM
  #244
jbrew's Avatar
Why don't you ask in the thread you started? I know I posted a pick. If yuh need a map, they're out there.
Oh well, good luck.
Old Sep 8, 2013 | 11:38 AM
  #245
Galaxy's Avatar
Cause I was already in here and the question had come up (in here) but didn't seem like it ever got covered. I have that pic, thanks! But I can't tell how it's modded and put together at the MAF in that pic.
Old Sep 8, 2013 | 11:52 AM
  #246
jbrew's Avatar
Yea, I did that along time ago. You remove the outer housing, first half, set it aside. Pull the insides out, chop it just enough to get the CAI box to seal. Using a Fernco, adapt the tube to the MAF cylinder. The MAF cylinder is attached to the pieced you chopped earlier.
I have pics somewhere.
Old Sep 8, 2013 | 11:56 AM
  #247
jbrew's Avatar
I guess you need pics ehh, - I know I would after that ^^ explanation.
Old Sep 8, 2013 | 03:18 PM
  #248
Galaxy's Avatar
No pics needed...stock intake is back on with mod; just finished!. Not gonna mess with it. Thanks though.
Old Sep 8, 2013 | 09:01 PM
  #249
jbrew's Avatar
Not a bad idea. Your welcome.
Old Dec 9, 2013 | 04:38 PM
  #250
jbass's Avatar
Just signed-up today...but I've been reading this thread for a few weeks! I actually did the mod, and pulled the silencer today. I can definately hear a difference, and THINK I feel a little difference. Honestly, this is the weakest feeling 4.6 I've ever had..lol. with almost 300k, and worn out shocks, I'm not seeing a huge gain. Besides, gonna change plugs Wed..bad bad detonation if I don't run 93 octane....had the same prob with my gt ( tune, hotter plugs, and shell v-power fixed that...lol)
#1. The end of the flex pipe that was sealed to the silencer housing.....do I need to put a clamp back on that, or will it be fine just shoved back on there?
#2. I have a 98 extended cab 4x4 4.6...from all that I've read, the 3" pvc (3 1/2" od) should basically butt up to the end of the filter housing. Mine actually went OVER it! So, I cut it a little short, to leave room for the coupler to tighten to the housing. The ID of the nipple on the housing is about 2 7/8 ( if I remember correctly). would this housing have came off of a 97? Can anyone confirm that this just don't jive with what everyone else has? (EDIT) BTW, it's and early 98.....08/97....title says 98, and vin runs as 98....so I guess it's got 97 crap on it...lol
#3. Considering that the housing has choked me back down, would it be fesable or even worth the time to remake my pipe a little longer, and cut out the end of the housing so that the pipe will fit just inside of it, and glue the **** out of it to seal it? If so, what would be the best thing to seal it with?
Old Dec 10, 2013 | 04:57 PM
  #251
Veteran: Army
just jit up your local wrecking yard / pull-a-part and get the newer air filter housing
Old Jun 17, 2014 | 01:25 PM
  #252
shadowvox6's Avatar
I performed the Gotts Mod on my 97 F150, but I did it in a slightly different way....
I own a 2004 Chrysler 300M Special, and I have owned a 1999 Chrysler 300M before that. I had some spare intake parts lying around...parts I have used for various experiments in the past. One of these was the stock intake elbow from a 98 - 01 3.2 / 3.5L motor. They have a nice, smooth internal path, 90* bend, etc. I simply cut the bend out of the elbow, and use the straight piece (with bellows) and tucked one end (end with the "lip") into the fenderwell. That lip locks it in place.....and clamped the other end around the air filter housing. Please see picture here:
I also removed the silencer....without taking off the factory coupler. Just used a long flathead screwdriver, and a long set of nedle nose pliers....and pulled it out.
Truck runs better now....more more responsive.....
Old Jul 23, 2014 | 02:07 PM
  #253
m3dragon's Avatar
Will be doing this, this weekend. Save $$ but improve airflow
Old Jul 25, 2014 | 11:37 PM
  #254
m3dragon's Avatar
I looked at the 2000 5.4 intake and there is no silencer. Hummm
Old Nov 22, 2014 | 03:07 PM
  #255
Fordman450's Avatar
I put a spectre universal intake in my 03 f150. Forgot to unhook my battery and it wouldn't run. Then I was told to unhook my battery and let the computer reset I left it unhooked for about a minute or two then hooked it back up and it still won't stay running. Any advice?
