Uh oh, P0175, part 2. Who's next?
Old Apr 18, 2009 | 03:38 PM
  #76
last5oh_302's Avatar
Originally Posted by FX4life
I think it only effects certain build dates, but I could be wrong. Stealth and I both have an early 05 build date of 11/04. Quinti I think explained it in this thread or my thread about what the issue is and who is affected.
Thanks Matt, and yes I read Quintin's reply in your thread, but I recall him mentioning Ford switching to another injector in 05 which continued through to early build 06's.
That's why I'm wondering why I didn't get a letter.
Oh yeah, I also recall Stealth mentioning he received the letter in your thread.
Old Apr 18, 2009 | 03:39 PM
  #77
Here's the post FX4life's referring to, I think.
Originally Posted by HDXLT
ALL 05's FOR THESE PLANT HAVE THE EXTENDED COVERAGE
VEHICLES COVERED BY THIS PROGRAM
Vehicle Line Model Years Assembly Plant Production Dates
F-150 2005 Dearborn Assembly Plant
F-150 2005 Norfolk Assembly Plant
F-150 2005 Kansas City Assembly Plant
Expedition 2005 Michigan Truck Plant
Navigator 2005 Michigan Truck Plant
F-Super Duty 2005 Kentucky Truck Plant
The injctors are only on 5.4 not on the 4.6.
In some of the affected vehicles with 5.4L 3V engines, the fuel injectors may stick open or closed.
This concern could cause the check engine light to illuminate along with a hard starting and/or rough
running engine condition. In some instances, continued engine operation with a stuck open/closed
fuel injector could result in powertrain damage.
Sorry dude your going to need a motor, but its all good you will get a new short block out of it.
Old Apr 18, 2009 | 03:42 PM
  #78
I don't know where my truck was built. Does that cover every plant the F150 is built, or are there a few missing?
Old Apr 18, 2009 | 03:46 PM
  #79
Loking for the letter.
OK, here's a copy of the letter. If you call a dealer and give your vin and Customer satisfaction Program 07M08 to the service manager they will verify if you're covered.
http://www.justanswer.com/uploads/ti...call_07M08.pdf
Old Apr 18, 2009 | 04:00 PM
  #80
Okay, thanks.
Do you know how I determine which plant my truck was built in, just as a "good to know", because I can't find anything that indicates this. I guess there's a code in the VIN?
Old Apr 18, 2009 | 04:09 PM
  #81
Okay, thanks.
Mine was on the window sticker from when I bought the truck. It shouldn't matter anyway, the dealer will know by your vin.
HDXLT may be able to pull up your vin info for you Monday also, if you ask him.
Old Apr 18, 2009 | 04:13 PM
  #82
FX4life's Avatar
Sorry guys maybe it was HDXLT. He and quintin have had great posts in both the threads, so did asemechanic.
Old Apr 18, 2009 | 04:15 PM
  #83
Sorry guys it was HDXLT! He and quintin have had great posts in both the threads, so did asemechanic.
Yep, it is great to have such knowledgeable guys helping us all!
Old Apr 18, 2009 | 04:29 PM
  #84
The 11th digit in my VIN is an "F". Apparently F = Dearborn.
This is the VIN decoder I used:
http://www.angelfire.com/ca/TORONTO/VIN/ford.html
Old Apr 18, 2009 | 04:30 PM
  #85
Mine was also assembled in Dearborn.
Old Apr 18, 2009 | 04:34 PM
  #86
I wonder why some people got the letter and others didn't? My truck was probably one of the last few 05's off the line in June of 05.
Oh well; next time I'm at my dealer I'll see what's up.
Old Apr 18, 2009 | 04:55 PM
  #87
risupercrewman's Avatar
Okay, thanks.
Mine has a UAW Assembly plant sticker on the lower right side of the windshield that has the Kansas City Plant on it. The "Show me State".....
Old Apr 18, 2009 | 05:07 PM
  #88
Yeah, I realize a lot of trucks have a sticker somewhere indicating the plant. Mine has nadda, nowhere, other than the VIN/manufacturers sticker inside the drivers door, and the tire info sticker. That's it, nothing anywhere else on the truck.
Old Apr 18, 2009 | 05:56 PM
  #89
FX4life's Avatar
Originally Posted by Quintin
POS injectors. Ford changed vendors for the '05 model year. I think in mid '06, they went back to the vendor that provided the '04 injectors (which are fine).
here is Quintin's post I was referring to earlier, as well as the one HDXLT posted (thanks stealth)
Old Apr 18, 2009 | 06:00 PM
  #90
I'm hoping Quintin is wrong, and they actually changed injectors just prior to the 06's. That way I may be out of the loop.
That was the same post I was talking about as well.
