Anyone changed the map/dome lights to LED's?
Old May 16, 2011 | 08:47 AM
  #136
murderout's Avatar
Originally Posted by jfire3134
Has anyone changed out the license plate lights? I ordered 194's, and they fit the connection, but are physically too big to fit
I ordered mine from gorecon.com and they fit fine
Old May 19, 2011 | 12:44 PM
  #137
RedlineTuning's Avatar
Has anyone had issues with their LED lights staying on very dimly after the swap? My front map bulbs stay on very dimly all the time, even after I lock the truck and come back after 5 minutes. Anyone else had this problem?
Regards,
Andreas
Old May 19, 2011 | 12:51 PM
  #138
BETCHER78's Avatar
i noticed from time to time. my rear one stays on , probably the dimming ckt leaking enough to cause an LED to light but not a filliment bulb.
could be an issue for some who dont drive their truck every day. i know a guy who has a 09 plat and keeps it on a tender. or the batt will go dead. he has 7K on his , and i have 50K . they are about 2 weeks apart. i bought it to drive it.
he also used to keep the keys in the ignition , which keeps some modules alive. from what i have been told
Old May 20, 2011 | 08:30 AM
  #139
ibcop's Avatar
Regards,
Andreas
No issues with mine after two plus years. Maybe you didn't get a good bulb. I got mine from VLeds.
Old May 20, 2011 | 12:37 PM
  #140
I got mine from VLeds as well. I'm afraid they will burn out prematurely because of the low voltage going to them.
Andreas
Old May 20, 2011 | 04:36 PM
  #141
ibcop's Avatar
Andreas
Bad bulb? How old are they? Are they direct replacements (i.e. swapped a 194 for a 194)? Did you contact Vled? I don't think low volatge would cause the bulb to stay on - they are made to accept the voltage difference.
Old Nov 30, 2011 | 03:03 AM
  #142
NastyFX4's Avatar
I think when that happens you need a LED with a resistor built in.
So I have a 2011 Supercrew with sunroof. I'm looking to do my dome, map lights, etc and the license plate bulbs. Should I get them from VLEDs or SuperBright? If so which ones?
I'm looking at these right now and think these are correct. How many do I need of each?
I'd like to find this in 5,000K. I couldn't find it on the website.
http://www.v-leds.com/Interior-LED-B...-p8200027.html
http://www.v-leds.com/Interior-LED-B...-p6691894.html
http://www.v-leds.com/Interior-LED-B...-p8804828.html
I appreciate the help in advance!!
Old Nov 30, 2011 | 02:04 PM
  #143
Milt IV's Avatar
If you have the SCREW with sunroof then for the front you need 2 bulbs - (194) for the maps and 1 bulb - (211) for the dome. For the rear you need 3 bulbs - (211) for the maps and dome, the rear uses all the same. Double check the bulb counts because I am not 100% positive with the sunroof. Just look and see how many bulbs you actually have.
For the license plate you need 2 bulbs - (194 angled flank style).
If you are going to do the license plate then you might as well do the cargo lights. They usually come on when you unlock the truck with the fob. You need 2 bulbs (921) for the cargo lights.
You can get them from V-leds or superbrightleds. They both have excellent customer service and shipping IMO. They both offer everything you are looking for in either 6k(slight blue hint) that is not even noticeable or 5k(pure white). I went with the 6k for all. V-leds has higher prices but I personally like the quality of their bulbs better. I got my cargos from superbrightleds and they are nice too but they just didn't look like they were made as well to me.
Here is a link to my thread if you want to see what the 6k look like.
https://www.f150online.com/forums/il...lled-pics.html
Old Nov 30, 2011 | 06:11 PM
  #144
Raptor05121's Avatar
To the person with the LEDs staying on, check to see if there is voltage with a DMM.
Old Dec 6, 2011 | 02:16 AM
  #145
NastyFX4's Avatar
Here is what I ordered just to help anyone else out. I have a 2011 F150 FX4 with the Sunroof and this is what I needed. Kind of surprising that the rear dome only has one bulb in my truck. Thought they had three.
Front Dome Lights 5000K (1 Pair)
Rear Dome Light 5000K (1 Bulb)
License Plate Bulbs 5000K (1 Pair)
Old Dec 6, 2011 | 01:19 PM
  #146
Milt IV's Avatar
That is why I told you to double check. You bought too many bulbs silly head.
I'm sure you could sell those 2 extra on here in no time.
Old Dec 7, 2011 | 05:59 PM
  #147
jpetre's Avatar
I totally got too many bulbs, I got
4 - 211_4HP_W_6K (only need 1 - Installed)
2 - 194_13_SMT_W_6K (only need 1 - Installed )
1 - 194_6_FA_W_6K (Rear Plate!)
1 - 921_19_HP_W_6K (need this for cargo)
Does anyone know what the puddle lamps are? I also will see if these will fit the wife's new explorer.
Old Dec 7, 2011 | 07:04 PM
  #148
post them up with some pictures in the classifieds section
Old Dec 8, 2011 | 12:02 AM
  #149
NastyFX4's Avatar
Trusted you!
Old Feb 27, 2012 | 09:21 PM
  #150
mjm222016's Avatar
got a quick question guys im ordering some lights for a friend because he saw mine. i went to order them and they don't have the rear dome i order when i got them. would this work http://www.v-leds.com/Interior-LED-B...-p9770320.html in a 2011 supercrew with a sunroof for the dome?
