Anyone changed the map/dome lights to LED's?
well that sucks i just ordered mine yesterday guess ill have to wait i ordered the led lights for the turn signal mirror mod too cant wait till its all done
I installed my map lights yesterday and it made a world of difference. The interior is not bright by any means. Everything is well lit and its easy on the eyes. I also got an email saying my dome lights shipped out. The truck def should of came this was from the factory. Map lights only took 5 minutes to do if that, simple cheap mod to do!!
I ordered the same ones that were posted earlier in the thread.
I got my dome and reading lights for the rear in last night. Intalled them. These were the festoon style bulbs. The reading lights snapped in fine.
The middle dome light snapped in, but wiggles a little. Like it's a little loose when it's installed. Anyone else have this issue? It works fine, makes contact, but I can wiggle it with my finger. The stock bulb was pretty set when installed.
Before you install the lights pinch the ends that hold the light in place together. When you push in the new light they will reform to the smaller size and hold the light in place. Also when installing the new light try not to push on the center of the bulb, push on the outside contacts. If you push on the center the ends can bend and could easily break. Make sure you install the light the correct way, I didnt think it would matter. My center dome light would work but the 2 reading lights wouldnt, I just had to rotate the reading lights 180 degrees and now they are all working.
Just ordered some lights for my truck. Here is what I got..
Qty Item Unit Price Total Price
1 HID 6K WHITE HIGH POWER 4 LED FESTOON DOME BULB 211
1 2 V-LEDS 6K WHITE 194 13 LED LIGHT BULBS 158 168 2825
1 2 WHITE 74 V-LEDS .5 WATT HIGH POWER LED LIGHT BULBS 37
1 LED for the Dome and 1 set for the Map Lights and 1 set for the Vanity...
Let you guys know how it goes.
My lights came in yesterday, but I didn't have a chance to put them in until today. The difference is dramatic. I replaced the front map lights and the rear dome light. Best $25 I have spent on my truck.
Anyone know the part number for the bed light on a 2010?
